Questions in VB
I have a VB script that does a multi post for 7 posts. I was wondering if there was any way to have the script ask me which post th use and then put the nc code in the right folder.
example:
Constantes
post 1
post 2
post 3
post 4
post 5
post 6
post 7
say I want to use post 6 & 7. Have it only create folders for 6 & 7. Then put the NC file in the right folder.
Does this make any since??
Yes this makes sense. You would need to make a condition stament in the VB script for the varabile like so:
Dim P 'Post vaule for folder
Dim K 'Vaule for Folder Amounts above 5
For P = 1 to 7 ' Count of Post Folders
If askValue("What post folder to post to?" ,0 ,7, P) Then
If askVaule("What Number to Have above 5?" ,0 , 2, K) Then
If P > 1 Then (what ever your command is for Null to take effect)
If P = 2 Then (what ever you command is for one folder)
If P = 3 Then (what ever your folder command is for 3 folders)
If P <= 5 Then
If K > 3 Then (what ever you folder command is for 2 folders where you want to start at 5 but only have a place for 2 folders)
I do not have access to your script or VB with Mastercam at home so just a guess here but Rekd or Mick are the gurus of VB.
Here is something I quickly put together that might give you some ideas.
' Sub Declaration
Sub Main()
On error resume next
Dim ret
Dim posts
Dim post
Dim i
' -- Prompt for posts
ret = AskString("Input Post numbers 1 - 7 to output, delimit by comma")
' -- Simple check
If Len(ret) = 0 Then Exit Sub
' -- Create an array for the return
posts = Split(Trim(ret), ",")
' -- Iterate over each item
For i = LBound(posts) To UBound(posts)
' -- Get this number
post = posts(i)
' -- Do something with it
Select Case post
Case 1
ShowString "Post number 1"
Case 2
ShowString "Post number 21"
Case 3
ShowString "Post number 3"
Case 4
ShowString "Post number 4"
Case 5
ShowString "Post number 5"
Case 6
ShowString "Post number 6"
Case 7
ShowString "Post number 7"
Case Else
ShowString "Invalid post"
End Select
Next
if Err then
Showstring Err.Description
end if
End Sub
Here's a script a whipped up that'll create a sub directory depending on the post that you selected. It allows you to select your post via a File|Open dialog. It will allow some flexibility, should you add new posts, since it'll create sub directories in your NC dir, based on the post's filename.
'// Author: Chris Bellini [email protected]
'// Date: 01/13/2005 9:03 AM
'// File Name: connormac2.vbs
'// Description: multiposter for connormac
'// Comments:
'//////////////////// My Constants /////////////////////
'///////////////// My Global Variables /////////////////
' call the main sub
Call Main()
' Purpose: The main sub, our script's entry point
Sub Main()
Dim objFSO ' FSO object
Dim strSelPostBname ' post base filename
Dim strNCDir ' our assembled NC directory
Dim strSelPost ' selected post
If Not AskForFileName(GetPathFromExtension("PST") & "*.pst", mcFILE_ACCESS_READ, strSelPost) Then
ShowString "Error: Post Processor not selected. Exiting."
Exit Sub
End If
' create a FileSystem Object
Set objFSO = CreateObject("Scripting.FileSystemObject")
' get the posts filename
strSelPostBname = objFSO.GetBaseName(strSelPost)
' assemble our new NC dir based on the post selected
strNCDir = GetPathFromExtension("NC") & strSelPostBname
' create our NC directory for our post if it doesn't exist
If Not (objFSO.FolderExists(strNCDir)) Then
objFSO.CreateFolder(strNCDir)
End If
' set the post
Call SetPostName(strSelPost)
' post all ops
Call RunPostAll(strNCDir, False)
' cleanup
Set objFSO = Nothing
End Sub
[ 01-13-2005, 09:17 AM: Message edited by: Bullines ]
That's because the MakeFolders() function creates all of the NC folders all in one shot, regardless of whether they were selected or not. Plus MakeFolders() is called before you even select your posts. You can modify the MakeFolders() function so that it also accepts a third parameter; the selected post to build the folder on the fly. To do as little refactoring as possible (although refactoring can be fun biggrin.gif ), let's modify that function a little bit:
' Function Declaration
Public Function MakeFolders(companyname, Program, PostFname)
On Error Resume Next
' -- Check to see if folders exist
Dim FSO
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- This is kinda long winded but does the job
' -- NOTE: If you use an invalid character for a part number you'll have a problem!
If Not FSO.FolderExists("C:Regal" & companyname) Then
Call FSO.CreateFolder("C:Regal" & companyname)
End If
If Not FSO.FolderExists("C:Regal" & companyname & "" & Program) Then
Call FSO.CreateFolder("C:Regal" & companyname & "" & Program)
End If
If Not FSO.FolderExists("C:Regal" & companyname & "" & Program & "Source") Then
Call FSO.CreateFolder("C:Regal" & companyname & "" & Program & "Source")
End If
If Not FSO.FolderExists("C:Regal" & companyname & "" & Program & "Model Files") Then
Call FSO.CreateFolder("C:Regal" & companyname & "" & Program & "Model Files")
End If
If Not FSO.FolderExists("C:Regal" & companyname & "" & Program & "Docs") Then
Call FSO.CreateFolder("C:Regal" & companyname & "" & Program & "Docs")
End If
If Not FSO.FolderExists("C:Regal" & companyname & "" & Program & "NC Code") Then
Call FSO.CreateFolder("C:Regal" & companyname & "" & Program & "NC Code")
End If
' let's create NC folders by the name of the post(s) selected
If Not FSO.FolderExists("C:Regal" & companyname & "" & Program & "NC Code" & FSO.GetBaseName(PostFname)) Then
Call FSO.CreateFolder("C:Regal" & companyname & "" & Program & "NC Code" & FSO.GetBaseName(PostFname)
End If
If Err Then
MakeFolders = False
Else
MakeFolders = True
End If
End Function
I've added a third parameter called PostFname. This will be the filename of the post selected (you've already defined those constants at the very top of the code). And instead of creating all of those folders each time MakeFolders() is called, it'll now only create the directories of the post that you passed. I used the GetBaseName() method of the FSO object to extract just the base file name...no extension.
We can now remove this code entirely:
        If Not MakeFolders(companyname, Program) Then
ShowString "Failed to create folders, aborting script"
Exit Sub
End If
Actually, we won't remove it entirely. We'll delete it from where it currently is and move it into the Select statement. For each Case, we'll modify accordingly. For example:
Case 1
If Not MakeFolders(companyname, Program, DEF_FIRST_POST) Then
Exit Sub
End If
' -- Set first post as current post
Call SetPostName(DEF_FIRST_POST)
' -- Post it
Call RunPostAll(strCNC_1, False)
Case 2
If Not MakeFolders(companyname, Program, DEF_SECOND_POST) Then
Exit Sub
End If
Call SetPostName(DEF_SECOND_POST)
' -- Post it
Call RunPostAll(strCNC_2, False)
' and so on
MCAMVB
Microsoft VBScript compilation error
Expected ')'
IActiveScriptSite::OnScriptError()
Line: Call FSO.CreateFolder("C:Regal" & companyname & "" & Program & "NC Code" & FSO.GetBaseName(PostFname)
OK
I'm not sure what it means but I don't think it liked it
You forgot to remove the initial call to MakeFolders().
Make this part:
Dim companyname
Dim Program
Do 'ask until a real company name is entered
companyname=AskString("Company Name?")
Loop While companyname="Company Name?" Or companyname="((ESC))" Or companyname=""
Do 'ask until a real program number is used
Program=AskString("Part number?")
Loop While Program="Part number?" Or Program="" Or Program="((ESC))"
Exit Sub
End If
Look like this:
Dim companyname
Dim Program
Also, I failed to notice the "_Prog" in all of your post filenames. You don't want that in the NC directories, right? In that case, let's modify MakeFolders() slightly:
Public Function MakeFolders(companyname, Program)
Dim FSO
End If
End If
End If
End If
End If
End If
If Not FSO.FolderExists("C:Regal" & companyname & "" & Program & "NC Code" & Replace(objFSO.GetBaseName(PostFname), "_Prog", "")) Then
Call FSO.CreateFolder("C:Regal" & companyname & "" & Program & "NC Code" & Replace(objFSO.GetBaseName(PostFname), "_Prog", ""))
End If
If Err Then
MakeFolders = False
Else
MakeFolders = True
End If
End Function
It's a little bit ugly, but you could always store the Replace() on the GetBaseName() in a variable first. It's Friday night, I'm lazy wink.gif
How about now?
Hey Bullines,
thanks for all your help. I got it where it will not give me any errors but it also won't do anything. I put it back on the FTP site. I'm going out of town for the weekend and my wife says no VB scripts are allowed. Will get back with you at the end of the weekend.
Thanks again
