Post coolant in different area?
Hello,
I am trying to post the M08 on a different line like below.. I am using a MPmaster edited post. Having no luck so far.. It needs to be right after the M03 spindle turns on.. It is for a older Okuma mill..
Post like this now
N100 G00 G17 G20 G40 G80 G53 G90
N110 G91 G30 P2.0 Z0.
N120 (DRILLS COUNTERBORE WITH 5/8 E.M.)
N130 M08 <---------------------------------------------------------------- Need this M08 gone or moved to below M03 ----------------------------->
N140 IF [VATOL EQ 1] N160 (SPINDLE TOOL CHECK)
N150 T1 M6
N160 S1500 M03 (SPINDLE TOOL JUMP)
N170 (MAX - Z3.)
N180 (MIN - Z-.3937)
N190 G00 G17 G90 G54 X-1.9685 Y-1.5748 S1500 M03
N200 G56 H1 Z3.
N210 G94
N220 G98 G83 Z-.3937 R.1 Q.025 F15.
N230 X1.9685
N240 G80 G53
N250 M09
N260 M05
N270 G91 G30 P2.0 Z0.
N280 M01
N290 (SPOT DRILLS THE 1/4-28 HOLES)
N300 M08
N310 IF [VATOL EQ 6] N330 (SPINDLE TOOL CHECK)
N320 T6 M6
N330 S1000 M03 (SPINDLE TOOL JUMP)
N340 (MAX - Z3.)
N350 (MIN - Z-.527)
N360 G00 G17 G90 G54 X-1.9685 Y-1.5748 S1000 M03
Need it to post like this
N150 T1 M6
N165 M08 <--------------------------------------------------------------- M08 needs to be here --------------------------------------->
N170 (MAX - Z3.)
N200 G56 H1 Z3.
N210 G94
N230 X1.9685
N240 G80 G53
N250 M09
N260 M05
N280 M01
N300 M08
N320 T6 M6
N340 (MAX - Z3.)
N350 (MIN - Z-.527)
Hello Darin, in the coolant settings you should have 3 options after you turn the coolant on; before, with, and after. try using the "with" option...it will move the M08 down. your other choice is to edit the Post to give you a different location of the M08. I prefer to have the coolant start on block N200 on its way down to Z3.0 (in this case) but I have seen it in the location you have indicated because it takes time to get coolant to the nozzle.
Good luck
Good luck
Oh ya thanks... I forgot about the pull down menu ... that worked...
