VBS Script for Multi Posts
Ok you need ot do alt c and bring up chook mcamvb. Here you will see a place to load a script or run a script or you can also map a toolbar to the VB script and run it that way.
Now a question for you did you go the FTP and get the ZIP out of the VB folder there is a very good explaintion of things to do and to watch for when using the multipost and the VB scripts.
I would also look ofr the multi post. The Vb part of it was for folder selection to put the files in the right place as well as some other functions if memeory serves me correct. You can set up the multi post you can do liek your post for one post then your set ot html set-up sheet as your others and if you had a txt that did soemthing it could be your third. Then when you post you get a post file a set-up sheet then a txt file like report or something you hsve developed for any additional information.
Glad if I can help anyone and that is reward enough for me. biggrin.gifbiggrin.gif
he Box is not checked. I have it posting for 7 diffrent machines but it doesn't pull all 7 up in program editor. If that makes since.(sp)
Check your posts to see if they have the variable bug1 set to anything other than 0, if so make them 0 to suppress the editor.
# Debugging and program switches
fastmode : 1 #Posting speed optimizition
bug1 : 2 #0=No display, 1=Generic list box, 2=Editor
This is what my Bug1 line says
# DEBUG/PROGRAM SWITCHES, debugging and program switches
bug1 : 2 # 1=Output post to screen, 2=output leader to screen
do I need to add
#0=No display
can I put this in as questions
' Sub Declaration
Sub Main()
On Error Resume Next
Do 'ask until a real company name is entered
companyname=AskString("company Name?")
Loop While companyname="company Name?" Or companyname="((ESC))" Or companyname=""
Do 'ask until a real program number is used
Program=AskString("PI number?")
Loop While Program="PI number?" Or Program="" Or Program="((ESC))"
then use this
Public Const DEF_FIRST_POST = "OP_KH.pst"
Public Const DEF_CNC_1 = "C:'Company Name'PI numberNC CodeOP"
Public Const DEF_SECOND_POST = "550_KH.PST"
Public Const DEF_CNC_2 = "C:'Company Name'PI numberNC Code550"
Public Const DEF_THIRD_POST = "1000_KH.PST"
Public Const DEF_CNC_3 = "C:'Company Name'PI numberNC Code1000"
Public Const DEF_FOURTH_POST = "Okuma_KH.PST"
Public Const DEF_CNC_4 = "C:'Company Name'PI numberNC CodeOkuma"
Public Const DEF_FIFTH_POST = "V30_KH.PST"
Public Const DEF_CNC_5 = "C:'Company Name'PI numberNC CodeV30"
Public Const DEF_SIXTH_POST = "V40_KH.PST"
Public Const DEF_CNC_6 = "C:'Company Name'PI numberNC CodeV40"
Public Const DEF_SEVENTH_POST = "760_KH.PST"
Public Const DEF_CNC_7 = "C:'Company Name'PI numberNC Code760"
to send it to the right folder
Got the questions from setup sheets.vbs off FTP site.
Kyle
You cannot modify constant variables (variables declared with the 'Const' keyword). Instead, one way would be to create two seven-element arrays to hold the company names and pi numbers and that you read in your two DO loops (you'll need variables for index counters that you'll have to increment in each iterations) like this:
Dim arrCompanyName(7)
Dim arrPiNumber(7)
Then you'll have to assemble your seven paths, after you've prompted for company name and pi number, something like this:
Dim strCNC1
Dim strCNC2
' and so on...
Dim strCNC7
' assemble paths
strCNC1 = "C:" & arrCompanyName(0) & "" & arrPiNumber(0) & "NC CodeOP"
strCNC2 = "C:" & arrCompanyName(1) & "" & arrPiNumber(1) & "NC Code550"
' and so on...
There's more efficient ways to write this and sorry for the lack of complete code but it's quite early in the morning right now wink.gif I'll finish it up when I'm in the office.
This is what I have so far. I'm sending at break time.so I have to hurry
'// Author: Mick George [email protected]
'// Date: 16/09/2003 12:58 PM
'// File Name: MULTIPOST.VBS
'// Description: Posts drawing to two defined posts
'// Comments:
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
companyname=AskString("Company Name?")
Loop While companyname="Company Name?" Or companyname="((ESC))" Or companyname=""
Program=AskString("Part number?")
Loop While Program="Part number?" Or Program="" Or Program="((ESC))"
Dim arrProgram(7)
Dim strCNC_1
Dim strCNC_2
Dim strCNC_3
Dim strCNC_4
Dim strCNC_5
Dim strCNC_6
Dim strCNC_7
'assemmble paths
strCNC_1 = "C:" & arrCompanyName(7) & "" & arrProgram(7) & "NC CodeOP"
strCNC_2 = "C:" & arrCompanyName(7) & "" & arrProgram(7) & "NC Code550"
strCNC_3 = "C:" & arrCompanyName(7) & "" & arrProgram(7) & "NC Code1000"
strCNC_4 = "C:" & arrCompanyName(7) & "" & arrProgram(7) & "NC CodeOkuma"
strCNC_5 = "C:" & arrCompanyName(7) & "" & arrProgram(7) & "NC CodeV30"
strCNC_6 = "C:" & arrCompanyName(7) & "" & arrProgram(7) & "NC CodeV40"
strCNC_7 = "C:" & arrCompanyName(7) & "" & arrProgram(7) & "NC Code760"
Dim strCurrentPost
' -- Check for drawing
If IsDrawing Then
' -- Store current post
strCurrentPost = GetPostName
' -- Set first post as current post
Call SetPostName(DEF_FIRST_POST)
' -- Post it
Call RunPostAll(CNC_1, False)
' -- Set second post as current post
Call SetPostName(DEF_SECOND_POST)
' -- Post it
Call RunPostAll(CNC_2, False)
' -- Set third post as current post
Call SetPostName(DEF_THIRD_POST)
' -- Post it
Call RunPostAll(CNC_3, False)
' -- Set fourth post as current post
Call SetPostName(DEF_FOURTH_POST)
' -- Post it
Call RunPostAll(CNC_4, False)
' -- Set fifth post as current post
Call SetPostName(DEF_FIFTH_POST)
' -- Post it
Call RunPostAll(CNC_5, False)
' -- Set sixth post as current post
Call SetPostName(DEF_SIXTH_POST)
' -- Post it
Call RunPostAll(CNC_6, False)
' -- Set seventh post as current post
Call SetPostName(DEF_SEVENTH_POST)
' -- Post it
Call RunPostAll(CNC_7, False)
' -- Set mc back to original post
Call SetPostName(strCurrentPost)
End If
End Sub
' Function Declaration
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
It almost works. it gets to c:regaltest
but stops there and only posts the 760
I think it it just puts one post on top ov another
