using VBscript to format Word Document
Here's what I've done so far tonight.
Dim wordDoc
Dim companyname
Dim Program
Dim Description
Dim Post
Dim programmer
Dim notes
'Dim whatdate()
Dim DateTimeFormat()
Const wdAlertsNone=0
Const wdWindowStateMaximize=1
Const wdLine=5
Const wdEnglishUS = 1033
Const wdCalendarWestern = 0
Const wdColorDarkRed=128
Const wdAlignParagraphCenter=1
Const msoTextOrientationHorizontal = 1
Const wdTextOrientationDownward = 3
Const msoFalse=0
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
'WriteString("Company Name?")
companyname=AskString("company Name?")
Program=AskString("program number?")
Description=AskString("description")
Post=AskString("fadal") ' -- You can call GetPostName() mag
programmer=AskString("programmer?")
notes=AskString("Notes")
Set wordDoc=CreateObject("Word.Application")
wordDoc.Documents.Add
With wordDoc
.Visible=True
.WindowState=wdWindowStateMaximize
.DisplayAlerts=wdAlertsNone
' -- InchesToPoints is an App method mag
.Selection.PageSetup.LeftMargin = .InchesToPoints(0.5) 'start of margin setting macro
.Selection.PageSetup.RightMargin = .InchesToPoints(0.5)
.Selection.PageSetup.TopMargin = .InchesToPoints(0.5)
.ActiveWindow.ActivePane.VerticalPercentScrolled = 20
.Selection.PageSetup.BottomMargin = .InchesToPoints(0.5) 'end of margin setting macro
'Puts "Program Info" top center
.Selection.Font.Bold=True
.Selection.ParagraphFormat.Alignment=wdAlignParagraphCenter
.Selection.Font.Name="staccato222 BT"
'.Selection.Font.Color =wdColorDarkRed 'Running low on red ink!
.Selection.TypeText "PROGRAM INFO"
.Selection.TypeText vbNewLine
'Puts program number in sideways box, right side
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 525, 75, 45, 117).Select 'start of macro code
.Selection.ShapeRange.TextFrame.TextRange.Select
.Selection.Collapse
.Selection.ShapeRange.Line.Visible = msoFalse
.Selection.ShapeRange.Select
.Selection.ShapeRange.IncrementLeft 36 ' -- Removed # not valid in VBS mag
.Selection.ShapeRange.IncrementTop -18
.Selection.Orientation = wdTextOrientationDownward
.Selection.Font.Size = 24
.Selection.TypeText Program
'double text boxes for header info
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 20.3,72, 222.3, 80).Select 'first box left side
.Selection.ShapeRange.TextFrame.TextRange.Select 'First box header info goes this section
.Selection.Collapse
.Selection.TypeText "Company: "&vbTab 'Company Name
.Selection.Font.Bold=False
.Selection.TypeText companyname&vbNewLine
.Selection.TypeText "Description: "&vbTab 'Description
.Selection.TypeText Description &vbNewLine
.Selection.TypeText "PI Num: "&vbTab 'PI number
.Selection.TypeText Program &vbNewLine
.Selection.TypeText "Name: "&vbTab 'Programmer Name
.Selection.TypeText programmer&vbNewLine
.Selection.TypeText "Date "&vbTab 'Date
'.Selection.InsertDateTime (DateTimeFormat= "M/d/yy", InsertAsField =False,DateLanguage =wdEnglishUS, CalendarType= wdCalendarWestern,InsertAsFullWidth= False) 'Earlier attempt at getting the date
' Call getthedate()
'.Selection.TypeText Time
'Second Header box
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 259,72, 280.35, 80).Select 'second box right side
.Selection.Collapse
.Selection.TypeText "Filename: "&vbTab&vbTab 'File Name
.Selection.TypeText GetCurrentFileName()&vbNewLine
.Selection.TypeText "Post: "&vbTab&vbTab&vbTab 'Post
.Selection.TypeText Post &vbNewLine
.Selection.TypeText "Material Type "&vbTab 'Material type IF in Job setup
.Selection.TypeText GetJobSetupMaterial() &vbNewLine
.Selection.TypeText "Stock Size: "&vbTab&vbTab 'Stock size IF in job setup
.Selection.TypeText "X"&GetJobSetupStockSizeX&" Y"&GetJobSetupStockSizeY&" Z"&GetJobSetupStockSizeZ &vbNewLine
.Selection.TypeText "Stock Origin: "&vbTab 'Stock origin from job setup. Almost always 0,0
.Selection.TypeText "X"&GetJobSetupStockOriginX&" Y"&GetJobSetupStockOriginY&vbNewLine
'Print out notes
End With
If Not wordDoc Is Nothing Then Set wordDoc = Nothing
ShowString "Script has ended"
End Sub
'Sub getthedate()
' whatdate=InsertDateTime (DateTimeFormat= "M/d/yy", InsertAsField =False,DateLanguage =wdEnglishUS, CalendarType= wdCalendarWestern,InsertAsFullWidth= False)
'End Sub
You'll notice I have the askstring and date stuff commented out. I don't know how to have the prompt string show above the input line at the bottom of mastercam like it does on the .SET sheets.
Second, I couldn't get the datetime thing to work. If I understand it right, its supposed to be a subroutine, but I can't get it to work right. The one in the above code is pretty hacked up from the Word macro, but as it is right now, I get a "mismatch" error message.
You'll notice I use textboxes for the information. I think I'll have to use these through the whole document? I next need to make a text box for the notes two lines long across the whole page, then 2 longer side by side boxes for the tool list, then a one line text box below then for the TL0 location, then finally one more text box filling the remainder of the page for the graphic of the part.
John
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
I'm at home and have OpenOffice, whose BASIC scripting language is very similar to Word's (and the rest of Office) but the objects are very different. But I'm pretty sure that Word's InsertDateTime method for Selections is overloaded (bad term to use with VB, I know). That is, some of the parameters are optional. Maybe all you'd need is:
.Selection.InsertDateTime DateTimeFormat= "M/d/yy", InsertAsField = False
Otherwise, you could always get the current date on your own and insert it as text.
' these are the constants for the date formats
Const DEF_GENERAL_DATE = 0
Const DEF_LONG_DATE = 1
Const DEF_SHORT_DATE = 2 ' looks like you want this one
Const DEF_LONG_TIME = 3 ' and this one, too
Const DEF_SHORT_TIME = 4
Dim strCurrDate ' string to hold the current date
Dim strCurrTime ' string to hold the current time
' get the date and format it (depends on your Regional Settings in your Control Panel)
strCurrDate = FormatDateTime(Date, DEF_SHORT_DATE)
' get the time and format it (depends on your Regional Settings too)
strCurrTime = FormatDateTime(Tim, DEF_LONG_TIME)
' now write strCurrDate and strCurrTime to the Word document with Selection's TypeText
Well Hope James doesn't get mad becuase he took this off very soon after
he put it up because the person he put it for didnt care for the help
but maybe you can use something out of it.
This is from James Meyette:
Sub MakeToolTable()
' MakeToolTable Macro
'Remove spaces
Selection.HomeKey Unit:=wdStory
Selection.Find.ClearFormatting
Selection.Find.Replacement.ClearFormatting
With Selection.Find
.Text = " "
.Replacement.Text = " "
.Forward = True
.Wrap = wdFindContinue
.Format = False
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.MatchSoundsLike = False
.MatchAllWordForms = False
End With
Do While Selection.Find.Execute = True
Selection.Find.Execute Replace:=wdReplaceAll
Loop
With Selection.Find
.Text = "^p "
.Replacement.Text = "^p"
.Forward = True
.Format = False
.MatchCase = False
End With
Loop
With Selection.Find
.Text = " "
.Replacement.Text = "^t"
.Forward = True
.Format = False
.MatchCase = False
End With
Loop
With Selection.Find
.Text = "i^t"
.Forward = True
.Format = False
.MatchCase = False
End With
Loop
'Remove extra lines at top of program
Selection.MoveDown Unit:=wdLine, Count:=3, Extend:=wdExtend
Selection.Delete Unit:=wdCharacter, Count:=1
Selection.EndKey Unit:=wdStory, Extend:=wdExtend
Selection.ConvertToTable Separator:=wdSeparateByTabs, NumColumns:=7
', _
' NumRows:=19, Format:=wdTableFormatNone, ApplyBorders:=True, ApplyShading _
' :=True, ApplyFont:=True, ApplyColor:=True, ApplyHeadingRows:=True, _
' ApplyLastRow:=False, ApplyFirstColumn:=True, ApplyLastColumn:=False, _
' AutoFit:=False
'Remove "tool type" and "radius type" columns
With Selection.Find
.Text = "tool type"
End With
Selection.SelectColumn
Selection.Columns.Delete
With Selection.Find
.Text = "radius type"
End With
'Change column widths
Selection.Cells.SetWidth ColumnWidth:=InchesToPoints(2), RulerStyle:= _
wdAdjustNone
Selection.Rows.SpaceBetweenColumns = InchesToPoints(0.15)
Selection.Collapse Direction:=wdCollapseStart
Selection.Move Unit:=wdColumn, Count:=-1
wdAdjustNone
Selection.Cells.SetWidth ColumnWidth:=InchesToPoints(1.5), RulerStyle:= _
wdAdjustNone
Selection.Cells.SetWidth ColumnWidth:=InchesToPoints(1), RulerStyle:= _
wdAdjustNone
'Bold top row
Selection.SelectRow
Selection.Font.Bold = wdToggle
Selection.Font.Size = 12
Selection.ParagraphFormat.Alignment = wdAlignParagraphCenter
' Sort Tool Table
Selection.MoveLeft Unit:=wdCharacter, Count:=1
Selection.Sort ExcludeHeader:=True, FieldNumber:="Column 1", SortFieldType _
:=wdSortFieldAlphanumeric, SortOrder:=wdSortOrderAscending, FieldNumber2 _
:="", SortFieldType2:=wdSortFieldAlphanumeric, SortOrder2:= _
wdSortOrderAscending, FieldNumber3:="", SortFieldType3:= _
wdSortFieldAlphanumeric, SortOrder3:=wdSortOrderAscending, Separator:= _
wdSortSeparateByTabs, SortColumn:=False, CaseSensitive:=False, LanguageID _
:=wdLanguageNone
'Remove extra zeros from CORNER RADIUS Column
With Selection.Find
.Text = "00 in."
.Replacement.Text = " in."
.Forward = True
.Format = False
.MatchCase = False
End With
End Sub
Is there a way to put a space and a half between lines instead of one space?
Try:
Const DEF_SPACING_ONEANDAHALF = 1 ' <- 1.5 line spacing
With Selection.ParagraphFormat
.LineSpacingRule = DEF_SPACING_ONEANDAHALF
End With
Or maybe in your situation:
With wordDoc
' some stuff
Selection.ParagraphFormat.LineSpacingRule = DEF_SPACING_ONEANDAHALF
' some more stuff
End With
Here's my latest, it does almost everything I need it to do.
'// Author: John Thompson, with MUCH help from Mick George and Bullines!
'// Date: 15/03/2004 04:01 PM
'// File Name: New Mastercam Script
'// Description: Headertest2.vbs
'// Comments: Makes a job setup sheet. Work in progress!
' -- Start Script
' Sub Declaration
Dim wordDoc
Dim companyname
Dim Program
Dim Description
Dim Post
Dim programmer
Dim notes
Dim tlo
Dim nCount ' number of operations
Dim nToolNum ' tool number
Dim arrToolNumber() ' array of tool numbers
Dim arrToolComment() ' array of tool comments
Dim arrToolDiameter() ' array of tool diameters
Dim arrToolFluteLength() ' array of tool flute lengths
Dim arrToolLength() ' array of tool lengths
Dim idx
Dim toolcount
Dim strText
Dim Position
Const wdTabLeaderSpaces = 0
Const wdLine=5
Const msoFalse=0
Const DEF_SPACING_ONEANDAHALF=1
Const wdAlignTabLeft = 2
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
tlo=AskString("TL0")
'Load tool information
' get the number of operations
nCount = GetOperationCount("")
If nCount = 0 Then ShowString "No operations found in current drawing": Exit Sub
For idx = 1 To nCount
' get the tool number using the current operation
nToolNum = GetToolNumberFromOperationID("", idx)
ReDim Preserve arrToolNumber(idx)
ReDim Preserve arrToolComment(idx)
ReDim Preserve arrToolDiameter(idx)
ReDim Preserve arrToolFluteLength(idx)
ReDim Preserve arrToolLength(idx)
' copy tool data into our individual arrays
arrToolNumber(idx) = nToolNum
arrToolComment(idx) = GetToolComment(nToolNum)
arrToolDiameter(idx) = GetToolDiameter(nToolNum)
arrToolFluteLength(idx) = GetToolFluteLength(nToolNum)
arrToolLength(idx) = GetToolLength(nToolNum)
Next
With wordDoc
.Visible=True
'Sets Margins
.Selection.Font.Size=20
.Selection.Collapse
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 20,80, 222.3, 80).Select 'first box left side
.Selection.Collapse
.Selection.TypeText "Date "&vbTab&vbTab 'Date
.Selection.InsertDateTime "M/D/YY", False, False, wdEnglishUS, wdCalendarWestern 'get the date
'Second Header box
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 259,80, 300, 80).Select 'second box right side
.Selection.Collapse
'Print out notes
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 20, _
153, 567.15, 30).Select
.Selection.Collapse
.Selection.TypeText "NOTES: "
.Selection.TypeText notes
'Revisions listing
198, 575.7, 50).Select
.Selection.Collapse
.Selection.ShapeRange.Line.Visible=msoFalse
.Selection.TypeText "Revisions:"&vbNewLine
.Selection.TypeText "Name:________"&vbTab&"Name:________"&vbTab&"Name:________"&vbTab&"Name:_______"&vbTab&"Name:________"&vbNewLine
.Selection.TypeText "Date:________"&vbTab&"Date:________"&vbTab&"Date:________"&vbTab&"Date:_______"&vbTab&vbTab&"Date:________"
'puts out tool list
'creat 2 text boxes
'left side box
250, 270, 225).Select
'.ActiveDocument.Paragraphs.TabStops.ClearAll
'.Selection.ParagraphFormat.TabStops.Add Position=.InchesToPoints(0.51),.Alignment=wdAlignTabLeft, .Leader=wdTabLeaderSpaces
'.Selection.ParagraphFormat.TabStops.Add Position=.InchesToPoints(1.58),.Alignment=wdAlignTabLeft, .Leader=wdTabLeaderSpaces
'.Selection.ParagraphFormat.TabStops.Add Position=.InchesToPoints(2.14),.Alignment=wdAlignTabLeft, .Leader=wdTabLeaderSpaces
'.Selection.ParagraphFormat.TabStops(InchesToPoints(2.61)).Position =.InchesToPoints(2.69)
.Selection.Collapse
.Selection.ParagraphFormat.LineSpacingRule=DEF_SPACING_ONEANDAHALF 'Change line spacing to 1 and a half
.Selection.TypeText "Tool"&vbTab&"Description"&vbTab&" "&"Dia "&vbTab&"Flute"&vbTab&"Overall"
toolcount=1 'prints first tool
strText="T"&arrToolNumber(1)& vbTab & _
arrToolComment(1) & vbTab &" "& _
arrToolDiameter(1) & vbTab&" " & _
arrToolFluteLength(1) & vbTab & _
arrToolLength(1)
Call WriteToWord(strText)'sends first tool to word
For idx=1 To nCount
If toolcount<=9 Then
If toolcount<>GetToolNumberFromOperationID("",(idx)) Then
strText = "T"&arrToolNumber(idx)& vbTab & _
arrToolComment(idx) & vbTab &" " & _
arrToolDiameter(idx) & vbTab&" "& _
arrToolFluteLength(idx) &vbTab& _
arrToolLength(idx)
toolcount=toolcount+1
End If
End If
Next
'Right side box
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 310, _
.Selection.Collapse
.Selection.TypeText "Tool"&vbTab&"Description"&vbTab&" "&"Dia"&vbTab&"Flute"&vbTab&"Overall"
'Second column of tools
toolcount=11
'toolcount=1
For idx=1 To nCount
If toolcount >= 10 Then
If toolcount=GetToolNumberFromOperationID("",(idx)) Then
arrToolLength(idx)
End If
End If
Next
'Put TL0 information in
485, 564.3, 35).Select
.Selection.Collapse
.Selection.TypeText "T.L.0. Location: "
.Selection.TypeText tlo&vbNewLine
.Selection.TypeText "_________________________________________________________________________________________"
End With
End Sub
' Writes tool list to word
Public Sub WriteToWord(strOutText)
Dim wordCounts
With wordDoc
.Selection.MoveDown wdLine, .ActiveDocument.Words.Count
.Selection.TypeParagraph
.Selection.TypeText strOutText
End With
End Sub
You'll noticed I tried to work with tabbing. If the tool diameter was more than 3 decimal places, it bumped the flute and overall columns over for that tool. I didn't get that to work, but it wasn't a priority (yet). I now need to get the EMF file to go on the remainder of the page. I started a new topic for that.
The logic to split the tool list into 2 columns turned out to be devilishly simple. banghead.gif
Future stuff includes getting the prompt to work when asking for the information at the top (company, number, etc), check stock sizes and asking if want to change if they are 0, use the default tool dimensions or input your own, and so on.
I also need to test this program on files that are missing a tool, or reuse a tool later on in the program, or tools out of sequence.
John
John that is pretty slick I like that. I want to personally thank you for sharing that. I know see a base for a good word doc. I have some Vb code at home that will make a bmp of a screen shot I got off of some Vb web site I will post it up and see if you can use it. I also have a Vb script for doing Word doc to Excel but that can be done easily in Word so not sure if it will do you any good. cheers.gifcheers.gifcheers.gifcheers.gif
A beer for your hard work.
CAM Disciple, what do you mean by two groups of tool paths? Do you mean like cutting the same part several times in one set up?
Something similar, if we have to cut a feature several times on one part, we use transform. You can also transform the transform for multiple parts.
MillMan,
Much of the thanks goes to Mick and Bullines. I could not have figured out a lot of it without them, and its still not finished!
John
Here it is. My finished setup sheet. There is only one big problem. It doesn't work right from MC, only the VB editor in MC!! why is this???
'// Description: setupsheet.vbs
' -- Start Script
' Sub Declaration
Dim wordDoc
Dim companyname
Dim Program
Dim Description
Dim Post
Dim programmer
Dim notes
Dim tlo
Dim idx
Dim toolcount
Dim strText
Dim Position
Dim FileName
Dim graphic
Dim stockx
Dim stocky
Dim stockz
Const wdLine=5
Const msoFalse=0
Const wdAlignTabRight = 2
Const wdAlignTabLeft=2
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Do 'ask until a real company name is entered
Loop While companyname="company Name?" Or companyname="((ESC))" Or companyname=""
Do 'ask until a real program number is used
Loop While Program="program number?" Or Program="" Or Program="((ESC))"
Do 'ask until a real description is used
Loop While Description="description" Or Description="" Or Description="((ESC))"
Post=AskString("Fadal") ' -- You can call GetPostName() mag
Do 'ask until a real programmer name is input
Loop While programmer="programmer?" Or programmer="" Or programmer="((ESC))"
notes=AskString("Notes") 'better a blank line than seeing Notes: notes
If notes="Notes" Or notes="" Then
notes=""
End If
Do
Loop While tlo="TL0" Or tlo="" Or tlo="((ESC))"
'get stock setup sizes
stockx=GetJobSetupStockSizeX
stocky=GetJobSetupStockSizeY
stockz=GetJobSetupStockSizeZ
'check stock size for 0
If stockx=0 Then
If askYesNo ("Stock size is zero, do you want to change it?")=mcMSG_YES Then
stockx=AskString ("X stock size?")
stocky=AskString ("Y stock size?")
stockz=AskString ("Z stock size")
End If
End If
Next
'open word
With wordDoc
.Visible=True
'Sets Margins
.Selection.Collapse
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 20,80, 222.3, 60).Select 'first box left side
.Selection.Collapse
.Selection.TypeText "Material: "&vbTab 'Material type IF in Job setup
'Second Header box
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 245,80, 320, 60).Select 'second box right side
.Selection.Collapse
.Selection.TypeText "X"&stockx&" Y"&stocky&" Z"&stockz &vbNewLine
'Print out notes
140, 530, 35).Select
.Selection.Collapse
'Revisions listing
180, 575.7, 33).Select
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(1.6)
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(3.1)
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(4.6)
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(6.1)
.Selection.Collapse
.Selection.TypeText "Name: "&programmer&vbTab&"Name:________"&vbTab&"Name:________"&vbTab&"Name:_______"&vbTab&"Name:________"&vbNewLine
.Selection.TypeText "Date: " 'Date
.Selection.TypeText vbTab&"Date:________"&vbTab&"Date:________"&vbTab&"Date:_______"&vbTab&"Date:________"
'puts out tool list
'creat 2 text boxes
'left side box
213, 270, 225).Select
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(.5)
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(1.5)
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(2.3)
.Selection.ParagraphFormat.TabStops.Add .InchesToPoints(2.9)
.Selection.Collapse
arrToolLength(1)
For idx=1 To nCount
arrToolLength(idx)
End If
End If
Next
'Right side box
.Selection.Collapse
toolcount=11
'toolcount=1
For idx=1 To nCount
arrToolLength(idx)
End If
End If
Next
438, 564.3, 35).Select
.Selection.Collapse
'Load Graphic into textbox
graphic="J:datatetest.emf"
DoMetafile graphic
.ActiveDocument.Shapes.AddTextbox(msoTextOrientationHorizontal, 115, _
480, 390, 302).Select
.Selection.Collapse
.Selection.InlineShapes.AddPicture graphic,False,True
End With 'end output to word
End Sub
Dim wordCounts
With wordDoc
End With
End Sub
What doesn't work is the message boxes, one that asks if you want to enter stock size if the default is zero, and it won't create the text box at the bottom and put the EMF graphic in it. I don't know if its creating the EMF file either, haven't checked.
I assigned the script to the F12 key, and it won't do those things, only from the script editor.
John
Serious problem has cropped up. The 30mb file I was using to test the script while developing it caused no problems, but when attempted with large files with lots of 3D, 131mb and 69mb, it causes MC to crash (caused errors message box). a 68mb file worked OK though. This was on different computers with the same results.
any ideas?
John
In testing, if a tool is missing (i.e. 1,2,4,5, etc) it messes up the tool list.
This is because you're using a FOR loop to sequentially move through a list of integers representing tool numbers. Back in this thread, I recommended using a DO-WHILE loop instead. This method gets the tool number from an operation ID. Note that in my code, it's not dependant on a sequence of integers.
Heres what I tried:
toocount=1
idx=1
Do
Do While toolcount=GetToolNumberFromOperationID("",(idx))
arrToolLength(idx)
Loop
idx=idx+1
Loop While toolcount<=10
This works fine when all the tools are there, but it crashes in the case of the missing tool. Do I need to do some error trapping the way of looking for a different kind of string, such as "NULL" or something? For my testing, I deleted tool 3, it lists tools one and 2 fine, lists tool 4 as T3, then freezes up, possibly an infinite loop.
I have no idea what to look for to see if a tool is missing.
John
I'll explain my loop with a little bit more detail. I'll repost my code and just highlight the important parts:
Dim nOpNum ' operation number
' get the id of the first operation
nOpNum = GetFirstOperationID("")
' loop as long as there are operations to get
Do
nToolNum = GetToolNumberFromOperationID("", nOpNum)
' show the nitty gritty details
ShowString "Operation ID: " & nOpNum & vbLf & "Tool number: " & nToolNum
' get the next operations
nOpNum = GetNextOperationID()
Loop While(nOpNum <> -1)
First, we'll find out how many operations you have. This is purely for a "there are x number of ops in this file". It has nothing to do with how the WHILE loop will work. Each operation uses a tool, so if we know ho many operations we have, we'll also know how many tools there are. But we won't know the tool numbers...not yet, anyway:
The next line does have a lot to do with how the WHILE loop works. It puts us at the start of the list of operations:
Now we'll start the loop. We will sequentially "touch" an operation in each iteration of the loop. And we will continue to stay in the loop as long as there are operations to "touch"
Do
Now we'll figure out all of our tool numbers. We'll do that with GetToolNumberFromOperationID(). We'll get the tool number based on the operation that we're on and not via a sequence of integers that can't take out-of-sequence tool numbers into account. Where did we get an operation ID? Well to start, we got the op ID of the first operation before we entered the loop:
Now do something with the tool info:
' do some stuff
Now we'll get the next operation ID. We won't be incrementing a counter or a variable like that. We'll call GetNextOperationID() and let Mastercam be responsible for telling us what the next operation in the list of operations is. The operation we get from GetNextoperationID is what we'll use to determine the tool number of the next iteration of the loop (if there are more operations remaining):
Then we close up the loop code. This line determines whether our loop contuinues or ends here. If GetNextOperationID from the line before is unable to get the next ID because there are no more, the function returns the value -1. So if there are no more operations, that's our sign to end the loop:
So with your code, and if you don't need arrays, you could do something like the following:
Dim strText ' tool info string
Do
' assemble the string
strText = "T" & nToolNum & vbTab & _
GetToolComment(nToolNum) & vbTab & " " & _
GetToolDiameter(nToolNum) & vbTab & " " & _
GetToolFluteLength(nToolNum) & vbTab & _
' write out the tool info to Word
If you still want to store it all in arrays, that's no problem. You'd then add an index varriable for the arrays and increment it on each iteration of the loop.
Bullines,
Your code works, but it seems the trick is to list each tool only once, then only 10 tools each in 2 columns. Straight, your code will list all operations.
I can't seem to do this correctly. Whatever I try either gives me an inifinite loop, or lists tool 1 once. I'm trying to puzzle out the logic to do this now.
John
Heres what I have. It works fine when tools are consecutive, but skips the remaining tools after the missing one. this is the code for one column.
I don't know if the if-next loop in ther messed things up, but I just can't figure out how to cut up the tool list into 2 columns of 10 tools each
nCount=GetFirstOperationID("")  'Get id of first operation
toolcount=1
Do
nToolNum=GetToolNumberFromOperationID("",nCount)
If toolcount=nToolNum Then
strText="T"&nToolNum&vbTab& _
GetToolComment(nToolNum)&vbTab& _
GetToolDiameter(nToolNum)&vbTab& _
GetToolFluteLength(nToolNum)&vbTab& _
With wordDoc 'output to word
.Selection.TypeText strText
End With
'nCount=GetNextOperationID()
'Else nToolNum=nToolNum+1
End If
Loop While (nCount<>-1) And nToolNum<=10
John
Try this:
Do
End With
In that case, you can use your toolcount variable to keep track of how many tools you've done so far, incrementing it on each interation of the DO-WHILE loop, and store everything in arrays or another data structure. Then loop through the arrays afterwards and start a new column when (toolcount Mod 10 = 0) or something like that. But DO NOT use your toolcount variable for exit conditions of the loop. remember, tool numbers may not be sequential so let GetNextOperationID() determine when the loop ends.
I still haven't figured out the logic for splitting the tool list, but I'm working on it. smile.gif
But anyway, we have a theory that what causes MC to crash when using this doc sheet is that it has something to do with transformed operations. The one thing in common all the programs that crash has been transformed operations.
Interesting. We'll be putting it to the test shortly.
John
