Small Arc Problem
GREG
Ive imported a DXF into Mcam. Its an engraving emblem with small arcs everywhere.Rad 0.19mm
Mcam displays these arcs as a zigzag and not a curve although they analyze OK.If I draw an arc it comes out the same.Im also having lots of probs with the tool path.(cutter comp not sucssesfull).Chain analyzes OK.
In a new drawing an arc drawn at this rad looks fine.
Any help would be much appreciated.
Cheers
Greg,
The .19mm is killing you.
Raster to vector conversion will fix this.
The largest problem going from a bitmap though an acad dfx is the entities are not touching.
Comp, whether used or not used will always branch at the unconnnected lines or arcs.
I believe a produst called tradesmen, or something like that will fix your problem.
I have also used an older version Coraldraw (Coraltrace) with the woodcut feature to do this task. Haven't used it for about six years.
Let us know how you make out.
Regards, Jack
