Single Tool - Missing T# M6
  • 3 weeks later...
On the tool branch of each of the operations parameters, check the box for "force tool change"
Thanks for the reply. However this did not solve the problem. When I use a Mastercam supplied post it's there but the custom post I was given does not.
I'll keep searching or revise a "good" post to get what I need.
Thanks again.
The easist thing to do would be this but somehow I suspect this is going to cause another as yet either unthought of or unasked question
in the ptlchg_com section
#if stagetool >= zero,
     #  if omitseq$ = 1 & tseqno > 0,
     #    if tseqno = 2, n$ = t$
     #    pbld, *n$, *t$, "M06", ptoolcomm, e$
     #  else, pbld, n$, *t$, "M06", ptoolcomm, e$
  • 5 weeks later...
help im having the same trouble: two ops, one tool, M00 after 1st op w/ force tool change
i need a tool change in the first op (force tool change didnt work in first op)
(PROGRAM NAME - 2701 )
(DATE=DD-MM-YY - 29-06-12 TIME=HH:MM - 07:54 )
N100 G0 G17 G40 G49 G80 G90
( 1 CHAMFER MILL TOOL - 2 DIA. OFF. - 2 LEN. - 2 DIA. - 1. )
G0 G90 G54 X12.52 Y-3.06 S9000 M3
G43 H2 Z.5 M8
Z.1
G1 Z-.28 F30.
G41 D2 X10.02 F80.
G0 Z.5
X10.4013 Y.06
Z.1
G1 Z-.28 F30.
X14.1513 F80.
G0 Z.5
X22.21 Y0.
Z.1
G1 Z-.25 F30.
Y-3. F80.
G0 Z.5
X-.06
Z.1
G1 Z-.25 F30.
Y0. F80.
G0 Z.5
G40 M5
G91 G28 Z0. M9
G28 X0. Y0.
M01
N110 ( FLIP )
G91 G28 Z0.
G28 X0. Y0.
T2 T0 M6
G0 G90 G54 X14.1513 Y-3.06 S9000 M3
G43 H2 Z.5 M8
Z.1
G1 Z-.28 F30.
G41 D2 X10.4013 F80.
G0 Z.5
X10.02 Y.06
Z.1
G1 Z-.28 F30.
X12.52 F80.
G0 Z.5
X22.21 Y0.
Z.1
G1 Z-.25 F30.
Y-3. F80.
G0 Z.5
G40 M5
G91 G28 Z0. M9
G28 X0. Y0.
*********************portion of post. see any reason y
Start of File and Toolchange Setup
psof0$ #Start of file for tool zero
psof$
psof$ #Start of file for non-zero tool number
pcuttype
toolchng = one
if ntools$ = one,
#skip single tool outputs, stagetool must be on
stagetool = m_one
!next_tool$
"%", e$
"(PROGRAM NAME - ", sprogname$, ")", e$
"(DATE=DD-MM-YY - ", date$, " TIME=HH:MM - ", time$, ")", e$
pbld, n$, *sgcode, *sgplane, "G40", "G49", "G80", *sgabsinc, e$
sav_absinc = absinc$
if mi1$ <= one, #Work coordinate system
absinc$ = one
, sgabsinc, *sg28ref, "Z0.", e$
, *sg28ref, "X0.", "Y0.", e$
absinc$ = sav_absinc
pcom_moveb
ptoolcomment
comment$
pcan
if stagetool >= zero, pbld, *t$, "T0 M6", e$
pindex
if mi1$ > one, absinc$ = zero
pcan1, pbld, *sgcode, *sgabsinc, pwcs, pfxout, pfyout,
pfcout, *speed, *spindle, pgear, strcantext, e$
pbld, "G43", *tlngno$, pfzout, scoolant, next_tool$, e$
pcom_movea
toolchng = zero
c_msng$ #Single tool subprogram call
ptlchg0$ #Call from NCI null tool change (tool number repeats)
pcuttype
pcom_moveb
if counter <> 1,
pbld, comment$
#"G43", "H27", pfzout, "M08", e$
counter = 0
comment$
pcan
result = newfs(15, feed) #Reset the output format for 'feed'
pbld, sgplane, e$
pspindchng
pbld, scoolant, e$
if mi1$ > one & workofs$ <> prv_workofs$,
absinc$ = zero
pbld, sgabsinc, pwcs, pfxout, pfyout, pfzout, pfcout, e$
pe_inc_calc
ps_inc_calc
if cuttype = zero, ppos_cax_lin
if gcode$ = one, plinout
else, prapidout
pcom_movea
ptlchg$ #Tool change
pcuttype
toolchng = one
if mi1$ = one, #Work coordinate system
pfbld, *sg28ref,"X0.","Y0.", e$
pfbld, "G92", *xh$, *yh$, *zh$, e$
pbld, "M01", e$
pcom_moveb
ptoolcomment
pbld, n$, comment$
pbld, *sgcode, *sgplane, "G40", "G49", "G80", *sgabsinc, e$
"G91 G28 Z0.",e$
"G28 X0. Y0.",e$
pcan
pindex
pcom_movea
toolchng = zero
pretract #End of tool path, toolchange
absinc$ = one
sav_coolant = coolant$
coolant$ = zero
#cc_pos is reset in the toolchange here
cc_pos$ = zero
gcode$ = zero
pbld, sccomp, *sm05, psub_end_mny, e$
pbld, sgabsinc, sgcode, *sg28ref, "Z0.", scoolant, e$
pbld, *sg28ref, "X0." ,"Y0.", protretinc, e$
coolant$ = sav_coolant
pretracteof
absinc$ = one
coolant$ = zero
cc_pos$ = zero
gcode$ = zero
pbld, *sg28ref,"X0.", "Y0.", protretinc, e$
protretinc #Reset the C axis revolution counter
if frc_cinit & rot_on_x,
rev = zero
sav_rev = zero
cabs = zero
csav = zero
indx_out = zero
if index, e$, pindxcalc, pindex
else, *cabs
prvcabs = zero
!csav, !cabs
Change this line
to this
It looks like you're outputting everything as T0, so I don't know exactly what you have got going on there but swapping that code around a s noted about will get you a tool output
