text from solid works???
buck30
yesterday i got a "flat pattern" to be programerd. It was drawn in solidworks. It is a simple contour around a diameter. So simply did a contour using the rotary axis and substiation in Y. No problem. However this pattern also had some text. chaining the pattern was no problem however trying to chain the text was another thing. Seems like it was not recognized in any way. I was able to delete it and create my own text in mastercam. So why and how does one make this work??? Chaining the solidworks text i mean.
TIA
Breaking it may not be enough to make a toolpath from the text. Yes you must "Break" it first, but if you pull a box around it to select it all, MC may still not path it. If that occurs pull a box around it again, but also select the "3D" option button and it should work. I have encountered this issue with 2d drawings as well.
