code output needed
tnevy
Hi tnevy, welcome to the forum!!
You need to give more information:
what ver of Mastercam are you using, what should the code look like, what does the code look like now. Is it a Miltronics control and what version.
Also, it's Friday night, you may not get much help until Monday.
MasterCam X4 software.
It is a Miltronics control.
The first G81 line is correct it has XYZ, R and feed rate. It's the second hole that has only an X or Y move as needed to get to the second hole. Machine only pauses then goes to the third hole location. At which point it gouged the part by literally moving to Y1.5Z-.11 and staying down and gouging to hole #4
G81 X-4.75 Y-1.5 Z-.1 R0.3 F10.
X4.75
Y1.5 Z-.11
X-4.75
G80
I need an R and Z at each hole even if it hasn't changed.
Thanks for any help you can offer to force output.
Sorry, I don't have X4
Do a search (search is right under the 'New Poll' button above) for "forced output" and read about the various changes to the post processor.
You will need to add a f or * at the prout and pzout lines in the post. Hopefully someone can chime in with better information.
ALWAYS SAVE A COPY OF YOUR POST BEFORE MAKING CHANGES !!!!
hth
I have the X Y and Z output at each line now, also the F rate just in case. Still having trouble getting the R value to output when the value hasn't
changed. I was able to fix the values I needed to be output in the
# Additional Holes
pdrill_2$ #Canned Drill Cycle, additional points
by adding an f or * to pxout, pyout, pzout
but it didn't help prdrlout
So I could still use some help to output an R value at each hole.
Tnevy
If your prdlout postblock looks anything like this, you're in luck.
prdrlout        #R drill position
if absinc$ = zero, refht_a, !refht_i
else, refht_i, !refht_a
Just add the force output modifier "*" to the variables that output the "R".
Like this:
if absinc$ = zero, *refht_a, !refht_i
else, *refht_i, !refht_a
You can NOT force out a postblock with a *. pxout, pyout, pzout and prdrlout are all postblocks and adding a * to them (pxout) will NOT work. You need to go into the postblocks themseleves and find the appropriate output variables and add the * to them. In our Mastercam posts there are also specific postblocks used to force XYZ which are pfxout, pfyout and pfzout so replacing pxout with pfxout would work for them but no such postblock exists for prdrlout.
John's suggestion would also work for the refht but you have to be careful to make sure NO other variables are formatted with the nonmodal format statement or they too will be forced out.
