using VBscript to format Word Document
I'm now experimenting to format WORD documents to the way I want them to look.
Here's what I want:
A single line of text centered at the top, that simply says "Program info" (a different color would be nice too). What is the object command to center text in word? I couldn't find anything specific in the microsoft site.
Then I want it to be followed by 2 short columns, which contains essential information, such as customer name, description, program name, item number, etc. Then a seperate two columns that shows the tool list, 10 tools per column. I have the printout of the TextColumn Object here, but I think VBScript wants me to declare InchesToPoints, but I get a error message if I try to declare it as a constant or array.
Then, under the tool list columns, a single line that tells the TL0 location. (or one very short pagewide column)
Lastly, the rest of the page blank for a graphic of the part. Or a single column, whichever works.
I think this list hinges on the TextColumn Object.
John
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
John,
One of the quickest ways to learn office vba is to record a new macro doing the things you mentioned, then open the VBA editor (right click toolbar check Visual Basic) and look in the Normal.dot bas module. Press F2 to view the object browser, select Word to only see word objects, you can also copy and paste any const and enum declares you may need for the script.
Here's a small snippet to get you started.
' vars
Dim objWord As Word.Application ' Word app object
Dim objDOC As Word.Document ' Word document object
' create an instance of Word
Set objWord = CreateObject("Word.Application")
appWord.Visible = True
Set objDOC = objWord.Documents.Add
' make John T's title
objWord.Selection.ParagraphFormat.Alignment = wdAlignParagraphCenter
objWord.Selection.Font.Size = 14
objWord.Selection.Font.Bold = True
objWord.Selection.Font.Name = "Arial"
objWord.Selection.Font.Color = wdColorRed
objWord.Selection.TypeText Text:="Program info"
objWord.Selection.TypeText Text:=Chr(11) ' <-- this is a new line
' more wicked awesome code to create the rest of the DOC
' clean up
Set objWord = Nothing
Set objDOC = Nothing
You may need to enumerate some of those values for VBS. The Office Developer Section on MSDN comes in handy.
Hope this gets you started.
Thanks for that snippet bulllines.
I think I'm confused about enumerate. Doesn't that mean to make a code "shortcut", such as:
Set wordDoc=CreateObject("word.Application")
So instead of typing the whole thing out, I can just type:
With wordDoc
.Visible=True
etc, etc.
Is that correct?
I've been reading up at the MSDN library a good bit now.
Mick, I'll send some code shortly.
John
Mick,
Heres the code in question. I've noted the 2 macros I've been trying, and are causing problems. The first one is supposed to set margins, the second one a vertical, rotated text box on the upper right. The margin code seems to be asking to have the InchesToPoints defined first, and the text box code keeps insisting there needs to be a right parentheses ")"
John
Dim wordDoc
Dim companyname
Dim Program
Dim Description
Dim Post
Dim programmer
Const wdAlertsNone=0
Const wdWindowStateMaximize=1
Const wdLine=5
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
WriteString("Company Name?")
companyname=AskString("company Name?")
Program=AskString("program number?")
Description=AskString("description")
Post=AskString("fadal")
programmer=AskString("programmer?")
Set wordDoc=CreateObject("Word.Application")
wordDoc.Documents.Add
With wordDoc
.Visible=True
.WindowState=wdWindowStateMaximize
.DisplayAlerts=wdAlertsNone
.Selection.PageSetup.LeftMargin = InchesToPoints(0.5) 'start of margin setting macro
.Selection.PageSetup.RightMargin = InchesToPoints(0.5)
.Selection.PageSetup.TopMargin = InchesToPoints(0.5)
.ActiveWindow.ActivePane.VerticalPercentScrolled = 20
.Selection.PageSetup.BottomMargin = InchesToPoints(0.5) 'end of margin setting macro
.ActiveDocument.Words(1).Text="Company "&companyname&vbTab&"Program "&Program&vbTab&"Dir "&GetCurrentFileName()&vbNewLine & _
"Description "&Description&"Post "&post&" Stock Size "&GetJobSetupStockSizeX&" X "&GetJobSetupStockSizeY&" X "&GetJobSetupStockSizeZ
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 513#, _
108#, 45#, 117#).Select 'start of macro code
.Selection.ShapeRange.TextFrame.TextRange.Select ' should put the "Program" string in a vertical box
.Selection.Collapse
.Selection.ShapeRange.Select
.Selection.ShapeRange.IncrementLeft 36#
.Selection.ShapeRange.IncrementTop -18#
.Selection.Orientation = wdTextOrientationDownward
.Selection.Font.Size = 24
.Selection.TypeText Text:=Program 'end macro code
End With
End Sub
[ 03-11-2004, 11:58 PM: Message edited by: John T. ]
John T.
Is this more what you're after?
Dim wordDoc
Dim companyname
Dim Program
Dim Description
Dim Post
Dim programmer
Const wdLine=5
' add these
Const msoTextOrientationHorizontal = 1
Const wdTextOrientationDownward = 3
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
With wordDoc
.Visible=True
.Selection.PageSetup.LeftMargin = .InchesToPoints(0.5) ' resolve back to Word object
.Selection.PageSetup.RightMargin = .InchesToPoints(0.5) ' resolve back to Word object
.Selection.PageSetup.TopMargin = .InchesToPoints(0.5) ' resolve back to Word object
.ActiveWindow.ActivePane.VerticalPercentScrolled = 20 ' resolve back to Word object
.Selection.PageSetup.BottomMargin = .InchesToPoints(0.5) ' resolve back to Word object
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 513, 108, 45, 117).Select 'start of macro code
.Selection.Collapse
.Selection.TypeText Program 'end macro code
End With
End Sub
John,
I have put a comment (mag) where I made changes to get your script to run.
Dim wordDoc
Dim companyname
Dim Program
Dim Description
Dim Post
Dim programmer
Const wdLine=5
' -- Were missing mag
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
'WriteString("Company Name?")
Post=AskString("fadal") ' -- You can call GetPostName() mag
With wordDoc
.Visible=True
' -- InchesToPoints is an App method mag
.Selection.PageSetup.LeftMargin = .InchesToPoints(0.5) 'start of margin setting macro
.Selection.PageSetup.BottomMargin = .InchesToPoints(0.5) 'end of margin setting macro
.ActiveDocument.Words(1).Text= "Company "& companyname & vbTab & "Program " & Program & vbTab & "Dir " & GetCurrentFileName() & vbNewLine & _
"Description " & Description & " Post " & post & " Stock Size " & GetJobSetupStockSizeX & " X " & GetJobSetupStockSizeY & " X " & GetJobSetupStockSizeZ
.Selection.Collapse
.Selection.ShapeRange.IncrementLeft 36 ' -- Removed # not valid in VBS mag
' -- Removed Text:= can't use this type of assignment in VBS
End With
If Not wordDoc Is Nothing Then Set wordDoc = Nothing
ShowString "Script has ended"
End Sub
Mick, How can I find information as to what those Const wdXxxxxx = X values should be? That seems to be a stumbling block for me.
I'm at home now (4 day workweek!), so will give your code a try Monday.
A bit eerie how Bullines and Mick came up with the same program
It really seems to be the little things like the # sign and text:= that aren't allowed in VBS that are tripping me up because I don't know that.
You guys have been a lot of help!
Hey Mick,
So where do it find the
...Tea by which all other teas are judged ...
here in the States? I watched all the commercials. I'd try it just on those alone! Kewl!
Mick, Browsing through Word's object browser screen, with the "Word" selected in the upper left dropdown. Using the example you wrote, I looked up "selection (classes column on left)-oriention (members of "selection" on right), and on the bottom, it tells me "Property Oriention as WdTextOriention".
Now, I can get the "wdTextOrientionDownward" from the recorded macro, but how do you know to define the constant wdTextOriention as 3 in the constant definitions?
This is what puzzles me in this code. how do I find out what these number mean, or which numbers are required in defining these constants?
In playing around with centering a pargraph, I discovered that the constant for orienting a paragraph (forgot what it was right now, have it noted) to =1 seems to "turn it on". Obviously, not all definitions are 0/1 or on/off.
John
