Program Help?
Dontlietomeman
I am using a 6" Diamond wheel to grind High Purity Quartz glass.
I need to mill:
x7, y0, z0.
x7, y0, z-1. then
x7.01, y0, z0.
x7.01, y0, z-1. then
x7.02, y0, z0.
x7.02, y0, z-1.
It seems simple enough. banghead.gif But I want to use cutter comp to change the x7. number to a differnt number, say x7.002 or x7.004 so that the operator can use cutter comp. to change the final size.
Thanks for any help
Carl Matthews
Fadal VMc 8030
Mastercam Mill Level 3
Tosoh Quartz
Thats kind of a wierd one for me Carl. Plunging in Z while advancing in Y with cutter comp on so that it affects Y.
If I was doing this, I'd program the numbers just like you have and then measure the cut and adjust the offset Y number to get the result I need.
Sounds like very interesting work. All I've ever cut is metal.
HTH.
