Curve 5-axis lead/lag tilt collision control
so something that comes up all the time in milling, trimming, welding, laser cutting, etc. is the need to tilt the tool in the lead/lag or push/pull path direction based on how close to a surface/solid the tool gets. Right now in Collision Control you can set a check surface, and stock to leave but it just trims the path.
You can do this in advanced multiaxis paths, but it would be fantastic to have in curve5-axis because it's a more simple path (and costs less). that is to say I'm not expecting to see that functionality, but I wondered how hard it would be for me to build it myself. at this point I haven't done any manipulation of points/vectors in space, but I can program in C, and .NET just fine.. have made a couple net hooks, and have a good grasp of vector programming.
The part I'm missing is if I have any access to the toolpath.
I know I can change values of toolpaths, I can change change:
// CM5dlg parameters
07656 int OutputFormat; ///< Output format
07657 int PatternType; ///< Pattern Type
07658 int ToolAxis;
and I *should* be able to look at the check surfaces when selected for Collision Control
now I don't think that's per-point though. What I need to do is change the tool axis on individual points based on a collision distance or angle (or combination of both)
basically want to know if it's possible before I even embark on this mad journey
  • 2 months later...
