Adding G05.1 to MPfan based post.
Bruce Caulley
Ahoy! I posted this in the off topic section by mistake.
I have searched and read up on a couple of threads related to this, but my post does not have the phsmon and phsmoff blocks. I am also a little hampered by an 18 month "holiday" from MC so the limited post tweaking abilities I did have are all but gone.
I have put:
if mi4$=1, n$, "G05.1 P1", e$
!mi4
in Psof$ and have setup mi4 as needed. This is working great to turn it on, but I am having trouble with the placement of:
if mi4$=1, n$, "G05.1 P0", e$
!mi4
in the correct place.
I want it on the line before the Z retract at the end of the op, but cannot for the life of me find the correct spot.
I also know I will need to do some logic to check previous value for mi4, but will try and plod through that myself before asking. [big Grin]
Any help appreciated.
Bruce
But with that said... for certain reasons I won't go into right now...I had to add this to an MPFAN post today. I robbed the logic and associated stuff from MPMaster and it took me about 20 minutes.
If the G05.1 is the only look ahead you're going to use and you want it automatically with no misc integer call...
Add a variable;
g05_1_flg   : 0      #Flag to indicate G05.1 look ahead function is active
Add a couple postblocks;
pg05_1_on         #G05.1 function on
if opcode$ = 3 | opcode$ = 16,
if g05_1_flg = 1, pg05_1_off
else, if g05_1_flg <> 1,
pbld, n$, "G05.1", "P1", e$
g05_1_flg = 1
pg05_1_off #G05.1 function off
if g05_1_flg = 1,
pbld, n$, "G05.1", "P0", e$
g05_1_flg = 0
Search for all of your "G43" codes and add this in the line before;
      pg05_1_on
Add it also in ptlchg0$. The location is going to vary here depending on your post, I would try in the line before
..., pfcout, pfxout, pfyout,...
Turn it off in ptoolend$ and peof$
ptoolend$        #End of tool path, before reading new tool data
!speed, !spdir2
if nextop$ = 1002, pg05_1_off
peof$ #End of file for non-zero tool
pg05_1_off
pretract
I thinks that is all you need.
