Hey guys,
I have my NL2000SY Post (using MPLMaster injected with CNC's pick/pull/cut off logic) 99.99% dialed. One last thing I can't fix is pchuck is outputting in the prior Op's pl_retract and I want it to output after.
Currently this is what I'm getting:
N5
(TOOL - 121 OFFSET - 121)
(10-32 ROLL FORM - R1253)
G0 G53 X-7.
G0 G53 Z0.
G0 G53 Y0.
G0 T12221
G54
G18 G99
G0 Y0.
G97
M8
G0 X0. Z.25
M329 S500
G84 Z-.5 R-.15 F.0313
G80
G0 Z.25
(PICKOFF SPINDLE - UNCLAMP AND EJECT PART)
M210 (OPEN CHUCK SECOND SPINDLE) <------------ This is the next op but outputs in the previous
M9
G0 G53 X-7.
G0 G53 Z0.
G0 G53 Y0.
M01
(PRE-POSITION CUTOFF TOOL)
N6
<-----------------------------------------------Would like it here
(TOOL - 7 OFFSET - 7)
(OD CUTOFF RIGHT - TK2041/ TR2212 INSERT - GFN-3 IC354)
G0 G53 X-7.
G0 G53 Z0.
G0 G53 Y0.
G0 T0707
G54
G18 G99
G0 Y0.
M35
G97 S1500 M03
G0 X12. Z0.
(PICKOFF SPINDLE - MOVE TO CLEARANCE DISTANCE)
G0 B0. (MOVE SECOND SPINDLE TO DEFINED POINT)
Later on in the file same thing. Last Op is a "Chuck Open" yet it places it in the previous Op:
M01
(TOOL - 3 OFFSET - 3)
(1/4" SPOT DRILL - O600)
G0 G53 X-7.
G0 G53 Z0.
G0 G53 Y0.
G0 T0303
G55
M45
G17 G98
M69
G28 H0.
G0 C37.5
G97 S750 M13
G0 Y0.
M8
G0 X.875 Z15.0825
G83 Z15.9065 R.7 F4. M268
C147.5
G80 M05
M9
M69
M46
G0 G53 X-7.
G0 G53 Z0.
G0 G53 Y0.
M01
Chris,
That is a good start. How do I suppress the pl_retract?
I'm now getting this post error.
16 Jul 2012 08:02:19 AM - <2> - RUN TIME - PST(2199), NCI(250) - The value of the string select selection variable is out of range: 903.00
This Line in pl_retract:
else,
#Retract to reference return
pbld, n$, `sgcode, psccomp, e$
Thanks!
Ron,
I tried that but I'm only a hack so I couldn't figure it out. Chris's method got me moving in the right direction.
I didn't get that error until calling pl_retract in pchuck$
pl_retract #Retract tool based on next tool gcode, lathe (see ptoolend)
cc_pos$ = zero
if home_type = one,
xh$ = vequ(start_xh)
pmap_home #Get home position, xabs
ps_inc_calc #Set inc.
pbld, n$, psccomp, e$
if lathe_stop | synch_flg | n1_gcode = 1003 | n1_posttype <> posttype$ | n1_spindle_no <> spindle_no$,
pbld, n$, pnullstop, e$
pforcelivetoolingoff
if css_actv$ & css_end_rpm & not(lathe_stop | synch_flg | n1_gcode = 1003 | n1_posttype <> posttype$ | n1_spindle_no <> spindle_no$),
pspindle
prpm
pcan1, pbld, n$, *sgcode, pfxout, pfyout, pfzout, [if drop_offset, *toolno], strcantext, e$
else,
if mi10$ = 1,
else,
pspindle
prpm
if lathe_stop | synch_flg | n1_gcode = 1003 | n1_posttype <> posttype$ | n1_spindle_no <> spindle_no$ | mi10$ = 1,
if mr10$ = 1, pbld, "M0", e$
if mi10$, pbld, "M26", e$
if g53,
pbld, n$, *sgcode, *sg53, *xhome, [if sof = 1, *bhome], e$
pbld, n$, *sgcode, *sg53, *zhome, e$
if y_axis_mch,
pbld, n$, *sgcode, *sg53, *yhome, e$
else,
pbld, n$, *sg28ref, "U0.", [if y_axis_mch, "V0."], e$
pbld, n$, "G53B0.", e$
pbld, n$, *sg28ref, "W0.", e$
if home_type = m_one & drop_offset, pbld, n$, *toolno, e$
if home_type > m_one & drop_offset, pbld, n$, *toolno, e$
if synch_flg, pbld, n$, "M36", e$ #synch off
