Lathe
jeff
Is it possible to feed at different feedrates on different dia's?
There is only 1 option to give a feedrate for each op.
For example:
I would like to finish a shaft that has multiple dia's and finish some at .004 ipr and others at .012 ipr without having to make seperate toolpaths or modify my nc file.
Any suggestions?
Karl,
I tried it but the "Change at point" is grayed out so I can't click on it.
Seems like they need to do some refining on their lathe options.
It would be nice to have the option to turn any dia,radius,chamfer etc. each at different feeds.
WITHOUT having to change it in the .nc code.
Karl and Jeff,
It does work in V9. I was unable to get "change at point" to work in my rough cycle but it worked fine in finish. I usually add a comment "with" the line to help me see the change better. It takes a bit of fooling to get it right where you want the change.
Good luck. Keep at this as it is the solution you are looking for. cheers.gif
Phil
