flatsrf c-hook
mowens
The purpose of this program is to take a 3-dimensional non-planar surface
and produce a planar surface from it.
The mapping algorithm to do so uses a "spine with ribs" approach of
stepping in constant u or v, preserving the segment length along the
backbone, and preserving the segment length along each rib.
The input is a surface entity in the Mastercam database.
The user can toggle the backbone spine direction.
The output is a planar parametric surface.
FLATTENING MENU:
Surface Flattening:
Surface use this to select a surface with the mouse
Spine div number of spine points to go into the parametric surf
Rib div number of rib points to go into the parametric surf
Subdivide number of subdivisions for stepping for accuracy
Analy srf lengths of the middle flowlines, area of surface
Flatten Execute flattening with surface and parameters set
To run, create surface(s) to flatten. Set the spine divisions, rib
divisions, subdivisions (to refine stepping along ribs), and then select
"Flatten."
Menu will come up with a toggling arrow to select the direction for the
spine to go in. If the spline is in the wrong direction, select "Flip".
Select "OK" to procede to do the flattening, creating the surface.
The flattened surface will always be created in the top view, at z = 0
Note: This C-Hook Will only work with an untrimmed surface!
[This message has been edited by Allan (edited 06-30-2000).]
