Work Offset
Graphite Master
You sure?, works here
Open Mastercam=>Machine Type=>(Your selection)=>Settings=>Control definition manager=>Operation Defaults=>(Your selection)”Pocket”=>Parameters=>Planes=>Check Workoffset, input number=>”Green Check mark”=>”Green Check mark”=>Save(Disk icon)=>”Green Check mark”=>Yes=>”Green Check Mark”=>Exit Mastercam=>Save File to Desktop=>Delete File on Desktop=>Open Mastercam normally.
When setting your views and origins in "view manager"- goto Work Offset and place the number you require in this field
This number will be recalled when this view is used - you will also find this number will be shown at the end of the parameter line in each operation if greater than ( -1 )
If using different work numbers for the same set-up i.e.
set w/off# in view manager to TOP=1, FRONT=2, BACK=-1
WCS=TOP Tplane=TOP w/off #1 - outputs #1
WCS=TOP Tplane=FRONT w/off #2 - outputs #2
WCS=TOP Tplane=BACK w/off #-1 - outputs #1(by default)
This is not a permanent setting for Mastercam only for this file
If it is required as a permanent setting, your post will require adjusting, quite often "Misc Intergers #1" is used forthis feature mod.
