.SS FILES
CEMENTHEAD
You should be able to do that…
Load up your SET file in a text editor (Mastercam Edit, CimcoEdit, etc)
You will want to add a line into the pprep$ postblock.
I added the spathnc$ line just below the existing #sextnc$ line, like this ->
      comm_filter$ = 0   #Allow output of all comments
#sextnc$ = ".doc" #Uncomment and change extension here to override
spathnc$ = "S:RMartinSupport" # Override the default output path! <*** NEW ***>
#Force longhand drilling cycles for proper time estimate
usecandrill$ = no$ #Use canned cycle for drill
Note - S: in the above example is a mapped network drive/folder.
You can specify a UNC type network path, like this ->
spathnc$ = "nServersharedRMartinSupport"
*Also, don’t forget the final trailing backslash on the path!
Now all the .DOC files that are produced by this Mill.SET Setup Sheet generator end up in that folder. smile.gif
