Scan Post output for H0
First we need to define an error message. Do a search through your post for "error" and find a section that looks like this:
# Error messages
saxiswarn      : "WARNING - POST ROTARY AXIS ASSIGNMENT ('rot_on_x') OVERWRITTEN BY OPERATION"
saxisoff       : "ERROR - POST ROTARY AXIS ASSIGNMENT ('rot_on_x') IS DISABLED"
saxiserror     : "ERROR - INVALID ROTARY AXIS ASSIGNMENT ('rot_on_x') FOR CURRENT OPERATION"
sindxerror     : "WARNING - INDEX ANGLE DOES NOT MATCH POST SETTING ('ctable')"
stlorgerr      : "ERROR - TOOL ORIGIN DOES NOT MATCH CENTER OF ROTATION IN POLAR MILLING"
shomeserror    : "ERROR - G92 WORK OFFSET ('wcstype') DOES NOT SUPPORT TRANSFORM SUBPROGRAM"
ssubprgerror   : "ERROR - TOOL SUBS (REPS) ('mi1) DO NOT SUPPORT TRANSFORM SUBPROGRAMS - SET mi1$ TO ZERO AND REPOST"
scdsubprgerror : "ERROR - CUSTOM DRILL SUBS ('mi10) DO NOT SUPPORT TRANSFORM SUBPROGRAMS - SET mi10$ TO ZERO AND REPOST"
sprognoerror   : "ERROR - PROGRAM NUMBER CANNOT BE ZERO"
sprogfmterror  : "ERROR - NCI NAME MUST BE FORMATTED AS 5 SPACE DELIMITED FIELDS CONTAINING 'REV' AND 'OP' Example:'CC33042 REV 2 OP 1'"
sprgnerror     : "ERROR - SUBPROGRAM NUMBER MATCHES THE MAIN PROGRAM NUMBER"
scompwarn      : "WARNING - CUTTER COMP APPLIED ON ARC MOVE"
smiscerror     : "WARNING - MISC VALUES SET TO POST DEFAULT FOR CURRENT OPERATION"
srotaxerror    : "ERROR - MORE THAN 1 ROTARY AXIS DETECTED IN SELECTED AXIS COMBINATION - OUTPUT MAY BE INVALID"
swriteopserror : "ERROR - WRITE NC OPERATION INFORMATION MUST BE ENABLED IN CONTROL DEFINITION - SET AND REPOST"
sxaxiswarn     : "ERROR - SELECT MACHINE ACHIEVABLE TOOLPLANE WITH X-AXIS ALONG MACHINE X - SET AND REPOST"
syaxiswarn     : "ERROR - SELECT MACHINE ACHIEVABLE TOOLPLANE WITH Y-AXIS ALONG MACHINE Y - SET AND REPOST"
szaxiswarn     : "ERROR - SELECT MACHINE ACHIEVABLE TOOLPLANE WITH Y-AXIS ALONG MACHINE Y - SET AND REPOST"
srotlimwarn    : "WARNING - ROTARY LIMITS EXCEEDED (CANCEL TO EXIT)"
saxissuberror1 : "ERROR - AXIS SUBSTITUTION IS SETUP FOR HMC WITH -Y ZERO POSITION (PLANES 2,5,3,6)"
saxissuberror2 : "ERROR - AXIS SUBSTITUTION IS SETUP FOR VMC WITH +Z ZERO POSITION (PLANES 1,2)"
swcserror      : "ERROR - WORK OFFSET NUMBER OUT OF RANGE"
Let's add a new one for this example.
stool_length_error      : "ERROR - TOOL LENGTH OFFSET NUMBER IS ZERO"
Now look for the G43 output lines in your post. Usually there are two lines. One will be in ptlchg_com, and one in ptlchg0$.
Here we need to test for the condition to warn against, and trigger a warning message.
pbld, n$, "G43", *tlngno$, pfzout, scoolant, pfspindleout, next_tool$, e$
if tlngno$ = 0,
             result = mprint(stool_length_error)
             exitpost$
HTH :)
I put this right at the top of my toolchange postblock
  	if t$ <> tlngno$, pbld, "M00", e$ "(", "T & H DO NOT MATCH!!!!!!!!!!!!!!!!!!!!!!", ")", e$ "M00", e$
  	if t$ <> tloffno$, pbld, "M00", e$ "(", "T & D DO NOT MATCH!!!!!!!!!!!!!!!!!!!!!!", ")", e$ "M00", e$
Works like a charm!!!
  • 3 weeks later...
