Using a machining center and spindle probe for inspection
What are your thoughts on using a machining center and spindle probe as a "not quite as accurate CMM"?
I currently do not have a CMM and have some parts I need to inspect. They are turned components and will be made on a lathe. I was thinking of using a machining center and spindle probe (which I currently have) as a method of inspecting things like profile tolerances, runout, diameters, true position, chamfers, inside radii, flatness, etc. Is this doable? Have you done this before? What software is out there to help with writing the inspection routine?
It's certainly doable, but if you're going to buy parts off doing this then you will need to laser and ball bar the machine at regualr intervals and you'll need a volumetric error map as well. Crazy MIllman can probably fill you in a littl ebetter as far as QC requirements for that.
Next, you'll need to either write the cycles by hand, purchase the Renishaw Productivity+ software package or purchase Mastercam's Renishaw Add-On. You can export reports via RS-232 or memory card on your machine using DPRNT.
We do some spot inspection from time to time if our CMM is backed up. We can format the reports out of the machine however we need to. It's not too complicated. We've got scales our machines so accuracy isn;t much of a worry but we probe more for re-machining operations so we'll know the part will fit on the 2nd Operation Fixtures.
  • 3 weeks later...
