part reposition
connormac
Good day,
Does the "g43 Z2." enter the hole or stop at the edge of the part....to save time, I would copy
+ paste from another tool, or hand
write this tool block ...the time it takes
to write this post you could have made 3
small progs...I am concidered a fast
programmer rather than exact one.
MC, most times gives me 95 to 98 %
what I need the other 2% I Jam,
just to not hear my boss say
" WHATS TAKING SO LONG "
If you want, the M0 prog you made,
Keep as a template, "Spindle part
Prog " an any time you need it
paste it in...I have hundreds
of template progs like it
Tony G
your post should be set up similar to this at psof and ptlchg:
n,G00,G90,pfwcs,xout,yout,paout,pchg_speed,
pspindle_on,pnext_tool,e
n,G43,tlngno,zout,pcoolant_on,e
pcan1
n,strcantext,e
comment
you may need to change the variables for canned text to what your post uses, but this format should work for your desired output.
Create a point at your x,y,z,.
Toolpaths, point, select point.
Canned text set to "full stop" M00, with.
If this is something you do all the time,it seems as though you could create a new "M00" drill cycle easy enough. Otherwise I would use a regular G81 drill cycle with a long dwell at the bottom. When the pin gets to the desired position, you could manually stop the machine.
