Buffer help
Acro Engineering
I think buffers are the only way to get this to work? Output needs to look like this:
X, Y, Bow, Feedrate
Bow is a calculation TAN of sweep/4 but for the next move...
Feedrate is the feed and offset of the next move, negative for left positive for right...
Here is my current code:
# Buffer Functions
rc1 : 1
wc1 : 1
size1 : 0
gcode_1 : 0
ccomp_1 : 0
x_1 : 0
y_1 : 0
sweep_1 : 0
fr_1 : 0
fbuf 1 0 6 0 0
# POSTLINES
pfr # Feedrate
if fr$ = -1, fr$ = prv_fr$
if fr$ = -2, fr$ = zero
quality = fr$
if ccomp$ = 2, neg_feed = 1
if neg_feed = 1, quality = -quality
if ccomp$ = 4, neg_feed = 0
*quality
!fr$
# Buffer Read / Write
pwritbuf1 # Write buffer number 1
gcode_1 = gcode$
ccomp_1 = ccomp$
x_1 = x$
y_1 = y$
sweep_1 = sweep$
fr_1 = fr$
gcode_1 = wbuf(one,wc1)
preadbuf1 # Read buffer number 1
gcode_1 = rbuf(1,rc1)
gcode$ = gcode_1
ccomp$ = ccomp_1
x$ = x_1
y$ = y_1
sweep$ = sweep_1
fr$ = fr_1
preadnext # Read buffer number 1
gcode_1 = rbuf(one,rc1)
preadbuf
size1 = rbuf(one,zero)
preadbuf1
preadnext
if gcode_1 > one, bow = tan(sweep_1/four)
else, bow = zero
rc1 = rc1 - 1
if gcode$ = zero, prapidout
if gcode$ = one, plinout
if gcode$ > one, pcirout
preadlast
preadbuf1
bow = zero
# Axis linear/circular motion
prapidout # Linear line movement - at rapid feedrate
*x$, *y$, *bow, pfr, e$
plinout # Linear line movement - at feedrate
prapidout
pcirout # Circular interpolation
prapidout
# POSTLINES, PRE-DEFINED
pheader$ # File header
psof0$ # Start of file for tool zero
psof$
psof$ # Start of file for non-zero tool
ptlchg0$ # Null tool change
ptlchng$
ptlchg$ # Tool change
peof0$ # End of file for tool zero
peof$
peof$ # End of file for non-zero tool
size1 = rbuf(1,0)
while rc1 < size1, preadbuf
if rc1 = size1, preadlast
# Axis motion
prapid$ # Linear line movement - at rapid feedrate
pwritbuf1
!x$, !y$
plin$ # Linear line movement - at feedrate
prapid$
pcir$ # Circular interpolation
prapid$
Now for the problems:
1. If selecting approach or retract positions I can't get them output to the NC code? They are in the NCI... I don't think the buffer is getting them?
The code is assembled as such:
X, Y, Bow, FeedRate
Bow is calculated, Tan of Sweep/4. Bow is output on the line previous to the arc move...
FeedRate is negative for left offset and positive for right offset. FeedRate is output on the line previous to the move...
2. I can't get the feedrate for the next move on the line previous, somehow I got it to work for bow but can't get feedrate to work?
Is there a way to retrieve next line information from the NCI without using buffers?
I figured out how to get my approach point but do have a question to set my if statements...
What variables are used for approach = true and retract = true? Here is what I want:
psof$
if approach = true,
pwritbuf1
pretract
pwritbuf1
peof$
if retract = true, pretract
size1 = rbuf(1,0)
Still trying to figure out how to get my feedrates backed up a line?
I did the keep bit to read the buffer... I think I have everything working now with the buffer method but would love to go a step further and try the variable method...
ak762,
I think what your saying is to save the NCI line to variables like prvx, prvy, etc then run the next line and output prvx and prvy on that line?
it is similar as look ahead at one step of next move
you will find description in MP postprocesor reference guide
it my favorite approach when I try to catch next x y z movement for special purpose
