BASIC programming help needed
hordur
My machine (Okuma Multus B400) reads BASIC code within the NC-file and i would like to add some if/else features to a program in order to make the same program fit multiple similar details
i want it to skip a part of the nc-file if i specify it in the beginning of the file, aswell as setting a variable for detail thickness (for program origo correction)
i can use the below mentioned code to automaticly set the origo, and i can add a function to it too (as illustrated), but is the below code correct?
NUM=45
VZOFZ=25209.767+NUM
result:
VZOFZ=25209.767+45
i have done some basic scripting previously and im completely lost when it comes to code, so i would greatly apreciate any help on the topic smile.gif
to clarify,
at the end of the "generic" program there is drilling and threading thats used on some of the pieces, and on some there´s none.
So i would like to add something like:
Drill yes/no= YES (not skip block N1650 and forward)
at the start of the program, aswell as setting the above mentioned thickness of the detail.
I figure i could add a function something like:
N001 DRILL=YES
N1649 IF Drill=yes goto N1651
N1650 ELSE M02 (program end)
N1651 DRILL program
All other parameters and functions are the same for numerous programs, and instead of tweaking 10 almost identical programs, it would ease my day ALOT if i could only do it once smile.gif
Okuma's read Okuma User Task II not basic.
NUM=45
VZOFZ=25209.767+NUM
result:
VZOFZ=25209.767+45
Yes that will work.
You can also use mathematical functions as well
O1
RA=18 (PART CORNER RADIUS)
RB=8 (CUTTER NOSE RADIUS)
RC=RA+RB (CUTTER PATH RADIUS)
LEN=200 (PART LENGTH)
ANG=5 (INCREMENTAL ANGLE)
REND=90 (RADIUS END)
VC100=ANG
N1
G0 X500 Y500 Z500
T1 M6
S3000 M3
G56 H1
F3000
G00 X=RB+2 Y0 Z0
NLOOP G01 X=-LEN-RB F3000
G00 Z=0+2
X=RB+2
IF [VC100 GT REND ]NEND
Y=[sIN[VC100]*RC] Z=[-RC+[COS[VC100]*RC]]
VC100=VC100+ANG
GOTO NLOOP
NEND
G00 Z500
M2
N001 DRILL=YES
N1651 DRILL program
I would use,
DRLL=1
N1649 IF [DRLL EQ 1] N1651
N1650 M02 (program end)
N1651 (SUB PROGRAM)
We have one Okuma in the shop, and it is a lathe. Other lathe programmer does the programming for it, but I was able to follow your code. I do get to play with it once in a blue moon. smile.gif
Been teaching myself Macro B programming (Fanuc controls). I didn't think MC could handle this type of programming, but I'm not so sure now after reading this thread.
Looks like it could be done. How do I go about modifying my post for this type of programming? Should I even give it a try? Is it already possible, and I just don't know how to use it? I've done some post modifying, but am not anywhere close to being in the same league as most of the guys posting here.
I think one of the things holding me back from learning more is that I only program for lathes. Plus I don't have much time at work for playing with MC. Always plenty of other work that needs doing.
Also, I would love to learn how to use cantext like I see it being used here.
I am not so sure a Mastercam post can output this style of code.
Here is a simple macro I use all of the time. It will machine the code in this case every 45 degrees
( TOOL - 10 OFFSET - 10 )
( CROSS CONTOUR 3.5 X R0.5 SLOT DRILL )
( ROUGH SLOTS )
N56 G0 X500. Z500.
N57 M110
N58 G138
N59 T101010 SB=2500 M13
N60 V1=0
N61 M15
N62 M08
N63 G00 Z7.371 C0
N64 X22.
NLOOP
N65 C=V1
N66 X20.05
N67 G94 G1 X19.05 F100.
N68 Z-1.079
N69 X18.8 Z-6.35
Blah Blah
N86 Z1.021
N87 G0 X22.
N88 V1=V1+45
N89 IF [V1 LT 360] NLOOP
N90 M02
And another to rotate a shape around a shaft as a sub program
OEND1
( LB4000-EX-M-ISSA .MIN )
( 12. BALL ENDMILL )
( CUT END FORM )
NAT2
M110
G0 X800. Z300. T1010
SB=4200 M13
M8
VZSHC=0
V10=0
NHERE
VZSHC=VZSHC+36
V10=V10+1
G0 X120 Z6.
C100. M16
G18
G94 G1 X63.5 C100. F2000.
Z-55.25 C10. M16 F1200.
G0 X73.
X120.
Z6. C80.
X73.
G1 X63.5 F2000.
Z-55.25 C170. M15 F1200.
G0 X73.
X120.
Z6. C100.
IF [V10 LT 10] NHERE
M12
M9
G95
M109
G0 X800.
Z300.
VZSHC=0
T1000
RTS
Thank you guys for that VERY helpful examples!
I would very much like to study up on the topic, but google only returns crap.. does anyone know any online guides/faq´s/reference libraries for me to read up on?
i will probably implement thease functions as stand alone textfiles and manual input, read from file thru mastercam, as i do now with machine origo and so on, and i might be able to modify the post to use misc ops to output correct "flags" for exclude-able operations.
I will need to investigate this further tho, dont want to do boo-boo.. smile.gif
You have many choices for varialble use on an okuma, Greg gave you some great examples.
The RA and RB he is using are local variables they are in the program itself, the V1 variable he is using is a variable outside the program that any program can use you can mix and match
Like RA EQ V1 so you can adjust from outside the main program so many choices with user task 2
