next_tool$ comment
Plastmo
Look at the way MP master handles the tool list in the header. It is buffers.
Here is part of (my modified)postblock that gets the info from the buffer......
You can make another call that uses rc2 = next_tool$ instead of rc2 = t$. You would also want to remove the recursive countdown of all tools. The buffer wrt's for buf2 and buf4 would be the same as in MPmaster, that I didn't include..
  ptooltable # Write tool table, scans entire file, null tools are negative
# Modified 8-11-09 RB to place tools in numeric order using Buffer 2 and 4
tnote = t$
toffnote = tloffno$
tlngnote = tlngno$
spaces$=0
size4 = rbuf(4, 0)
rc4 =1
while rc4 <= size4,
t$ = rbuf(4, rc4)
if t$ > zero,
rc2 = t$
strtool$ = rbuf(2, rc2)
if tcr$>0, "(", *t$, ptspace, " * ", plistcomm, " * ", ")", e$
if tcr$=0, "(", *t$, ptspace, " * ", plistcomm, " * ", ")", e$
!tcr$
rc4 =1
#!tS
#!strtool$
spaces$=sav_spc
Zoober - My method is similar. Here it is:
As always, back up your post first. OK.
Buffered comments are working fine for me.
My example is added to the X4 Mpmaster post.
Add a string buffer:
# Buffer 8 - Holds the string 'strlool$' for each toolpath segment
rc8 : 1 #RP
wc8 : 1 #RP
index : 1 #RP
snext_comment : "" #RP
fbuf 8 1 80 0 1 # Buffer 8
Fill the buffer while the tooltable is being output:
plistcomm  # Comments from tool library
strtool$=ucase(strtool$)
if strtool$=snull, strtool$ = snocomm
index = t$ #RP
strtool$ = wbuf(8,index) #RP
*strtool$
nstrlen = strlen(strtool$)
counter = 1
while counter <= (20-nstrlen), pspace
Then add the read and output lines to ptlchg_com:
ptlchg_com      #Tool change common blocks
if force_output | sof,
result = force(ipr_type,ipr_type)
result = force(absinc$,absinc$)
result = force(plane$,plane$)
pcom_moveb
pcheckaxis #Check for valid rotary axis
#ptoolcomment
if sof & scomm_sav <> snull,
spaces$ = 0
n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
spaces$ = sav_spc
if sof = 0, scomm_sav = snull
comment$
pcomment3
pmisccheck
pcan
if stagetool >= zero,
if omitseq$ = 1 & tseqno > 0,
if tseqno = 2, n$ = t$
pbld, *n$, *t$, "M06", ptoolcomm, e$
else, pbld, n$, *t$, "M06", ptoolcomm, e$
index = next_tool$ #RP
snext_comment = rbuf(8,index) #RP
next_tool$, "(", snext_comment, ")", e$ #RP
spaces$=0
if output_z = yes$,
preadbuf5
if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
n$, pspc, scomm_str, "MAX - ", *max_depth, scomm_end, e$
n$, pspc, scomm_str, "MIN - ", *min_depth, scomm_end, e$
spaces$=sav_spc
pstock
if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0
sav_absinc = absinc$
if wcstype > one, absinc$ = zero
pindex
if safe_index,
if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
pbld, n$, pgear, e$
pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], pfcout, strcantext, e$
if lock_codes = one & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
if convert_rpd$ = one,
gcode$ = one
feed = maxfeedpm
ipr_type = zero
pbld, n$, sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, pfspindleout, [if gcode$ = 1, *feed], e$
else,
pbld, n$, pgear, e$
gcode$ = one
feed = maxfeedpm
ipr_type = zero
pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], [if gcode$ = 1, sgfeed], pfcout, pfxout, pfyout,
pfspindleout, [if gcode$ = 1, *feed], strcantext, e$
phsm1_on #must remain before G43
pbld, n$, "G43", *tlngno$, pfzout, scoolant, e$ #next_tool$, e$ #RP Commented out next_tool$
pcan2 #Added so M and G codes in canned text will output before phsm2_on
phsm2_on #must remain after G43
sav_coolant = coolant$
if coolant$ = 1, sm09 = sm09_0
if coolant$ = 2, sm09 = sm09_1
if coolant$ = 3, sm09 = sm09_2
absinc$ = sav_absinc
pcom_movea
toolchng = zero
c_msng$ #Single tool subprogram call
plast
Now I'm outputting like this:
O0100 (NEW)
(MC-510VF MATSUURA)
(MCX FILE - D:X2MR2SP1MCXMILLNEW.MCX)
(PROGRAM - NEW.NC)
(DATE - DEC-15-2009)
(TIME - 9:28 AM)
(T1 - 3" FACE MILL - H1 - D24 - D3.0000")
(T2 - 1/2" EM - H2 - D25 - D0.5000")
(T3 - #2 C'DRILL - H3 - D26 - D0.0800")
(T4 - #38 DRILL - H4 - D27 - D0.1015")
(T5 - #1 C'DRILL - H5 - D28 - D0.0500")
(T6 - #47 DRILL - H6 - D29 - D0.0785")
(T7 - 3/16" C'SINK - H7 - D30 - D0.0600")
(T8 - 4-40 ROLL TAP - H8 - D31 - D0.1120")
(T9 - 2-56 ROLL TAP - H9 - D32 - D0.0860")
(OVERALL MAX - Z.05)
(OVERALL MIN - Z-.625)
G00 G17 G20 G40 G80 G90
G91 G28 Z0.
(SKIM TOP)
(COMPENSATION TYPE - COMPUTER)
T1 M06 ( 3" FACE MILL)
T2 ( 1/2" EM )
(MAX - Z.05)
(MIN - Z-.01)
G90 G54
G00 G17 X5.0443 Y-.9016 S5800 M03
G43 H1 Z.05 M08
Z.01
G94 G01 Z-.01 F40.
X-2.5461
G02 Y1.0734 I0. J.9875
G01 X5.0443
G00 Z.05 M09
M05
G91 G28 Z0.
M01
(PROFILE)
(COMPENSATION TYPE - WEAR COMP)
T2 M06 ( 1/2" EM)
T3 ( #2 C'DRILL )
(MAX - Z.05)
(MIN - Z-.625)
G90 G54
G00 G17 X3.4993 Y1.8235 S6000 M03
G43 H2 Z.05 M08
Z.01
G94 G01 Z-.1563 F2.
G41 D25 Y1.4235 F25.
Y-1.2517
G02 X2.9943 Y-1.7567 I-.505 J0.
G01 X-2.8961
G02 X-3.4011 Y-1.2517 I0. J.505
G01 Y1.4235
G02 X-2.8961 Y1.9285 I.505 J0.
G01 X2.9943
G02 X3.4993 Y1.4235 I0. J-.505
G01 G40 X3.8993
X3.4993 Y1.8235
Z-.3125 F2.
Y-1.2517
G01 X-2.8961
G01 Y1.4235
G01 X2.9943
G01 G40 X3.8993
X3.4993 Y1.8235
Z-.4688 F2.
Y-1.2517
G01 X-2.8961
G01 Y1.4235
G01 X2.9943
G01 G40 X3.8993
X3.4993 Y1.8235
Z-.625 F2.
Y-1.2517
G01 X-2.8961
G01 Y1.4235
G01 X2.9943
G01 G40 X3.8993
X3.4943 Y1.8235
G41 D25 Y1.4235
Y-1.2517
G02 X2.9943 Y-1.7517 I-.5 J0.
G01 X-2.8961
G02 X-3.3961 Y-1.2517 I0. J.5
G01 Y1.4235
G02 X-2.8961 Y1.9235 I.5 J0.
G01 X2.9943
G02 X3.4943 Y1.4235 I0. J-.5
G01 G40 X3.8943
G00 Z.05 M09
M05
G91 G28 Z0.
M01
(C'DRILL FOR .1015)
T3 M06 ( #2 C'DRILL)
T4 ( #38 DRILL )
(MAX - Z.05)
(MIN - Z-.1186)
G90 G54
G00 G17 X-2.2348 Y.8508 S6000 M03
G43 H3 Z.05 M08
G94
G98 G81 Z-.1186 R.01 F12.
X-1.2586 Y.619
X-1.5881 Y-.1254
X-1.1976 Y-.6135
X-.8193 Y-.3206
X.047 Y.2407
X.9866 Y.1065
X1.7676 Y-.4792
G80 M09
M05
G91 G28 Z0.
M01
(DRILL FOR 4-40)
T4 M06 ( #38 DRILL)
T5 ( #1 C'DRILL )
(MAX - Z.05)
(MIN - Z-.4)
G90 G54
G00 G17 X-2.2348 Y.8508 S2634 M03
G43 H4 Z.05 M08
G94
G98 G83 Z-.4 R.01 Q.0305 F4.22
X-1.2586 Y.619
X-1.5881 Y-.1254
X-1.1976 Y-.6135
X-.8193 Y-.3206
X.047 Y.2407
X.9866 Y.1065
X1.7676 Y-.4792
G80 M09
M05
G91 G28 Z0.
M01
(C'DRILL FOR .0785)
T5 M06 ( #1 C'DRILL)
T6 ( #47 DRILL )
(MAX - Z.05)
(MIN - Z-.0847)
G90 G54
G00 G17 X2.2557 Y-.5768 S6000 M03
G43 H5 Z.05 M08
G94
G98 G81 Z-.0847 R.01 F9.
X2.3289 Y.1187
X1.8774 Y.8631
X1.4381 Y.619
X.5473
X-.4045 Y.8508
X-.7705 Y.2773
X-2.064 Y.2041
X-2.1494 Y-.6013
X-.075 Y-.345
X.2789 Y-.6623
X.8402 Y-.4182
X1.3283 Y-.4914
G80 M09
M05
G91 G28 Z0.
M01
(DRILL FOR 2-56)
T6 M06 ( #47 DRILL)
T7 ( 3/16" C'SINK )
(MAX - Z.05)
(MIN - Z-.28)
G90 G54
G00 G17 X2.2557 Y-.5768 S3406 M03
G43 H6 Z.05 M08
G94
G98 G83 Z-.28 R.01 Q0. F3.82
X2.3289 Y.1187
X1.8774 Y.8631
X1.4381 Y.619
X.5473
X-.4045 Y.8508
X-.7705 Y.2773
X-2.064 Y.2041
X-2.1494 Y-.6013
X-.075 Y-.345
X.2789 Y-.6623
X.8402 Y-.4182
X1.3283 Y-.4914
G80 M09
M05
G91 G28 Z0.
M01
(4-40 TO .130)
T7 M06 ( 3/16" C'SINK)
T8 ( 4-40 ROLL TAP )
(MAX - Z.05)
(MIN - Z-.065)
G90 G54
G43 H7 Z.05 M08
G94
G98 G81 Z-.065 R.01 F8.
X-1.2586 Y.619
X-1.5881 Y-.1254
X-1.1976 Y-.6135
X-.8193 Y-.3206
X.047 Y.2407
X.9866 Y.1065
X1.7676 Y-.4792
G80
(2- 56 TO .100)
X2.2557 Y-.5768
G98 G81 Z-.05 R.01 F8.
X2.3289 Y.1187
X1.8774 Y.8631
X1.4381 Y.619
X.5473
X-.4045 Y.8508
X-.7705 Y.2773
X-2.064 Y.2041
X-2.1494 Y-.6013
X-.075 Y-.345
X.2789 Y-.6623
X.8402 Y-.4182
X1.3283 Y-.4914
G80 M09
M05
G91 G28 Z0.
M01
(TAP 4-40)
T8 M06 ( 4-40 ROLL TAP)
T9 ( 2-56 ROLL TAP )
(MAX - Z.05)
(MIN - Z-.35)
G90 G54
G43 H8 Z.05 M08
G95
M29 S3200
G98 G84 Z-.35 R.01 F.025
X-1.2586 Y.619
X-1.5881 Y-.1254
X-1.1976 Y-.6135
X-.8193 Y-.3206
X.047 Y.2407
X.9866 Y.1065
X1.7676 Y-.4792
G80 M09
M05
G91 G28 Z0.
M01
(TAP 2-56)
T9 M06 ( 2-56 ROLL TAP)
T1 ( 3" FACE MILL )
(MAX - Z.05)
(MIN - Z-.245)
G90 G54
G43 H9 Z.05 M08
G95
M29 S3200
G98 G84 Z-.245 R.01 F.0179
X2.3289 Y.1187
X1.8774 Y.8631
X1.4381 Y.619
X.5473
X-.4045 Y.8508
X-.7705 Y.2773
X-2.064 Y.2041
X-2.1494 Y-.6013
X-.075 Y-.345
X.2789 Y-.6623
X.8402 Y-.4182
X1.3283 Y-.4914
G80 M09
M05
G91 G28 Z0.
G28 Y0.
[ 12-15-2009, 10:05 AM: Message edited by: Mastercam Guru ]
