Acer Computer and M/C
Dan Joss
Does the computer shutdown while you are using it?
Or, when you are away from the computer?
If it happens when you are away, you may have the system set to go into 'hibernation' after a period of no use.
You can check for this when Mastercam is off by . . . 'right-click' in a blank area of the windows desktop - select properties - screen saver - power - power schemes (set home/office desk and set turn off monitor to never). Then if you have the Hibernation tab select that and uncheck "enable hibernation"
It sounds like a driver problem I would suspect video. Your computer is curently set to reboot on a stop "Blue Screen Of Death" so you never see a blue screen. If you press your windows key and the pause button you can set the system properties to not reboot under the advanced tab.
Once you have done that check to see what the name of the driver or file name at the top of your "blue screen of death" when it happens again.
Allan
