modify mill.set to incl. MCX file name
Keep in mind I have very little post mod experience...
Is it possible to get mill.set to output the .MCX file name in the header ?
This is what I am using now. It is slightly modified...
 [post_VERSION] #DO NOT MOVE OR ALTER THIS LINE# V11.00 E1 P0 T1114796248 M11.00
# Post Name : MILL.SET
# Product : Mill
# Machine Name : Generic
# Control Name : Generic
# Description : Generic setup sheet for Mill X
# 4-axis/Axis subs. : No
# 5-axis : No
# Executable : MP 11.0
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Revision log:
# CNC 04/28/05 - Initial Setup for Version X.
# CNC 11/15/05 - Modified header section and layout, added new functionality
# CNC 01/20/06 - Fixed buffer logic to correctly handle null toolchanges
# CNC 02/17/06 - Added opcomment string reset in pcomment2
# - Modified stock to leave to seperate 2D toolpath (XY and Z) from surface
# toolpaths (Drive surface and Check surface)
# CNC 02/22/06 - Added check for "Write NC Operation Information" output error popup if not enabled in CD
# - Reworked information output by various tool paths. Added surface machining operation name
# CNC 03/14/06 - Fixed typo in pwritbuf2. Modified pdrillcyc to use nextdc$ rather than drillcyc$
# CNC 04/10/06 - Modified output for surface high speed machining operations.
# CNC 06/26/06 - Initial post setup for Mastercam X2
# Features:
# This post supports output for 3 and 4 axis milling.
# It is designed to support the features of Mastercam X Mill.
# NEW FEATURES FOR X:
# - Variable initialization with CD_VAR are read directly from CD. Changing these initial values
# in the post will not effect output. These values are only processed during the update post routine.
# All initializations read from CD come from the active machine groups selected control definition.
# - Supports X comments including machine name, group name and group comment output (see pcomment2)
# Output of these comments is controlled by setting outputxcom in the Optional Output Settings area.
# - Enhanced output control via post switches (see Optional Output Settings area)
# Misc. Values:
# Integers:
# mi1 - mi10 (NOT USED)
# Reals:
# mr1 - mr10 (NOT USED)
# Additional Notes:
# File extension (.doc) is set internally in MP. Use pprep$ postblock to override this setting.
# Rapid traverse times are determined by maximum rapid feedrates set in the selected Machine Definition
# Time estimates will be wrong if these settings are incorrect.
# END_HEADER$
# Debugging and Factory Set Program Switches
# Define constants
m_one := -1
zero := 0
one := 1
two := 2
three := 3
four := 4
five := 5
c9k := 9999
m_c9k := -99999
fastmode$ : yes$ #CD_VAR Enable Quick Post Processing, (set to no for debug)
bug1$ : 2 #0=No display, 1=Generic list box, 2=Editor
bug2$ : 40 #Append postline labels, non-zero is column position?
bug3$ : 0 #Append whatline number to each NC line?
bug4$ : 1 #Append NCI line number to each NC line?
whatno$ : yes$ #Do not perform whatline branches? (leave as yes)
linktolvar$ : 0 #Associate X tolerance variables to V9- variable?
linkplnvar$ : 1 #Associate X plane specific variables to V9- variable?
skp_lead_flgs$ : 0 #Do NOT use v9+ style contour flags
get_1004$ : 0 #Find gcode 1004 with getnextop?
rpd_typ_v7$ : 0 #Use Version 7 style contour flags/processing?
strtool_v7$ : 2 #Use Version 7+ toolname?
tlchng_aft$ : 2 #Delay call to toolchange until move line
cant_tlchng$ : 1 #Ignore cantext entry on move with tlchng_aft
newglobal$ : 1 #Error checking for global variables
getnextop$ : 1 #Build the next variable table
tooltable$ : 3 #Pre-read, call the pwrtt postblock (DO NOT CHANGE!)
# General Output Settings
linarc$ : yes$ #Linearize arcs? (DO NOT CHANGE!)
arctype$ : 2 #CD_VAR Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.,
#5 = R no sign, 6 = R signed neg. over 180
progname$ : 1 #Use uppercase for program name (sprogname)
# Optional Output Settings
output_comments : yes$ #Output Operation Comments in tool list?
outputxcom : yes$ #Output new X comments? (Machine name, Group comment, Group name)
xyz_limits : 3 #Output Max/Min X,Y,Z information?
#0 = Do NOT output ANY Max/Min X,Y,Z information.
#1 = Output Max/Min X,Y,Z info. ONLY for EACH tool (not Program)
#2 = Output Max/Min X,Y,Z info. ONLY for entire Program
#3 = Output Max/Min X,Y,Z info. for EACH tool AND Program (if > 1 tool)
# Individual axis output (if xyz_limits > 0)
X_limits : yes$ #Output Max/Min values for the X axis?
Y_limits : yes$ #Output Max/Min values for the Y axis?
Z_limits : yes$ #Output Max/Min values for the Z axis?
# Specific setting to allow tuning the cycle time calculations
# Set the time it takes for machine to do a toolchange
tlchgtime : 0.1 #Tool Change Time (* in Minutes *)
time_est : 3 #Output operation and/or cycle times?
#0 = Do NOT output time estimates (including det_time estimates below)
#1 = Output operation time ONLY for EACH tool (not Program)
#2 = Output comeplete cycle time ONLY for entire Program
#3 = Output operation time for EACH tool AND cycle time for Program (if > 1 tool)
# The 'det_time' switch allows selecting the output of "Detailed Times".
# In addition to the usual 'Cycle Time' you can get the time spent at
# RAPID and at FEEDRATE during the program.
# *IMPORTANT* -
# Note that the Program TOTAL TIME includes the Toolchange time(s),
# so it will be longer than the Total RAPID time + Total FEED time!
det_time : 0 #Output Rapid/Feedrate times? (Requires time_est > 0)
#0 = Do NOT output ANY Rapid/Feedrate time breakdown.
#1 = Output Rapid/Feedrate times ONLY for EACH tool (not Program)
#2 = Output Rapid/Feedrate times ONLY at end for entire program
#3 = Output Rapid/Feedrate times for EACH tool AND Program (if > 1 tool)
fr_limits : 3 #Output Max/Min Feedrate information?
#0 = Do NOT output ANY Max/Min Feedrate information.
#1 = Output Max/Min Feedrate info. ONLY for EACH tool (not Program)
#2 = Output Max/Min Feedrate info. ONLY at end for entire program
#3 = Output Max/Min Feedrate info. for EACH tool AND Program (if > 1 tool)
show_lengths : 0 #Output Feed/Rapid path length information?
#0 = Do NOT output ANY Feed/Rapid path length information.
#1 = Output Feed/Rapid path length info. ONLY for EACH tool (not Program)
#2 = Output Feed/Rapid path length info. ONLY at end for entire program
#3 = Output Feed/Rapid path length info. for EACH tool AND Program (if > 1 tool)
stock_info : no$ #Display stock material and size/location?
show_tool_mfg : no$ #Output the tool definition - 'manufacturer' data?
show_chuck_name : no$ #Output the tool definition - 'chuck name' data?
show_tool_details : no$ #Output tool details information (20000's data)?
# Common User-defined Variable Initializations (not switches!)
drlgsel : -1 #Selector variable for drill cycle string
tol : 0.0001 #Tolerence for feed rates set to zero
ttltime : 0 #Total operation time
tltime : 0 #Feed time
trtime : 0 #Rapid time
total : 0 #Total machine time
tot_ltime : 0 #Total FEED time
tot_rtime : 0 #Total RAPID time
len : 0 #Length for calculation
dx : 0 #Delta x
dy : 0 #Delta y
dz : 0 #Delta z
result : 0 #Test Variable
comp : 0 #CDC status from pre-scan (see 'look4comp')
comp_cc : 0 #CDC status from pre-scan (see 'look4comp')
comp_cc_computer : 0 #CDC status from pre-scan (see 'look4comp')
look4comp : yes$ #Buffer null toolchanges to search for comp (yes or no)
tool_end : no$ #End flag when scanning for CDC settings at Null tlchgs
cdc_found : no$ #Was an active CDC setting found during scan
sof : 1 #Start of file flag
write_ops : 0 #Write NC operation information (True/False)
use_across : 0 #Use across distance? (True/False)
toolop : 0 #Modified tool_op$ for string selector lookup
hmm_type : 0 #High speed machining style
#String and string selector definitions for NC output
#Seperator lines
sepline "--------------------------------------------------------------"
sepline2 "========================================="
sepline3 "=============================================================="
#Comment strings
snull #Null string
smachname #Machine name
sgrpcomm #Group comment
sgrpname #Group name
sopcomment #Operation comment
#String variables to hold 'sparameter' string data
stl_mfg_com #'tool mfg comment' from tool
stl_chuck_com #'tool chuck comment' from tool
soptype #Surface machining operation type
# Error messages
swriteopserror "ERROR - WRITE NC OPERATION INFORMATION MUST BE ENABLED IN CONTROL DEFINITION - SET AND REPOST"
# General String select tables
#Select operation note
sop00 "NULL"
sop01 "CONTOUR"
sop02 "CONTOUR"
sop03 "DRILL CYCLE - "
sop04 "POCKET"
sop05 "RULED"
sop06 "2D-SWEPT"
sop07 "3D-SWEPT"
sop08 "REVOLVED"
sop09 "LOFT"
sop10 "COONS"
sop11 "TRIM "
sop12 "FLOWLINE"
sop13 "SURFACE FINISH "
sop14 "SURFACE ROUGH "
sop15 "POINT"
sop16 "DRILL-5AX"
sop17 "CURVE-5AX"
sop18 "SWARF-5AX"
sop19 "FACING"
sop20 "OP20?"
sopnote #Target for string
fstrsel sop00 opcode$ sopnote 21 -1
#Select drill operation note
sdr00 "SIMPLE" #drill - no dwell
sdrd0 "COUNTERBORE" #drill - with dwell
sdr01 "PECK" #peck drill - no dwell
sdrd1 "PECK" #peck drill - with dwell
sdr02 "CHIP BREAK" #chip break - no dwell
sdrd2 "CHIP BREAK" #chip break - with dwell
sdr03 "TAP" #tap - right hand
sdrd3 "TAP" #tap - left hand
sdr04 "SIMPLE BORE" #bore #1 - no dwell
sdrd4 "BORE W/DWELL" #bore #1 - with dwell
sdr05 "BORE W/STOP" #bore #2 - no dwell
sdrd5 "BORE W/STOP" #bore #2 - with dwell
sdr06 "MISC_1" #misc #1 - no dwell
sdrd6 "MISC_1" #misc #1 - with dwell
sdr07 "MISC_2" #misc #2 - right hand
sdrd7 "MISC_2" #misc #2 - left hand
sdrillcyc #Target for string
fstrsel sdr00 drlgsel sdrillcyc 16 -1
#Surface toolpath type selector
sfin0 #Leave blank
sfin5 "PARALLEL"
sfin6 "RADIAL"
sfin7 "PROJECT"
sfin8 "FLOWLINE"
sfin9 "CONTOUR"
sfin10 "POCKET"
sfin11 "PARALLEL"
sfin12 "RADIAL"
sfin13 "PROJECT"
sfin14 "FLOWLINE"
sfin15 "CONTOUR"
sfin39 "PENCIL"
sfin40 "LEFTOVER"
sfin41 "PARALLEL STEEP"
sfin42 "SHALLOW"
sfin43 "SCALLOP"
sfin44 "PLUNGE"
sfin107 "RESTMILL"
sfin108
sfin109 "BLEND"
ssurftype #Target for string
fstrsel sfin0 toolop ssurftype 21 -1
#Surface high speed machining style selector
shmm0 "CORE ROUGHING"
shmm1 "AREA CLEARANCE"
shmm2 "WATERLINE"
shmm3 "SCALLOP"
shmm4 "HORIZONTAL AREA"
shmm5 "RASTER"
shmm6 "PENCIL"
shmm7 "FLOWLINE"
shmm8 "BLEND"
shmm9 "SPIRAL"
shmm10 "PROJECT"
shmm11 "ROUGH REST PASSES"
shmm #Target for string
fstrsel shmm0 hmm_type shmm 12 -1
#Select stock orientation note
stk0 "AT CENTER, Z AT TOP"
stk1 "UPPER LEFT CORNER, Z AT TOP"
stk2 "UPPER RIGHT CORNER, Z AT TOP"
stk3 "LOWER RIGHT CORNER, Z AT TOP"
stk4 "LOWER LEFT CORNER, Z AT TOP"
stk5 "UPPER LEFT CORNER, Z AT BOTTOM"
stk6 "UPPER RIGHT CORNER, Z AT BOTTOM"
stk7 "LOWER RIGHT CORNER, Z AT BOTTOM"
stk8 "LOWER LEFT CORNER, Z AT BOTTOM"
stknote #Target for string
fstrsel stk0 stck_crnr$ stknote 9 -1
#Month selector
smon0 ""
smon1 "JAN."
smon2 "FEB."
smon3 "MAR."
smon4 "APR."
smon5 "MAY."
smon6 "JUN."
smon7 "JUL."
smon8 "AUG."
smon9 "SEP."
smon10 "OCT."
smon11 "NOV."
smon12 "DEC."
smonth #Target for string
fstrsel smon0 month$ smonth 13 -1
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
fs2 1 0.4 0.3 #Decimal, absolute, 4/3 place, default for initialize (
fs2 2 0.4 0.3n #Decimal, absolute, 4/3 place, non-modal
fs2 3 1 0 1 0n #Integer, not leading, non-modal
fs2 4 0.2 0.2n #Decimal, absolute, 2 place, non-modal
fs2 5 1.4 1.3ltn #Decimal, absolute, 4/3 place, leading&trailing, non-modal
fs2 6 +1.4 1.3ltn #Decimal, absolute, 4/3 place, leading&trailing with SIGN
fs2 7 0.4 0.3ltn #Decimal, 4/3 place, trailing, non-modal
fs2 8 0^2 0^2n #Decimal, 2 place, omit decimal if whole number, non-modal
fs2 9 4 0 4 0l #Integer, force four leading
# These formats used for 'Date' & 'Time'
fs2 17 1 0 1 0 #Integer, not leading
fs2 18 2.2 2.2lt #Decimal, force two leading & two trailing (time2)
fs2 19 2 0 2 0t #Integer, force trailing (hour)
fs2 20 0 2 0 2lt #Integer, force leading & trailing (min)
# Format assignments
fmt 9 progno$ #Program number
fmt 3 t$ #Tool number
fmt 7 tldia$ #Tool diameter
fmt 7 tcr$ #Tool corner radius
fmt 3 tloffno$ #Diameter offset number
fmt 3 tlngno$ #Length offset number
fmt 3 ss$ #Spindle speed
fmt 4 fr_pos$ #Feedrate
fmt 2 llen #Feed cut length
fmt 2 rlen #Rapid traverse cut length
fmt 2 llen_total #Feed cut length (program total)
fmt 2 rlen_total #Rapid traverse cut length (program total)
fmt 2 total #Total part time
fmt 2 ttltime #Total operation time
fmt 3 thrs #Time in hours
fmt 3 tmin #Time in minutes
fmt 8 tsec #Time in seconds
fmt 3 tcnt #Tool Counter
fmt 3 custcycle #Custom Cycle number
fmt 4 tmax_fr #Max Feedrate in current Tool
fmt 4 tmin_fr #Min Feedrate in current Tool
fmt 4 pmax_fr #Max Feedrate in Program
fmt 4 pmin_fr #Min Feedrate in Program
fmt X 7 stck_ht$ #X - Stock Height
fmt Y 7 stck_wdth$ #Y - Stock Width
fmt Z 7 stck_thck$ #Z - Stock Thickness
fmt X 2 stck_x$ #X origin of block
fmt Y 2 stck_y$ #Y origin of block
fmt Z 2 stck_z$ #Z origin of block
fmt 2 stck_crnr$ #Origin corner of stock
# Variables to hold info read from 'additional parameters'
fmt 2 stock #Amount of stock to leave
fmt 2 zstock #Amount of stock to leave
fmt 2 drive_stock #Amount of stock to leave on drive surfaces
fmt 2 check_stock #Amount of stock to leave on check surfaces
fmt 2 wall_stock #High speed machining - stock to leave on walls
fmt 2 floor_stock #High speed machining - stock to leave on floors
fmt 2 rgh_ang #Roughing angle
fmt 2 rgh_step #Roughing step size
fmt 2 num_fin #Number of finish passes
fmt 2 fin_step #Finish pass step size
fmt 2 fin_stk #Finish allowance
fmt 2 across #Across distance
fmt 2 along #Along distance
fmt 2 cut_dir #Cutting direction: 0 = along, 1 = across
fmt 2 use_cdev #Use chordal deviation (0 = no, 1 = yes)
fmt 2 chdev #Chordal deviation
fmt 2 total_tol #Total tolerance - HMM toolpaths
fmt 2 step_down #Stepdown distance
fmt 2 across_dist #Across cut: distance
fmt 2 across_height #Across cut: scallop height
# Numeric variables to hold '20004' tool parameters
# Do NOT change the order of these (16) variable definitions!
fmt 2 tl_number
fmt 3 tl_type
fmt 3 tl_material
fmt 3 tl_corner_typ #0=flat, 1=bullnose, 3=ball
fmt 2 tl_dia
fmt 2 tl_corner_rad
fmt 2 tl_tpi
fmt 2 tl_tip_angle
fmt 3 tl_dia_ofs
fmt 3 tl_len_ofs
fmt 2 tl_feed
fmt 2 tl_plunge_feed
fmt 2 tl_retract_rate
fmt 2 tl_spindle_rpm
fmt 3 tl_coolant
fmt 3 tl_num_flutes
# Numeric variables to hold '20005' DRILL type tool parameters
# Do NOT change the order of these (9) variable definitions !
fmt 3 drl_cycle$
fmt 2 drl_peck1
fmt 2 drl_peck2
fmt 2 drl_peck_clr
fmt 2 drl_chip_brk
fmt 2 drl_dwell
fmt 2 drl_angle
fmt 2 drl_tap_drl_dia
fmt 2 drl_shift
# Numeric variables to hold '20006' MILL type tool parameters
# Do NOT change the order of these (8) variable definitions !
fmt 3 tl_cut_cap
fmt 2 tl_rgh_XY_step
fmt 2 tl_rgh_Z_step
fmt 2 tl_fin_XY_step
fmt 2 tl_fin_Z_step
fmt 2 tl_tip_dia
fmt 2 tl_minor_dia
fmt 2 tl_thrd_mill_angle
# Numeric variables to hold '20007' MILL type tool holder parameters
# Do NOT change the order of these (11) variable definitions !
fmt 2 tl_min_dia_plg
fmt 2 tl_flute_len
fmt 2 tl_overall_len
fmt 2 tl_shld_len
fmt 2 tl_arbor_dia
fmt 2 tl_holder_dia
fmt 2 tl_holder_len
fmt 3 tl_dummy_pos8
fmt 3 tl_dummy_pos9
fmt 3 tl_dummy_pos10
fmt 3 tl_units #0=inches, 1=metric
#Format the variables used to output the X,Y,Z Max/Min values
fmt 6 max_Xpos
fmt 6 min_Xpos
fmt 6 max_Ypos
fmt 6 min_Ypos
fmt 6 max_Zpos
fmt 6 min_Zpos
fmt 17 year2 #Calculated year value
fmt 18 time2 #Capture 24-hour time value into 'time2' variable
fmt 19 hour #Hour
fmt 20 min #Minutes
year2 = year$ + 2000
# Tool Comment / Manual Entry Section
pcomment$ #Comment from manual entry (must call pcomment2)
pcomment2 #Required if doing boolean 'if' logic testing!
pcomment2 #Output Comment from manual entry
sopcomment = snull
scomm$ = ucase(scomm$)
if gcode$ = 1051, smachname = scomm$ #Machine name
if gcode$ = 1052, sgrpcomm = scomm$ #Group comment
if gcode$ = 1053, sgrpname = scomm$ #Group name
if gcode$ = 1008, sopcomment = scomm$ #Operation comment
psurfop #Output surface machining operation type if programmed
if opcode$ = 13 | opcode$ = 14,
if tool_op$ < 16, toolop = tool_op$ - 4
if tool_op$ > 38 & tool_op$ < 45, toolop = tool_op$ - 27
if tool_op$ > 106 & tool_op$ < 110, toolop = tool_op$ - 89
*ssurftype
pdrillcyc #Output drillcycle type note if canned cycle was programmed
if opcode$ = three,
if nextdc$ = three | nextdc$ = 7, drlgsel = fsg1(-ss$) + nextdc$ * two
else, drlgsel = fsg2(dwell$) + nextdc$ * two
if drlgsel > 15, #Custom canned cycle was programmed
custcycle = drlgsel - 7 #Shift it
"CUSTOM CYCLE ", 35, *custcycle
else, *sdrillcyc
pprm_0 #Run parameter table
if opcode$ = 1 | opcode$ = 2, pprm_1 #2D/3D Contour
if opcode$ = 4, pprm_4 #Pocket
if opcode$ = 5, pprm_5 #Ruled
if opcode$ = 6, pprm_6 #2D Swept
if opcode$ = 7, pprm_7 #3D Swept
if opcode$ = 8, pprm_8 #Revolution
if opcode$ = 9, pprm_9 #Loft
if opcode$ = 10, pprm_10 #Coons
if opcode$ = 13, pprm_13 #Surface Finish
if opcode$ = 14, pprm_14 #Surface Rough
if opcode$ = 19, pprm_19 #Face
pprm_1 #Output Parameters for 2D/3D Contour
"STOCK TO LEAVE (XY)= ", *stock, e$
"STOCK TO LEAVE (Z) = ", *zstock, e$
pprm_4 #Output Parameters for Pocket
"ROUGHING ANGLE = ", *rgh_ang, e$
"ROUGHING STEP SIZE = ", *rgh_step, e$
"NUMBER OF FINISH PASSES = ", *num_fin, e$
"FINISH PASS STEP SIZE = ", *fin_step, e$
"FINISH ALLOWANCE = ", *fin_stk, e$
pprm_5 #Output Parameters for Ruled
"STOCK TO LEAVE = ", *stock, e$
"ACROSS DISTANCE = ", *across, e$
pprm_6 #Output Parameters for 2d Swept
pprm_7 #Output Parameters for 3d Swept
"ALONG DISTANCE = ", *along, e$
"CUTTING DIRECTION: (0 = ALONG, 1 = ACROSS) = ", *cut_dir, e$
pprm_8 #Output Parameters for Revolved
"STEP SIZE = ", *fin_step, e$
pprm_9 #Output Parameters for Loft
"ALONG CUT DISTANCE = ", *along, e$
"ACROSS CUT DISTANCE = ", *across, e$
pprm_10 #Output Parameters for Coons
pprm_13 #Output Parameters for Msurf Finish
if tool_op$ = 132, #Surface High Speed
"STOCK TO LEAVE ON WALLS = ", *wall_stock, e$
"STOCK TO LEAVE ON FLOORS = ", *floor_stock, e$
"TOTAL TOLERANCE = ", *total_tol, e$
else,
"STOCK TO LEAVE ON DRIVE SURFACES = ", *drive_stock, e$
"STOCK TO LEAVE ON CHECK SURFACES = ", *check_stock, e$
"TOTAL TOLERANCE = ", *chdev, e$
#Parallel, Parallel Steep, Shallow, Leftover, Scallop or Blend
if tool_op$ = 11 | tool_op$ = 41 | tool_op$ = 42 | tool_op$ = 40 |
tool_op$ = 43 | tool_op$ = 109, "MAXIMUM STEPOVER DISTANCE = ", *fin_step, e$
if tool_op$ = 14, #Flowline
if use_across, "STEPOVER DISTANCE = ", *across_dist, e$
else, "SCALLOP HEIGHT = ", *across_height, e$
if tool_op$ = 15, "MAXIMUM STEPDOWN DISTANCE = ", *step_down, e$ #Contour
pprm_14 #Output Parameters for Msurf Rough
#Parallel or Plunge
if tool_op$ = 5 | tool_op$ = 44, "MAXIMUM STEPOVER DISTANCE = ", *rgh_step, e$
#Parallel, Restmill or Pocket
if tool_op$ = 5 | tool_op$ = 107 | tool_op$ = 10,
"STEPOVER DISTANCE = ", *rgh_step, e$
if tool_op$ = 8, #Flowline
pprm_19 #Output Parameters for Facing
ptool_details #Output requested tool details (20004, 20005, 20006, 20007 type)
# 20004 = tool definition - 'tool parameters' data
# 20005 = tool definition - 'DRILL type tool' parameters
# 20006 = tool definition - 'MILL type tool' parameters
# 20007 = tool definition - 'MILL type tool HOLDER' parameters
if opcode$ <> three, "NUMBER OF FLUTES = ", *tl_num_flutes, e$ #If NOT a canned cycle (drill) type toolpath
else, "DRILL TIP ANGLE = ", *tl_tip_angle, e$ # If IS a canned cycle (drill) type toolpath
"FLUTE LEN. = ", *tl_flute_len, e$
"OVERALL LEN. = ", *tl_overall_len, e$
"SHOULDER LEN. = ", *tl_shld_len, e$
"ARBOR DIA. = ", *tl_arbor_dia, e$
"HOLDER DIA. = ", *tl_holder_dia, e$
# Start of File and Toolchange Setup
ptimecalc #Convert 24-hour time format into 12-hour AM/PM format
if time$ >= 13, time2 = (time$ - 12)
else, time2 = time$
hour = int(time2), min = frac(time2)
*hour, ":", *min,
if time$ > 12, " PM"
else, " AM"
pheader$ #Call before start of file
if pst_rpd_fr$ <= 0, pst_rpd_fr$ = 300 #Make it greater than ZERO !
tmax_fr = fr_pos$ #Initialize (max fr used in current tool)
tmin_fr = fr_pos$ #Initialize (min fr used in current tool)
pmax_fr = fr_pos$ #Initialize (max fr used in program)
pmin_fr = fr_pos$ #Initialize (min fr used in program)
"X2-MR1 - MILL.SET rev10.16.06", e$
sepline2, e$
" ", e$ #Blank line
"PROGRAM NAME = ", *sprogname$, e$
if progno$ > zero, "PROGRAM NUMBER = ", *progno$, e$
#Date/Time output
#"DATE PROCESSED = ", month$, "-", day$, "-", year$, e$ #Date output as month,day,year - Ex. 02-12-05
"DATE PROCESSED = ", *smonth, " ", day$, " ", *year2, e$ #Date output as month,day,year - Ex. Feb. 12 2005
#"DATE PROCESSED (DD-MM-YY) = ", date$, " TIME(HH:MM) = ", time$, e$ #Date and time output Ex. 12-02-05 15:52
#"TIME = ", time$, e$ #24 hour time output - Ex. 15:52
"TIME = ", ptimecalc, e$ #12 hour time output 3:52 PM
pstock_info #Stock information output
psof0$ #Start of file for tool zero
psof$
psof$ #Start of file for non-zero tool number
psetup #Call for toolchange info output
sof = 0 #Reset start of file flag
!op_id$
ptlchg0$ #Call from NCI null tool change (tool number repeats)
!gcode$
if op_id$ <> prv_op_id$, ptlchg$
!op_id$
ptlchg$ #Tool change - Output of time calculations for the last tool run
if op_id$ = prv_op_id$, ex$
ptooldata #Total ending data for tool (Path Length and Times)
!op_id$
peof0$ #End of file for tool zero
peof$
peof$ #End of file for non-zero tool - Output of time calculations for the last tool and total time
#Supress Program totals if only one tool or no output selected
if tcnt > one & (fr_limits | xyz_limits | show_lengths | time_est),
" ", e$ #Blank line
sepline3, e$
"PROGRAM TOTALS (", *tcnt, " TOOLS):", e$
" ", e$ # Blank line
if fr_limits = two | fr_limits = three,
"FEEDRATES: MAX = ", *pmax_fr, " MIN = ", *pmin_fr, e$
#sepline, e$ #Output the separator '----' line
if xyz_limits = two | xyz_limits = three,
preadbuf1e #Read Buffer 1 (get X,Y,Z extents of entire program)
pMaxMin #Output Max/Min X,Y,Z coords for entire program
#Output Feed/Rapid path lengths
if show_lengths = two | show_lengths = three,
"TOTAL FEED CUT LENGTH = ", *llen_total, e$
"TOTAL RAPID TRAVERSE LENGTH = ", *rlen_total, e$
if time_est > 0 & (det_time = two | det_time = three),
ttltime = tot_rtime
"TOTAL RAPID TIME = ", ptimeout, e$
ttltime = tot_ltime
"TOTAL FEED TIME = ", ptimeout, e$
#Output Cycle Time information
if time_est = two | time_est = three,
ttltime = total #Transfer TOTAL program time
"CYCLE TIME: ", ptimeout, e$ #Program Total time output
psetup #Output of toolchange information
!gcode$
tcnt = tcnt + one #Tool Counter
if look4comp = one, preadbuf2 #Look for CDC settings @ Null tlchgs
else, #Load CDC setting for the current tool change
comp_cc = cc$ #Capture CDC in control setting
comp_cc_computer = cc_computer$ #Capture CDC in computer setting
comment$
if sof & outputxcom, #If start of file and outputxcom = yes$
if smachname <> snull, "MACHINE NAME = ", smachname, e$ #Machine name
if sgrpcomm <> snull, "GROUP COMMENT = ", sgrpcomm, e$ #Group comment
if sgrpname <> snull, "GROUP NAME = ", sgrpname, e$ #Group name
" ", e$ #Blank Line
"OPERATION TYPE = "
if tool_op$ = 16, "C-HOOK CREATED OPERATION", e$
else,
if tool_op$ = 132, "SURFACE HIGH SPEED - ", *shmm, e$
else, *sopnote, pdrillcyc, psurfop, e$
if output_comments & sopcomment <> snull, "OPERATION COMMENT = " sopcomment, e$ #Operation comment
"TOOL NAME = ", *strtool$, e$
if show_tool_mfg & strlen(stl_mfg_com) > zero & stl_mfg_com <> " ",
"TOOL DEF. (MANUFACTURER) = ", stl_mfg_com, e$
if show_chuck_name & strlen(stl_mfg_com) > zero & stl_mfg_com <> " ",
"TOOL DEF. (CHUCK) = ", stl_chuck_com, e$
"TOOL NUM. = ", *t$, e$
"TOOL DIA. = ", *tldia$, e$
if show_tool_details, ptool_details
if tcr$ > zero, "TOOL CORNER RAD. = ", *tcr$, e$
"DIA. OFFSET = ", *tloffno$, e$
"LEN. OFFSET = ", *tlngno$, e$
if ss$ = zero, "SPINDLE OFF", e$
if ss$ > zero, "SPINDLE = ", *ss$, e$
if ss$ < zero,
ss$ = abs(ss$)
"SPINDLE (*REVERSE*) = ", *ss$, e$
if fr_pos$ = zero, "*ERROR* - THE FEEDRATE WAS SET TO ZERO", e$
else, "FEEDRATE = ", *fr_pos$, e$
# Show Cutter Diameter Compensation settings
if opcode$ <> three & opcode$ < 13, #If NOT a canned cycle or surface machining, output CDC setting
if comp_cc = zero & comp_cc_computer = zero, "CUTTER COMP. = OFF", e$
if comp_cc <> zero & comp_cc_computer = zero,
"CUTTER COMP. (CONTROL) = "
if comp_cc = 41, "LEFT", e$
if comp_cc = 42, "RIGHT", e$
if comp_cc = zero & comp_cc_computer <> zero,
"CUTTER COMP. (COMPUTER) = "
if comp_cc_computer = 41, "LEFT", e$
if comp_cc_computer = 42, "RIGHT", e$
if comp_cc <> zero & comp_cc_computer <> zero,
if comp_cc = comp_cc_computer, "CUTTER COMP. (WEAR, IN CONTROL) = "
else, "CUTTER COMP. (REVERSE WEAR, IN CONTROL) = "
if result = 1, pprm_0 # Output 'additional parameter' information
#else, "*** NO ADDITIONAL PARAMETER' INFORMATION AVAILABLE ", e
llen = zero #Reset counter for next tool
rlen = zero #Reset counter for next tool
tltime = zero #Reset counter for next tool
trtime = zero #Reset counter for next tool
ttltime = zero #Reset counter for next tool
x$ = xh$, y$ = yh$, z$ = zh$
!x$, !y$, !z$, !fr_pos$ #Update previous [prv_?] variables
#Output Max/Min Feedrate used during prior toolpath
if opcode$ <> three & (fr_limits = one | fr_limits = three),
"FEEDRATES: MAX = ", tmax_fr, " MIN = ", tmin_fr, e$
#"MAX FEEDRATE IN TOOLPATH = ", tmax_fr, e
#"MIN FEEDRATE IN TOOLPATH = ", tmin_fr, e
if xyz_limits = one | xyz_limits = three,
preadbuf1t #Read the data from the Buffer 1
pMaxMin #Output Max/Min X,Y,Z coords during this tool operation
if show_lengths = one | show_lengths = three,
"TOOL FEED CUT LENGTH = ", *llen, e$
"TOOL RAPID TRAVERSE LENGTH = ", *rlen, e$
llen_total = llen_total + llen #Keep running total for Program
rlen_total = rlen_total + rlen #Keep running total for Program
if time_est > 0 & (det_time = one | det_time = three),
ttltime = trtime
"RAPID TIME = ", ptimeout, e$ #Time at RAPID RATE (for last tool)
ttltime = tltime
"FEED TIME = ", ptimeout, e$ #Time at FEEDRATE (for last tool)
pttltime #Total tool times
if time_est = one | time_est = three,
"OPERATION TIME = ", ptimeout, e$ #This operations time output
pthrminsec #Convert minutes to hr/min/sec format
thrs = int(ttltime / 60)
tmin = int(ttltime - thrs * 60)
tsec = (ttltime - thrs * 60 - tmin) * 60
pttltime #Total tool times and total program time
tot_ltime = tot_ltime + tltime #Total FEED time
tot_rtime = tot_rtime + trtime #Total RAPID time
ttltime = tltime + trtime #Calc. current Tool Time
total = ttltime + total + tlchgtime #Calc. total Program Time
ptimeout #Output "times"
#Output 'HOURS'
if thrs = one, *thrs, " HOUR, "
if thrs > one, *thrs, " HOURS, "
#Output 'MINUTES'
if tmin = one, *tmin, " MINUTE, "
if tmin > one, *tmin, " MINUTES, "
#Output 'SECONDS'
if tsec > zero, *tsec, " SECONDS"
ptimer #Rapid time and length calc
rlen = rlen + len #Running total RAPID length
trtime = rlen / pst_rpd_fr$ #Running total RAPID time
ptimel #Feed time and length calc
if fr_pos$ < zero, fr_pos$ = prv_fr_pos$
if fr_pos$ < tol, fr_pos$ = tol
llen = llen + len
tltime = tltime + len / fr_pos$
ptime #Distance calculations
dx = x$ - prv_x$
dy = y$ - prv_y$
dz = z$ - prv_z$
len = sqrt(dx^2 + dy^2 + dz^2)
if gcode$ = zero, ptimer #RAPID time and length calc
if gcode$ = one, ptimel #FEED time and length calc
if fr_limits, pfrcheck #Track MAX/MIN Feedrates if requested
pfrcheck #Track Feedrates (Max/Min)
if fr_pos$ > zero,
if fr_pos$ < tmin_fr, tmin_fr = fr_pos$ #Tool MIN
if fr_pos$ > tmax_fr, tmax_fr = fr_pos$ #Tool MAX
if fr_pos$ < pmin_fr, pmin_fr = fr_pos$ #Program MIN
if fr_pos$ > pmax_fr, pmax_fr = fr_pos$ #Program MAX
pstock_info #Output stock information if requested
if stock_info,
"MATERIAL TYPE = "
if stck_matl$ = "NONE" | stck_matl$ = "", "*NOT DEFINED*", e$ #No material type was selected
else, stck_matl$, e$
#" ", e$ # Blank line
if stock_info & tlplnno$ <= one, #ONLY if in TOP plane
#If any stock values are empty, disable don't output
if stck_ht$ > 0 & stck_wdth$ > 0 & stck_thck$ > 0,
"STOCK SIZE = ", stck_ht$, " ", stck_wdth$, " ", stck_thck$, e$
"STOCK ORIGIN = ", stck_x$, " ", stck_y$, " ", stck_z$, "(", *stknote, ")", e$
pMaxMin #Output Max/Min X,Y, Z coordinates
#Output MAX/MIN positions in the X,Y and Z axis
if X_limits = yes$, "MAX_X = ", *max_Xpos, " MIN_X = ", *min_Xpos, e$
if Y_limits = yes$, "MAX_Y = ", *max_Ypos, " MIN_Y = ", *min_Ypos, e$
if Z_limits = yes$, "MAX_Z = ", *max_Zpos, " MIN_Z = ", *min_Zpos, e$
# Motion NC output
prapid$ #Output to NC of linear movement - rapid
ptime
pzrapid$ #Output to NC of linear movement - rapid Z only
ptime
plin$ #Output to NC of linear movement - feed
ptime
pz$ #Output to NC of linear movement - feed Z only
ptime
# Parameter read postblocks:
pprep$ #Pre-process postblock
#Allows post instructions after the post is parsed but before the NC and NCI file are opened.
#DO NOT ATTEMPT TO OUTPUT TO THE NC FILE IN THIS POSTBLOCK (OR ANY POSTBLOCKS YOU MAY CALL FROM HERE)
#BECAUSE THE NC OUTPUT FILE IS NOT YET OPENED!
# rd_mch_ent_no$ = 0 #Read only the machine base parameters (use to collect common parameters from CNC_MACHINE_TYPE)
# rd_md$ #Read machine definition parameters
rd_cd$ #Read CD Parameters
#Output error message if Write NC operation information is not enabled in CD
if write_ops = 0, result = mprint(swriteopserror, 2) #Write NC Operation information MUST be enabled in CD
subout$ = 0 #Force output stream to NC file
comm_filter$ = 0 #Allow output of all comments
#sextnc$ = ".doc" #Uncomment and change extension here to override
#Force longhand drilling cycles for proper time estimate
usecandrill$ = no$ #Use canned cycle for drill
usecanpeck$ = no$ #Use canned cycle for Peck
usecanchip$ = no$ #Use canned cycle for Chip Break
usecantap$ = no$ #Use canned cycle for Tap
usecanbore1$ = no$ #Use canned cycle for Bore1
usecanbore2$ = no$ #Use canned cycle for Bore2
usecanmisc1$ = no$ #Use canned cycle for Misc1
usecanmisc2$ = no$ #Use canned cycle for Misc2
spaces$ = 0
eob$ = 0, prv_eob$ = 0
pwrtt$ #Pre-read NCI file
pwritbuf1 #Write MAX/MIN X,Y,Z values to Buffer 1
pwritbuf2 #Write COMP data to Buffer 2
!op_id$
pparameter$ #Read operation parameters
#rd_params is used to call pparameter postblock and read the parameters of the operation specified in rd_param_op_no
#"pparameter", ~prmcode$, ~sparameter$, e$
#Read tool definition data
if prmcode$ = 20002, stl_mfg_com = sparameter$ #'manufacturer' data
if prmcode$ = 20003, stl_chuck_com = sparameter$ #'chuck name' data
if prmcode$ = 20004, tl_number = rpar(sparameter$, 16) #'tool parameters' data
if prmcode$ = 20005, drl_cycle$ = rpar(sparameter$, 9) #'DRILL type tool' parameters
if prmcode$ = 20006, tl_cut_cap = rpar(sparameter$, 8) #'MILL type tool' parameters
if prmcode$ = 20007, tl_min_dia_plg = rpar(sparameter$, 11) #'MILL type tool HOLDER' parameters
result = fprm(opcode$) #Run the parameter table for current OPCODE
# Parameter lookup tables - You must adjust the size value if you add any parameters to these tables!
fprmtbl 1 2 #2D Contour
10010 stock #XY stock to leave
10068 zstock #Z stock to leave
fprmtbl 2 2 #3D Contour
fprmtbl 4 7 #Pocket
10301 rgh_ang #Roughing angle
10302 rgh_step #Roughing step size
10304 num_fin #Number of finish passes
10305 fin_step #Finish pass step size
10314 fin_stk #Finish allowance
fprmtbl 5 2 #Ruled
10010 stock #Stock to leave
12217 across #Across distance
fprmtbl 6 2 #2d Swept
12239 across #Across distance
fprmtbl 7 4 #3d Swept
12238 along #Along distance
12240 cut_dir #Cutting direction: 0 = along, 1 = across
fprmtbl 8 2 #Revolution
12054 fin_step #Step size
fprmtbl 9 3 #Loft
12238 along #Along cut distance
12239 across #Across cut distance
fprmtbl 10 4 #Coons
fprmtbl 13 13 #Multisurface Finish & HMM toolpaths
10010 drive_stock #Stock to leave on drive surfaces
10227 check_stock #Stock to leave on check surfaces
10204 chdev #Cut tolerance
10205 fin_step #Stepover distance
12411 step_down #Stepdown distance
12117 use_across #Use across cut distance (True/False)
12118 across_dist #Across cut: distance
12119 across_height #Across cut: scallop height
12302 fin_step #Finish blend max stepover
12628 hmm_type #High speed machining style
12665 wall_stock #High speed machining - stock to leave on walls
12666 floor_stock #High speed machining - stock to leave on floors
12593 total_tol #Total cut tolerance - High speed machnining
fprmtbl 14 10 #Multisurface Rough
10205 rgh_step #Stepover distance
12124 rgh_step #Restmill stepover distance
10302 rgh_step #Rough pocket stepover distance
fprmtbl 19 2 #Face
# Machine Definition Parameters
fprmtbl 17000 0 #Table Number, Size
# Param Variable to load value into
# Control Definition Parameters
fprmtbl 18000 1 #Table Number, Size
18171 write_ops #Enable write NC operation information
# Toolpath Group Parameters
fprmtbl 19000 0 #Table Number, Size
# Machine definition and control definition parameter capture:
pmachineinfo$ #Machine information parameters postblock
#rd_md is used to call pmachineinfo postblock and read the parameters of the selected axis
#combination machine entity set in rd_mch_ent_no
#rd_cd is used to call pmachineinfo postblock and read the active control definition parameters
#rd_tlpathgrp is used to call pmachineinfo postblock and read the active toolpath group parameters
#"-->pmachineinfo", ~prmcode$, " ", ~sparameter$, e$ #Do not uncomment if being called from pprep$ - see pprep comment
#Read parameter lookup tables -
#Leave lines below commented until you enter values in related lookup tables
#if prmcode$ >= 17000 & prmcode$ < 18000, result = fprm(17000) #Run the parameter table for Machine Definition Parameters
if prmcode$ >= 18000 & prmcode$ < 19000, result = fprm(18000) #Run the parameter table for Control Definition Parameters
#if prmcode$ >= 19000 & prmcode$ < 19900, result = fprm(19000) #Run the parameter table for Toolpath Group Parameters
# Buffer 1 definition (for Max/Min X,Y,Z storage)
rc1 : 2 #Buffer1 READ pointer (YES, '2' is correct for this case!)
wc1 : 1 #Buffer1 WRITE pointer
size1 : 0 #To hold 'size' of Buffer 1
b1_gcode : 0 #Stored in Buffer #1
b1_tcode : 0 # "
b1_xmax : 0 # "
b1_xmin : 0 # "
b1_ymax : 0 # "
b1_ymin : 0 # "
b1_zmax : 0 # "
b1_zmin : 0 # "
fbuf 1 0 8 0 0 #Declare Buffer1 to hold Min/Max X,Y,Z axis info.
# Buffer 1 Read / Write Routines
pinit #Initialize the limit checking variables
max_Xpos = m_c9k #Initialize
min_Xpos = c9k # "
max_Ypos = m_c9k # "
min_Ypos = c9k # "
max_Zpos = m_c9k # "
min_Zpos = c9k # "
plimits #Check for NEW X,Y,Z limits
if b1_xmax > max_Xpos, max_Xpos = b1_xmax
if b1_xmin < min_Xpos, min_Xpos = b1_xmin
if b1_ymax > max_Ypos, max_Ypos = b1_ymax
if b1_ymin < min_Ypos, min_Ypos = b1_ymin
if b1_zmax > max_Zpos, max_Zpos = b1_zmax
if b1_zmin < min_Zpos, min_Zpos = b1_zmin
pwritbuf1 #Write Buffer 1
b1_gcode = gcode$
if gcode$ = 1002 & op_id$ = prv_op_id$, b1_gcode = 1000
if gcode$ = 1000 & op_id$ <> prv_op_id$, b1_gcode = 1002
b1_tcode = t$
b1_xmax = x_max$
b1_xmin = x_min$
b1_ymax = y_max$
b1_ymin = y_min$
b1_zmax = z_max$
b1_zmin = z_min$
b1_gcode = wbuf(one, wc1) #Write the record
preadbuf1t #Read Buffer 1 (at the toolchanges for X,Y,Z limits)
b1_gcode = rbuf(one, rc1) #Read a record from the Buffer
plimits #Check for NEW limits
#Loop thru possible NULL toolchanges
while b1_gcode = 1000, #Find the next NON-NULL toolchange
b1_gcode = rbuf(one, rc1) #Read the next record from the Buffer
preadbuf1e #Read Buffer 1 (at the END of Program for X,Y,Z limits)
size1 = rbuf(one, zero) #Get the size of the Buffer 1
rc1 = two #Reset read pointer (SKIP 1st record!)
while rc1 <= size1, #Loop thru entire program
# Buffer 2 definition (for CDC settings storage)
rc2 : 1 #Buffer2 READ pointer
wc2 : 1 #Buffer2 WRITE pointer
size2 : 0 #To hold 'size' of Buffer 2
b2_gcode : 0 #Data stored in Buffer 2
b2_ccomp : 0 #Data stored in Buffer 2
b2_cc : 0 #Data stored in Buffer 2 (comp. in control setting)
b2_cc_computer : 0 #Data stored in Buffer 2 (comp. in computer setting)
fbuf 2 0 4 0 0 #Declare Buffer2 to hold cutter dia. comp. settings
# Buffer 2 Read / Write Routines
pwritbuf2 #Write Buffer 2
b2_gcode = gcode$
if gcode$ = 1002 & op_id$ = prv_op_id$, b2_gcode = 1000
if gcode$ = 1000 & op_id$ <> prv_op_id$, b2_gcode = 1002
b2_ccomp = ccomp$
b2_cc = cc$
b2_cc_computer = cc_computer$
b2_gcode = wbuf(two, wc2) #Write the record
preadbuf2 #Read Buffer 2 (at the toolchanges for cutter comp setting)
#Reset flags
comp_cc = zero
cdc_found = no$
tool_end = no$
b2_gcode = rbuf(two, rc2) #Read a record from the Buffer
if b2_cc <> zero | b2_cc_computer <> zero, #Tool change has active CDC
cdc_found = yes$
comp_cc = b2_cc
comp_cc_computer = b2_cc_computer
while b2_gcode = 1000, #Find the next NON-NULL toolchange
b2_gcode = rbuf(two, rc2) #Read the next record from the Buffer
if cdc_found = no$, #There was NO CDC setting on the toolchange
if b2_cc <> zero | b2_cc_computer <> zero, #Null tlchg has active CDC
cdc_found = yes$ #Report the CDC from the Null tlchg
comp_cc = b2_cc
[CTRL_TEXT_END]
AH - HA !
I just did a little experimental copy-paste from an actual post into the mill.set...
Seems to work OK now.
sepline2, e$
" ", e$ #Blank line
<<<<ADDED THIS LINE>>>>sopen_prn, "MCX FILE - ", *smcpath$, *smcname$, *smcext$, sclose_prn, e$<<<<>>>>
#Date/Time output
psof$
