Errors
Rob_Bish
Could someone guide me in the right direction to sort these out please?
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'met_mtol$' was re-initialized from 0.001 to 0.0001
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'ltol$' was re-initialized from 0.00001 to 0.01
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'met_ltol$' was re-initialized from 0.00001 to 0.01
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'omitseq$' was re-initialized from 0. to 1.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'arccheck$' was re-initialized from 0. to 1.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'larccheck$' was re-initialized from 0. to 1.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed4$' was re-initialized from 2. to 0.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed5$' was re-initialized from 3. to 0.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'inversefeed$' was re-initialized from 0. to 1.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'lrotfeed4$' was re-initialized from 2. to 0.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'linversefeed$' was re-initialized from 0. to 1.
23 Jun 2009 05:20:55 PM - <2> - CONTROL DEFINITION - - Post variable 'peckacel$' was re-initialized from 0. to 1.
The information you provide is fine, no errors, just information notes. Basically it is jsut informaing you that settings in the Control Defintion are being used instead of the initial values set in the post. Basically CD always wins.
If when posting Mastercam tells you you have errors, then you need to post the entire contents of the .ERR file and there should be some errors listed in it.
Here you go thank goodness i'm off to Spain for a long weekend tomorrow. lol
24 Jun 2009 07:38:34 AM - <0> - Report created.
24 Jun 2009 07:38:34 AM - <2> - Initialize posting log file
24 Jun 2009 07:38:34 AM - <2> - Using MP run version 13.00 and post components version 10.00
24 Jun 2009 07:38:34 AM - <2> - Initiate opening the post processor file(s).
24 Jun 2009 07:38:35 AM - <2> - Post processor file name: C:MCAMX4YASDAH30I.PST
24 Jun 2009 07:38:35 AM - <2> - An encrypted post file is associated with the .pst file.
24 Jun 2009 07:38:35 AM - <2> - Post processor file name: C:MCAMX4YASDAH30I.PSB
24 Jun 2009 07:38:35 AM - <2> - The post processor file has finished the read process.
24 Jun 2009 07:38:35 AM - <2> - Post version information (input):
24 Jun 2009 07:38:35 AM - <2> - UPDATEPOST Version 13. was used to modify this file.
24 Jun 2009 07:38:35 AM - <2> - The file was modified by this product on 19 Jun 09 15:50:56
24 Jun 2009 07:38:35 AM - <2> - The post was written to run with Mastercam Version 13.
24 Jun 2009 07:38:35 AM - <2> - The post product type is Mill.
24 Jun 2009 07:38:35 AM - <2> - Initialization of pre-defined post variables, strings, postblocks was successful.
24 Jun 2009 07:38:35 AM - <2> - Search for defined post variables, strings, postblocks was successful.
24 Jun 2009 07:38:37 AM - <2> - RUN TIME - - Negative tool numbers not allowed in tooltable.
24 Jun 2009 07:38:37 AM - <2> - RUN TIME - - The post is not configured to support nested subprograms! Nested subs are ignored in output.
24 Jun 2009 07:38:37 AM - <2> - RUN TIME - - File error reading NCI file.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'met_mtol$' was re-initialized from 0.001 to 0.0001
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'ltol$' was re-initialized from 0.00001 to 0.01
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'met_ltol$' was re-initialized from 0.00001 to 0.01
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'dec_seq_right$' was re-initialized from 3. to 0.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'omitseq$' was re-initialized from 0. to 1.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'arccheck$' was re-initialized from 0. to 1.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'larccheck$' was re-initialized from 0. to 1.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed4$' was re-initialized from 2. to 0.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'rotfeed5$' was re-initialized from 3. to 0.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'inversefeed$' was re-initialized from 0. to 1.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'lrotfeed4$' was re-initialized from 2. to 0.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'linversefeed$' was re-initialized from 0. to 1.
24 Jun 2009 07:38:37 AM - <2> - CONTROL DEFINITION - - Post variable 'peckacel$' was re-initialized from 0. to 1.
24 Jun 2009 07:38:37 AM - <2> - RUN TIME (QUESTION) Enter part number ? - OPERATION 1 NCI LINE 94.
24 Jun 2009 07:38:37 AM - <2> - RUN TIME (RESPONSE) jh - OPERATION 1 NCI LINE 94.
24 Jun 2009 07:38:37 AM - <2> - RUN TIME (QUESTION) Enter subprogram start number? - OPERATION 1 NCI LINE 94.
24 Jun 2009 07:38:37 AM - <2> - RUN TIME (RESPONSE) 0. - OPERATION 1 NCI LINE 94.
24 Jun 2009 07:38:37 AM - <2> - Successful completion of posting process!
