Deleting Entities
You could probably make a VB script for the`at, but as far as doing in as a function in Mastercam, I don't think so.
If you have a bunch of edge curves to delete inbetween two boundaries, just delete a poly/window with intersect.
Use the window like a line and cross all the ones you need to delete. It works real fast.
Murlin
I wrote this script in a couple minutes but it might be useful.
' The sample source code contained in this file is provided by CNC Software, Inc.
' for demonstration purposes. It is provided on an 'as-is' basis and is not
' directly supported.
' CNC Software, Inc. grants you the right to use the source code in your projects
' and to freely re-distribute it to others.
' Copyright 2002-2004 CNC Software, Inc. All Rights Reserved.
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim CLine
Dim bRet
Dim intLines, intEPtr
' -- Initialize
intLines = 0
' -- Test for active drawing
If IsDrawing Then
' -- Prompt user
If askYesNo("Delete all Vertical and Horizontal lines?") = mcMSG_NO Then Exit Sub
Call ResetAll
' -- Start searching the database, mask on lines
bRet = StartDBSearch(mc_alive, mc_linetype)
' -- Ok?
If bRet Then
Do
' -- Create an instance of our line ent
Set CLine = New McLn
' -- Store the current ent id
intEPtr = GetEntityEptr
' -- Get the current ent
If GetLineData(intEPtr, CLine) Then
If CLine.X1 = CLine.X2 Or CLine.Y1 = CLine.Y2 Then ' And CLine.Z1 = CLine.Z2
' -- Blow it away
If DeleteEntity(intEPtr) Then intLines = intLines + 1
End If
End If
' -- Keep searching....
Loop While NextDBSearch
' -- Update the display
Call RepaintScreen(True)
' -- Show some feedback
ShowString intLines & " lines deleted"
End If
End If
End Sub
' Function Declaration
Function IsDrawing()
IsDrawing = StartDBSearch(mc_alive, -1)
End Function
' Sub Declaration
Public Sub ResetAll
' -- Just to be sure
Call FreeChains
Call UnselectAll
End Sub
Hi Code_Breaker,
There have been a few postings about that very subject and I did recommend this book to help get people like yourself started.
The are a number of resources, links etc in the Mastercam VBScript editors help file, to open the editor run the chook (ALT+C) mcamvb.dll and choose the New button, once the editor is open use the Help menu to access the above mentioned help file.
There are also a number of example scripts installed to your VB folder under your mcam9 install, these should also be helpful and this forum is a very good resource too, do a search for script for plenty of examples cheers.gif
The title of the book is "Teach Yourself Windows Script Host in 21 Days" and its published by Sams. Windows Script Host, aka WSH, is the component of Windows that allows scripts to interact with Windows (read: the interpreter). These scripts are written in either Visual Basic Script (VBS) or JScript (actually JavaScript but Microsoft calls it JScript because it hates Sun's dreaded "J" word). There are other scripting languages like Perl, Python and Tcl that do not use the WSH and cannot be used to automate Mastercam.
In the case of Mastercam, the scripting language used is VBS. I've never read "Teach Yourself Windows Script Host in 21 Days" but I'm sure it's loaded with VBS snippets to get you started wink.gif
