G41 output only on Finish pass
Hrmmmm, this is a fair amount of work.
First you have to know if multi passes are enabled prmcode = 15214
Then you have to know how many roughing passes were programmed prmcode = 15560
Then you have to know how many finish passes were programmed prmcode = 15380
Then you have to add the roughing passes & finish passes together to get the total number of passes programmed... sum of 2 above variables
Then you need a counter in the plinout postblock that would be triggered by the compensation on position cstart$ = 2000
Then you need to find were the G41 comes out from and put that section of code into brackets.... something like...
         if 15214 = 1,
             if counter = total number of passes,
             G41
        	else, proceed as usual
There is more to it that I listed (defining variables, pulling parameters.... etc...), but that should get you started
2 operations, 1st has 3 roughing multi passes (no finish passes and no cutter comp), 2nd has 1 finish pass (no roughing passes but with cutter comp)
N3 ( T6 M06 ) (.480 FLAT ENDMILL)
N4 (TOOLPATH MAX - Z.1)
N5 (TOOLPATH MIN - Z-2.)
N6(Z STOCK TO LEAVE  = 0.)
N7(XY STOCK TO LEAVE = 0.)
N8 M11 (UNLOCK
N9 G00 G17 G90 G54 B0. X-23.4675 Y0. S1069 M03
N10 M10 (LOCK
N11 W0.
N12 G43 H6 Z.1 M08
N13 G94 G01 Z-2. F6.42
N14 X-23.2995
N15 G03 X-31.2255 R3.963
N16 X-23.2995 R3.963
N17 G01 X-23.4675
N18 X-23.4615
N19 X-23.2935
N20 G03 X-31.2315 R3.969
N21 X-23.2935 R3.969
N22 G01 X-23.4615
N23 X-23.4555
N24 X-23.2875
N25 G03 X-31.2375 R3.975
N26 X-23.2875 R3.975
N27 G01 X-23.4555
N28(Z STOCK TO LEAVE  = 0.)
N29(XY STOCK TO LEAVE = 0.)
N30 G41 D6 X-23.2875
N31 G03 X-31.2375 R3.975
N32 X-23.2875 R3.975
N33 G01 G40 X-23.4555
N34 M05
N35 G00 G91 G28 Z0. M09
N36 G90 H00
N37 M30
1st op
2nd op
