Okuma LB15 lathe post problems
k_barry
We have a problem with our post for an Okuma LB15ii lathe with on OSP 7000 control. It has a C axis as well.
We have 20 seats of Mcam. (Education institution) 15 are still V9, a couple of X2 and a couple of X3. (We have budget restrictions)
We want to upgrade them all to X4 but our lathe post does not work and our reseller either can't or won't supply one that works in X2 or X3.
Our reseller changed the V9 post the way we wanted it. When we got X2 we used the Updatepost.dll file to update the post.
It seems to have worked ok for our mill but the lathe has problems. We have been in contact with our reseller and he has sent us another post that doesn't work. I think originally we used the MPLOSP7 in V9 and our reseller customised it to suit us.
This has been going on for ages.
The main problem is the start of each tool. It doesn't call up a tool at all.
This is what is coming up at the start.
(PROGRAMMED BY: KB DATE: 28-09-09 )
(JOB INFORMATION-)
(JOB INFORMATION-)
CALL
( Machine definition created by UpdatePost.dll )
( Face to zero )
G13
G50 X1000. Z0.
G50 S2500
G00 X0. Z0. G97 S3500 M03
G50 S3500
G96 S200
G95 G01 F.2
But we want the following, which we used to have.
(PROGRAMMED BY: KB DATE:07-11-05 )
(JOB INFORMATION-)
(JOB INFORMATION-)
CALL
( FACE TO Z0.1 )
G00 X500. Z500. T0101 M42
N1 ( OD ROUGH RIGHT - 80 DEG. )
G50 S3000
G50 S2500
G00 X62. Z.1 G97 S1027 M03
M08
G96 S200
G95 G01 X-1.6 F.2
The end of each tool is not correct as well but if we could get the first bit done its a start.
Thanks in advance
Can you do a .z2g with a sample part make sure to check the post option when doing the .z2g and send it my way I will be glad to take a look at it for you. I have a pretty tricked out LB15 post for our machine. With the G13 I am assuming you have a lower turret. If you do would you like Mastercam Sync turning added to the post? It is a little crude, but something is better than what CNC offers for dual turret machines which is nothing!!!
Greg
The G13 came from the post update. I have had a look at the machine definition and changed a few things thinking I will delete the lower turret (it was showing a lower turret) and I may have stuffed things up a bit. I haven't done anything to the machine definition as it looks a bit daunting after using V9. I think I had better delve into the help files a bit. I just read the Mastercam getting started manual but this didn't explain much of the settings.
It still posts a G13 and still doesn't call up a tool.
