x4 post miss erro
thanhsonnguyen
i'm have some line miss i'm don't know what line... my debugger notworking i'm can't check it, can you help me out with this thanks out time
17 Jun 2009 08:52:17 AM - <2> - The post product type is Mill.
17 Jun 2009 08:52:17 AM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.
17 Jun 2009 08:52:17 AM - <2> - Search for defined post variables, strings, postblocks was successful.
17 Jun 2009 08:52:18 AM - <2> - PST LINE (849) - The start string is missing
17 Jun 2009 08:52:18 AM - <2> - PST LINE (2142) - Label has not been defined[26]
17 Jun 2009 08:52:18 AM - <2> - PST LINE (2202) - Label has not been defined[26]
17 Jun 2009 08:52:18 AM - <2> - PST LINE (2219) - Label has not been defined[27]
17 Jun 2009 08:52:18 AM - <2> - PST LINE (3396) - Label has not been defined[26]
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'ltol$' was re-initialized from 0.0005 to 0.002
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'minarc$' was re-initialized from 0.0005 to 0.002
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'helix_tol$' was re-initialized from 0.0005 to 0.0001
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'met_helix_tol$' was re-initialized from 0.005 to 0.001
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'atol$' was re-initialized from 0.5 to 0.01
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'err_file$' was re-initialized from 0. to 2.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'bldnxtool$' was re-initialized from 0. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'nobrk$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'nobrkxz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'nobrkyz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'lnobrk$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'lnobrkxz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'lnobrkyz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'arcoutput$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'arcoutputxz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'arcoutputyz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'larcoutput$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'larctypexz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'larcoutputyz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'breakarcs$' was re-initialized from 0. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'breakarcsxz$' was re-initialized from 0. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'breakarcsyz$' was re-initialized from 0. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'lbreakarcs$' was re-initialized from 0. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'lbreakarcsxz$' was re-initialized from 0. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'lbreakarcsyz$' was re-initialized from 0. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'do_full_arc$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'do_full_arcxz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'do_full_arcyz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'ldo_full_arc$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'ldo_full_arcxz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'ldo_full_arcyz$' was re-initialized from 1. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'arccheck$' was re-initialized from 111. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'larccheck$' was re-initialized from 111. to 1.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed4$' was re-initialized from 2. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed5$' was re-initialized from 3. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'lrotfeed4$' was re-initialized from 2. to 0.
17 Jun 2009 08:52:18 AM - <2> - CONTROL DEFINITION - - Post variable 'sub_level$' was re-initialized from 0. to 0.
17 Jun 2009 08:52:18 AM - <2> - Successful completion of posting process!
You may want to contact your reseller unless you are familiar enough with post syntax and editing.
If you want to make a go on your own, here are my thoughts.
error on line 849 - This probably a problem with your string selector if you don't know what a string selector is, then you have a problem. I'm betting the string variable that represents the start variable for the string selector array is either missing or commented out both of which are wrong.
The remaining 4 postline errors (2142, 2202,2219, 3396) are caused because there is a user defined variable that hasn't been defined/declared. Most likely someone commented out the variable definition/declaration statement. Again, if you don't know what this means, contact your reseller.
Everything else in the file is just informational and can be ignored. I'm sure the problems are very, very simple to address if you have the post background.
