X5 MU1 X Style Coolant
Tony35
running X style coolant and is set to "from tool"
well in my ops it says its on but when i post i get nothing
if i have multiple ops with the same tool the first op no coolant the next op in the middle of the code boom it turns coolant on
snippet of code
N7T7M6
M50 (CHIP FLUSH ON)
S5093M3<<<<<<<<<<<<<<< COOLANT ON AFTER SPINDLE NOT PRESENT
G0G17G90G54X3.71075Y-.79839
G43H7Z3.T4
G94
G5P10000
<<<<<<<<<<<<<<<<NEXT OP SAME TOOL>>>>>>>>>>>>>>>>>>>>>>>>>>
G1X.32373Y-2.66162Z-1.333
Z-1.343F500.
G0Z3.
(SEMI FINISH CAM PROFILE +.01)
X.14689Y-2.87394
M151<<<<<<<<<<<<<<<<<<<<<<<<COOLANT ON
Z.1
G1Z-1.343
G41D7X.14833Y-2.72394F266.
any ideas why this happening or how to fix it?
TIA
ok was digging a bit deeper and found out the tool was set to "after" which should be no big deal
in my post i have "before", "with" and "after" all set after the spindle command
flipping it to "before" got it to work
this use to work in X4 MU3
the reason for this is we have so many tools built up i dont know what tool is set to what "before, with, after" and was running into coolant not turning on fast enough on the machines so i moved all the pcan, pcan1, pcan2 up in the post.
did something change here i dont know about?
ok i found out some more info here
when you double click a tool to use and it is set to "before" when it gets moved up to the current op its flipping to "after"
anybody else seeing this or am i the only guy who uses X style coolant
sorry reread post :blink:
I know that the coolant has been set to the V9 style for backwards compatibility with older posts, there is a way to reset the operations default so that the X style coolant function will be loaded into the operations. I set the coolant default from the operations.
If you are using Windows 7 or Vista C:\Users\Public\Documents\Shared McamX5
If you are using Windows XP C:\Documents and Settings\ All Users\Shared Documents\Shared McamX5
1 - go to Shared McamX5\mill\ops, folder, rename mill_inch.defaults to mill_inch.mcx
2 - open mill_inch.mcx in Mastercam as a part file
3 - open the Machine definition through the settings drop down
4 - use general machine parameters and set the coolant to the VX style
5 - save the file & exit Mcam
6 - go back to Shared McamX5\mill\ops, rename mill_inch.mcx back to mill_inch.defaults
B)
ok i went in there and sure enough it was set to V9
hopefully that fixes it up
CJep thanks for the tip would have never looked there, i checked all the MD and they were good but not the defaults
i will keep ya posted
