5axis post problem
my have one machine culd't use G94 code.
plese help me ,thanks,thanks,thanks,,
i use mastercam Generic Fanuc 5X Mill.pst process toolpath.
O0001
( DATE - 18-05-11 TIME - 15:20 )
G21
G0 G17 G40 G80 G90 G94 G98
G0 G28 G91 Z0.
G0 G30 X0. Y0.
( D3R1.5 TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - 3. )
T1 M6
G0 G54 G90 X0. Y7.509 C-.619 B75. S3555 M3
G43 H1 Z117.074
Z17.074
G1 Z12.074 F333.
C0. F888.
Y7.563 C6.35 F333.
Y7.689 C13.303 F888.
Y7.85 C20.328
Y8.028 C26.96
Y8.255 C33.273
Y8.578 C39.929
Y8.967 C47.029
Y9.381 C54.218
Y9.801 C61.435
Y7.737 C343.817
Y7.592 C350.517
Y7.517 C356.599
Y7.509 C359.381
Z17.074 F800.
G0 Z117.074
M5
G0 G28 G91 Z0.
G0 G30 X0. Y0.
G28 C0. B0.
This is i want
O0001
G21
G0 G28 G91 Z0.
G0 G30 X0. Y0.
T1 M6
G43 H1 Z117.074
Z17.074
G1 Z12.074 F333.
C0. F619.
Y7.563 C6.35 F1962. <--------------- here
Y7.689 C13.303 F2180.<--------------- here
Y7.85 C20.328 F2329.<--------------- here
Y8.028 C26.96 F2213.<--------------- here
etc...
Here is the section of the post that handles the feedrate output.
#Feed control settings
convert_rpd$ : 0 	#Convert rapid to rapid feed
use_fr   	: 0 	#Output feedrate
                	#0 - programmed feedrate
                	#1 - inverse feedrate
                	#2 - inverse feedrate on 5 axis continuous
                	#3 - inverse feedrate on motion with rotary
inv_fd_typ   : 0 	#Calculate feed location options
                	#0 - inverse feed at tip
                	#1 - min-max on flute length
                	#2 - tip to pivot on tool length
                	#3 - min-max on flute length to pivot on tool length
inv_sec  	: 0 	#Inverse feedrate is in seconds
radius_fr	: 0 	#Use axis radius distance (pri_feed, sec_feed), user must add code
rot_feed 	: 0 	#Rapid rotary motion only feed options
                	#0 - convert to G0 rapid
                	#1 - apply rapid feedrate
maxfeedpm	: 500   #Limit for feed in inch/min
maxfeedpm_m  : 10000 #Limit for feed in mm/min
maxfrinv 	: 999.99#Limit for feed inverse time
fix_fr   	: 1 	#If feedrate is zero, apply these values
deffeedpm	: 1.	#Default for zero feed in inch/min
deffeedpm_m  : 25.   #Default for zero feed in mm/min
deffrinv 	: 500.  #Default for zero feed inverse time
The use_fr variable is the one that you want to change.
