Need help with generic Haas TR series 5X Mill post
MSL
Hi,
I’m working on a post for a Haas TR-160Y Trunnion Table. I need to activate the A & B axis break when I’m doing a positioning cut and deactivate when operation is done. Also need to disable A & B axis break when I’m doing a 5 Axis drilling.
I'm using the generic Haas TR series 5X Mill post that comes with Mastercam.
Using X6MU2
Thanks in advance.
Ara.
I need to activate the A & B axis break when I’m doing a positioning cut and deactivate when operation is doneI need to activate the A & B axis break when I’m doing a positioning cut and deactivate when operation is done.I need to activate the A & B axis break when I’m doing a positioning cut and deactivate when operation is done.
Are you referring to the M10 - M13 clamp codes?
If so there is a variable in the post called "use_clamp"
use_clamp : 1 #Use the automatic clamp Mcode <<< Make certain the value is set to one and it will be active.
Thanks for the reply.
Yes, I'm referring to the M10 - M13 clamp codes. I have the auto clamp set to 1 now. I don’t want to have the clamp on when I’m doing 5 axis drilling. Only want them when I'm doing a positioning cut. I want my axises to be clamped so I can cut more rigid.
Thanks.
That would require some custom post editing,...
Do a search for "use_clamp"
#Lock rotary axis
#if use_clamp & (cuttype = zero | opcode$ = three | opcode$ = 16), <<<< I copied this line of code below, the pound sign will cause the post to ignore it
if use_clamp & cuttype = zero, <<< to turn off the clamping for drilling remove the opcode$ 3 & 16 information
You will need to do a search for all instances of this, opcode 3 is for drilling toolpaths opcode 16 is for 5axis drilling.
In the punclamp post block you'll need to make changes as well.
punclamp #Unclamp the rotary axis
if use_clamp,
#Force both rotaries to unlock if multi-axis
#if cuttype <> zero & opcode$ <> three & opcode$ <> 16 & (p_lock = one | s_lock = one), <<< change this line to look like the one below
if cuttype <> zero & (p_lock = one | s_lock = one),
#Lock rotary axis
if use_clamp,
Thank you for the help.
That worked out pretty good. The only thing is I need to un clamp it when I'm done with cutting.
Thanks.
Original codes:
( 1/4 FLAT ENDMILL |TOOL .25)
(FACE POSITIONING 3)
M13
M11
T1 M6
G0 G54 G90 X-6.2431 Y.1209 A-12. B-45. S5000 M3
M12
M10
G43 H1 Z12.3159
Z7.5159
G1 Z7.3359 F10.
X-6.2443 Y.2816
G0 Z12.3159
(CONTOUR - POSITIONING 3)
X-6.3167 Y.535
Z12.2959
Z7.4959
G1 Z7.2959 F10.
X-6.3838 Y.0279 F30.
Y-.2916
X-6.2799 Y.4994
X-6.3167 Y.535
X-6.3193 Y.5151
G3 X-6.2548 Y.431 I.0744 J-.0098
G0 Z12.2959
M5
G0 G28 G91 Z0.
Modified codes:
M13
M11
T1 M6
M12
M10
G43 H1 Z12.3159
Z7.5159
G1 Z7.3359 F10.
X-6.2443 Y.2816
G0 Z12.3159
X-6.3167 Y.535
Z12.2959
Z7.4959
G1 Z7.2959 F10.
Y-.2916
X-6.2799 Y.4994
X-6.3167 Y.535
X-6.3193 Y.5151
G0 Z12.2959
M13 <-------- Add or move here
M11 <-------- Add or move here
M5
G0 G28 G91 Z0.
In pretract, you can call punclamp in the line before the optional stop. That way the post keeps track of the condition.
Hi CNC Apps Guy.
I just find out that it does unclamp only when I post multiple ops (when it see M01). If I only post one op. it won't unclamp in the end as I post out my codes above. Can you show me where to add the punclamp in the post please, I might placed it in a wrong place.
Thanks.
Ara,
Instead of using the "pretract" there is a postblock called "protretinc",... it resets the C axis rev counter in the post. There is already logic in the post block that will output the M11 / M13, you may also want to shut down what was added in "pretract"
protretinc #Reset the C axis revolution counter
if frc_cinit,
p_abs = zero
p_inc = zero
s_abs = zero
s_inc = zero
pset_dlt_to_abs
# if use_clamp, #Unlock rotary axis <<<< you will need to remove the pound signs from these lines
# p_lock = zero
# s_lock = zero
# pbld, n$, s_slock, e$
# pbld, n$, s_plock, e$
# pbld, n$, *sg28, p_out, s_out, e$ <<<< to here
p_wnd_ang = zero
s_wnd_ang = zero
!p_wnd_ang, !s_wnd_ang
##### Stop custom changes #####
Hi CJep. Thanks for your help. I'm using "protretinc" it works good. The problem I have now is that when I'm machining in different plane, it looks like it's clamping and unclamping in every 1/2 degree until reaches to next position. This is only happening when I post all my operetions. If I post different operations from same plane it works fine. below you see what is happening. This has nothing to do with the changes I did in "protretinc".
Thanks.
From same plane:
O1234(WORM GEAR)
(DATE=DD-MM-YY - 27-11-12 TIME=HH:MM - 04:14)
(T1| 1/4 FLAT ENDMILL |H1)
G0 G17 G40 G49 G80 G90 G20
( 1/4 FLAT ENDMILL)
M13
M11
T1 M6
G0 G59 G90 X-6.7799 Y.535 A12. B-45. S5000 M3
M12
M10
G43 H1 Z12.7591
Z7.9591
G1 Z7.7591 F10.
X-6.8469 Y.0279 F30.
Y-.2916
X-6.7613 Y-.5175
X-6.7825 Y.5151
G3 X-6.7179 Y.431 I.0744 J-.0099
G0 X-6.718 Z12.7591
M5
M13
M11
G0 G28 G91 Z0.
G28 Y0
From different plans:
O1234(WORM GEAR)
( 1/4 FLAT ENDMILL .25)
M13
M11
T1 M6
M12
M10
G43 H1 Z12.7591
Z7.9591
G1 Z7.7591 F10.
Y-.2916
X-6.7613 Y-.5175
X-6.7825 Y.5151
G0 X-6.718 Z12.7591
(CONTOUR - POSITIONING 2)
Z12.7985
X-6.6413 Y.4307
M13
M11
A11. B-44.5
M12
M10
Z14.6912
X-2.9611 Y.4161
M12
M10
Z15.0855
X-2.1943 Y.4131
M13
M11
A-47. B-15.5
M12
M10
Z15.1249
X-2.1177 Y.4128
M13
M11
A-48. B-15.
M12
M10
Z10.3249
G1 Z10.1249 F10.
Y-.2126 F30.
X-1.8072 Y-.0151
X-1.8098 Y.0674
X-1.8837 Y.3523
X-2.1177 Y.4128
Y.3928
G3 X-2.0426 Y.3178 I.0751 J.0001
G0 X-2.0427 Z15.1249
M5
M13
M11
G0 G28 G91 Z0.
G28 Y0
