Force 4th Axis output at Tool change
Current post outputs 4th axis rotation at tool change only if position is different from the previous position. How can I force it to output the 4th axis rotation at every tool change.
The machine is a Maatsura HMC 405 with 5 degree indexing.
The post we are using is:
V14.00 E1 P0 T1232650364 M14.00 I0
# Post Name : Generic Fanuc 4X Mill.pst
# Product : Mill
# Machine Name : Generic
# Control Name : Fanuc
# Description : Generic 4 Axis Mill Post
# 4-axis/Axis subs. : Yes
# 5-axis : No
# Subprograms : Yes
# Executable : MP 14.0
Here is what I get from my post.
T5 M6
G0 G90 G54 X-.3 Y1. A0. S3000 M3
T4 M6
T4 M6
G0 G90 G54 X.3 Y-1. A180. S3000 M3
T5 M6
T5 M6
G0 G90 G54 X.3 Y-1. A180. S3000 M3 <--------- Even the same tool and position posts out the A180.
As you can see whether the position is the same or different, the A coordinate still gets posted. I noticed that the pfcout command is in my psof$, ptlchg$, and ptlchg0$ blocks and it forces the rotary coordinate to be posted. Check it out in your post. If it is missing then here is what my pfcout looks like,
pfcout          #Force C axis output
     if index = zero & rot_on_x,
       if use_rotmcode & cabs <> prv_cabs, *sindx_mc
       if absinc$ = zero, *cabs, !cinc
       else, *cinc, !cabs
Thanks for the response.
The postblock pfcout is right. However, this post apparently was modified to output the rotary axis motion before the other positioning moves using a pindex postblock .
The output reads:
G90 B0.
G0 G90 G54 P211 X-7.0075 Y-1.48 S4500 M3
G43 H1 Z2.02 T2
M8
M50Z.02
Here is how it is written in the psof$ postblock:
pindex
if mi1$ > one, absinc$ = zero
pcan1, pbld, n$, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfcout,
[if nextdc$ <> 7, *speed, *spindle], pgear, strcantext, e$
pbld, n$, sg43, *tlngno$, pfzout, scoolant, pstagetool, e$
Not sure how this is supposed to function.
In the attached file the Tool 8 is on the same tool plane as Tool 7, so there is no output of an index command. We need the index command to output even if the rotation is the same.
It is redundant, but if an operator drops down in the progam to rerun a tool, the pallet needs to index to position.
  • 1 month later...
Thanks all,
This for an indexed axis not for a full rotary axis.
Had to copy pindex and create pfindex and call it in in ptlchg$ and ptlchg0$
This is the post mod_
pfindex #Index output 'FORCED'
if index & rot_on_x,
#if (prv_indx_out <> fmtrnd(indx_out)) | (prv_cabs <> fmtrnd(cabs)),
if rot_lock, pbld, n$, *sunlock, e$
pbld, n$, [if use_rotmcode, `sindx_mc], *sgabsinc, *indx_out, e$
!cabs, !cinc
if rot_lock, pbld, n$, *slock, e$
pindex #Index output
!cabs, !cinc
