Surface High Speed roughing
Candyman
Hi all,
in surface high speed roughing is there a setting for top of stock that
allows for the fact that you may have say 20mm or even 50mm stock to take off
first before you even get to the z zero or top of your part and then it starts to rough out?
in older versions there was a top of stock button you could tick that you could set..
In surface high speen roughing, it starts at the top of the solid, regardless of the min/max values.
That satement is not correct. It actually does start at the min value on the steep shallow page. If you have 20 mm stock above your Z zero than enter 20. for min. Enter your max depth as a negative number. That being said it may be faster to use a face mill to hog off all that extra material.
I stand corrected. I tried a test cut, and it didn't cut the top of the part. Turns out I had the Stock to leave set too high. I would still opt for the Face mill to rip the stock down.
