Simple Brass Machining Question
BBOwen
Guys I am not a machinist, so I need advice.
My boss has me machining some brass kick plates on the GR-510 router.
I want to use a high speed 2d path if possible.
The stock needs a 2.25" wide X .125" deep pocket around the outside.
I am using a 3/4" carbide endmill and a kool mist.
What speed and feeds would you guys use on this?
I haven't machined brass in years and it is tough to say with machine and workholding factors but.......... I did some calculations and I think you should start around.
2667 rpm and 21 IPM
you could always speed it up/slow it down judging by how it sounds.
[ 07-22-2009, 11:09 AM: Message edited by: Michael Sullivan @ Blackhawk Mgmt ]
If it's 360 you don't need the mist, and air blast will be fine. With a carbide cutter 650 to 1000sfm is good. I use 3flt cutters for AL from Imco that seem to last forever. With a .03corner rad you can run a .5" cutter at 7500 and 80+ipm (I'v pushed them as high as 120ipm. For the harder stuff cut those numbers in half and use mist or flood. I have found that the harder brass loves to heat up and heat the cutter too. 360 puts the heat into the chip.
Use a smaller tool!!! That 3/4" tool will probably grab the material and bend it inless you play musical clamps all the way around.
At .125 thick you could use a 5/16" 2flt. end mill and just contour it.
Your machine and how well you are holding the material will determine what you run at. Remember, Speeds & Feeds are more related to tool life than anything.
