5 axis swarf problem
sharles
I'm trying to cut a seal groove that isn't flat (it starts out flat, then goes up an angled surface then is flat at the top for awhile until it goes back down the angled surface on the other side, gets back to the flat and finishes). I have to cut it with an endmill so that the bottom is as flat as possible so I'm using a swarf program.
The post should really only need to set the C axis at 90 degrees and then after that the tool should move only in X,Y,Z and B. Unfortunately the program is "dancing" around in the C axis. I'm guessing it has something to do with the surfaces I'm using not being perfectly vertical, but is there some way I can set the post or parameters to lock the C axis at 90 degrees and stay there for the rest of the program? I'd only want it to be for this program (not a permanent post edit...and I can't change the post itself because it's locked).
I typically create curves making certain the endpoints are aligned to produce only an axis movement on which you want then sync by entity.
Oh and using entities, you have to have the same number of entities on the top control chain as the bottom. Then it will swarf from endpoint of each upper/lower line to endpoint throughout the chain.
