Okuma post issue
I'm still in the day of MC9. And my post is MPLOKUMA. I have tried many ways, the way that is now working I know is wrong, and I don't want it to bit me. The post wants to output "G96 S500" (Surface Speed), then on the following line output "G97 S214" (Start up RPM). The control alarms out, it wants Start up RPM first. This is so far the only way I have got it to work,
prpm #Output for start spindle
speed = speedrpm
pbld, n, *sg97, *speed, *spindle_l, pgear, e
speed = g_speed
if css_actv, pbld, n, *sg9697, *speed, e
pcss #Output Constant surface speed
speed = g_speed
if css_actv, pbld, n,"(SURF SPEED ", *sg9697, *speed,")", e
!speed
I have looked for switches at the beginning of the post related to css but I don't see it in this post. I'm sure someone has figured this out, and I would sure like to know how. The machine is an Okuma Crown Lathe. Thank you all in advance.
I don't use a G97 start rpm on any of our Okuma lathes, so I am curious why you want this; what is the benefit?
I looked in my Okuma posts and don't see anything obvious that would work better than your fix does. I modified one of my Fanuc posts to support this, but I don't use it, so I don't know how well it works:
I added this to General Output Settings: css_start_rpm : no #Do direct RPM spindle start prior to CSS
Then I have this in ltlchg which should give you the G97:
#Added for 'css_start_rpm' logic (09/05/01)
if css_actv,
if css_start_rpm,
prpm # Direct RPM startup for programmed CSS
else,
pbld, pcssg50, pcss # NO RPM start - just output the CSS
else, # Direct RPM was programmed
prpm # Output programmed RPM
Then I have this at the end of ltlchg which should output the CSS:
if css_start_rpm,
pbld, pcssg50, pcss # CSS output AFTER a G97 RPM spindle startup
Since I have the switch set to "no" I don't ever get this rpm, but it probably works
C
I run this format
(TOOL - 1 OFFSET - 1)
(PCLNR 2525M 12 - R08 INSERT - CNMG 12 04 08)
(TOOL HOLDER - PCLNR 2525M 12)
(STOCK X 0.2 STOCK Z 0.6)
( FNISH FRONT OD )
NAT1
G0 X900. Z300. T010101
G97 S497 M63
G0 X160. Z5. M08
G96 S250
Z-7.394
X142.828
G95 G1 X140. Z-8.808 F.15
Z-32.055
X142.828 Z-30.641
G0 X160.
Z5.
( FINISH FRONT FACE )
X146.828
Z-9.394
G1 X144. Z-10.808
X102.572
X90.252
G2 X88.456 Z-10.362 I-45.926 K-91.417
X6.475 Z0. I-45.028 K-91.863
G1 X-2.
X.828 Z1.414
G0 Z5.
X160.
M09 M64
G97 S497 M42 M63
G0 X900. Z300. T0100
M01
I achanged this section
speed = speedrpm
if speed = zero,
pbld, n$, *spindle_l, e$ #RPM = '0', output just an 'M05'
else,
pbld, n$, *sg97, *speed, spindle_l, pgear, "M63", e$
!css_actv$
  • 2 months later...
I run this format
( FNISH FRONT OD )
NAT1
G97 S497 M63
G0 X160. Z5. M08
G96 S250
Z-7.394
X142.828
Z-32.055
X142.828 Z-30.641
G0 X160.
Z5.
X146.828
Z-9.394
G1 X144. Z-10.808
X102.572
X90.252
G1 X-2.
X.828 Z1.414
G0 Z5.
X160.
M09 M64
G97 S497 M42 M63
M01
speed = speedrpm
if speed = zero,
else,
!css_actv$
  • 6 months later...
Could you post a copy of you post processor here? I would really like to have it for my lathe. I am a retired machinist and i have a lnc8 in my hobby shop at home. I program by MdI now.
