Rotate - Translate, Helical Geometry Creation
McRae
What mechanism is there to rotate and translate entities - concurrent to each other? I have a cross section and point data that I would like to generate a helical part out of.
I could do this the labour intensive method but hope there is some hidden gem I just don't know about.
Thanks for your replies.
I have created helical shapes from cross sections using both surfaces and solids.
Step 1 - determine the amount of rotation per unit of length needed for your helix (i.e. 360 degrees per inch).
Step 2 - rotate and translate copies of the cross section geometry so that you end up with 4 or more cross sections located correctly in 3D space.
Step 3 - create a lofted solid by chaining the cross sections. Be careful to begin chaining at the correct point to preserve the timing. Creating a reference point on your cross section chains may be helpful.
I have sometimes noticed issues at each end of the helical solid, so I typically create a solid that is longer than needed then Extrude Cut the ends off. The problems with the ends can be avoided by creating an additional rotated/translated cross section very near each end (i.e. 1 degree separation from the ends).
There are a few steps involved but the results are very good. A nice feature would be to create a helical solid by chaining a single contour, specifying length and pitch.
Good Luck
Kieth,
The method that you described is how I am doing it now. What I want is
That!
What a usefull feature this would be for me... Secondly, does anyone have a reference book of polar equations complete with the equation plotted out? I have a mathematical handbook (Schaums') but there are only a limited number of plotted graphs - the ones with names of famous mathematicians...
