small milling cutters
Dan Bedore
I just started doing some injection molds with small radius .0625 and small shallow cuts .03125 wide*.015 deep the problem is these cuts are next to 3deg drafted walls .625 tall. where can a guy get .03125 and .0625 dia. ball and flat end mills long enough to cut this? and what would you recommend as a depth of cut and feed rate with a 6000 rpm spindle in 7075 al.? thanks ahead of time.
Can you use tapered endmill to do this job?
That is how I get to some deep pockets on our molds. I hope this helps. MSC has flat and ball tapered end mills. We special order flat tapered endmills with a corner radius to match the mold's radius from Award cutters. I am not at work so I don't have the number. They are usually cheaper than MSC on the flat ones.
Stephen
I know you can buy tapered shank ball and flat endmills. .015 dp doesn't sound like you need much flute length. Grind the shank down a little. Just remember endmills that small are already flimsy and grinding the shank and hanging them out of the holder will make them even more flimsy.
Dan
