How do I add a G76 boring cycle to a post
connormac
I have a Kitamura post but it does not have a G76 boring cycle in it. I looked at mpmaster and tried to do it that way but just posted a G83 cycle.
I did a search but everything that came up seems to already have the cycle in the post and people just needed some advice.
I'm trying to bore the top of a hole then shoot thru and bore the bottom of the hole. I didn't want to write it log hand because I don't want to back bore all the way out.
Thanks in advance for any help.
You would have to use this cycle a lot to justify the time to set it up in the post.
Another option is to draw a line through C/L of holes and use 3D contour. Break the line where you need to change feed/G0, and use toolpath editor to modify.
Little bit of work on the toolpath, but everything is save with mcx file, and will post correctly with std post.
A problem using G76 is that you will not be able to feed straight through. It must retract to R for each bore.
