outpur r with g96
88Matt
# Toolchange / NC output Variable Formats
fmt T 7 toolno #Tool number
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
fmt S 4 maxss$ #RPM spindle speed
fmt N 4 n$ #Sequence number
fmt X 12 xabs #X position output #drr was 2
fmt Z 12 zabs #Z position output #drr was 2
fmt U 3 xinc #X position output
fmt V 3 yinc #Y position output
fmt W 3 zinc #Z position output
fmt I 3 iout #Arc center description in X
fmt J 3 jout #Arc center description in Y
fmt K 3 kout #Arc center description in Z
fmt R 2 arcrad$ #Arc Radius
fmt R 12 css_r #css start position #lmr added line test
fmt F 18 feed #Feedrate
fmt P 11 dwell$ #Dwell
fmt M 5 cantext$ #Default cantext
pcss #Output Constant surface speed
speed = g_speed
if css_actv$, pbld, n$, *sg9697, *speed, spindle_l, pfcss_r, pfxout, !css_actv$ e$ #lmr pfxout is added just for reference
!speed
pfcss_r #css start position #lmr added block
*css_r
gives me
N10 G20 G90 G08
N20 G0 X20. Z20.
N30 G97 S100 M03 M62
N40 G0 X7.6372 Z10. M8
N50 G92 S320
N60 G96 S200 R0. X7.6372 #<<<<<<<need this line to read G96 S200 R7.6372
How do I get the current x position to post with an R.
Thank you in advance for your help.
Matt
There are a couple of ways to achieve this but it depends on what you want to happen from a modality standpoint. for the example above we can get it to output R7.6372 now the next line has the same X, does X need to come out again as X7.6372 or should there be no X.
Modality in tact (in the example above no X on the second line if the same as R) - If you want modality to stay in affect then learn to use the nwadrs function. This function allows you to change the address string so the new string address gets output when a variable is output. So you could actually use nwadrs to give say xabs a string of R and then after the output use nwadrs to change it back to X. By using the same output variable and just changing the string address modality stays in tact. This requires that you have string variables defined for both R and X and you use the nwadrs function before and after the output to change and reset respectively. there is much more to this because of accounting for Absolute and incremental that once again if this doesn't make much sense, let your reseller or someone with post experience make the changes.
Here is an example but I can't guarantee it will work in your post (The example below assumes strr and strx have been defined appropriately. Notice I removed the call to pfxout from the pcss postblock as well. The call to output was moved to the pcss_r postblock instead).
speed = g_speed
if css_actv$, pbld, n$, *sg9697, *speed, spindle_l, pfcss_r, !css_actv$ e$ #lmr pfxout is added just for reference
!speed
pfcss_r
#Based on ABS/INC output change the address of appropriate variable from X to R
if absinc$ = zero, result = nwadrs (strr, xabs) #Absolute output
else, result = nwadrs (strr, xinc) #incremental output
pfxout #Call to output X
result = nwadrs (strx, xabs) #reset back to X address
result = nwadrs (strx, xinc) #Reset back to X address
If you don't want to keep modality in tact, then you can just assign the current value into the css_r variable like so
   css_r = xabs
Ofcourse the above won't work completely because you have to account for outputting in Absolute (xabs) or incremental mode (xinc). You would need to add more logic for the above to work correctly. Something like this (you would also need to remove pfxout from the pcss postblock otherwise you would get R7.6372 X7.6372 on the same line).
  pfcss_r
if absinc$ = zero, css_r = xabs
else, css_r = xinc
*css_r
If none of this makes much sense, that should be a sign to contact your reseller for help so someone with post experience can make the change for you. If you don't understand the basic rules of posts you will just get deeper into trouble trying to make this modification. ALWAYS BACK UP YOUR POST BEFORE MAKING ANY MODIFICATIONS - yes I'm yelling.
