Need to post a M15 or M16 before B move
Hello,
I need to have the post put a M15 before the B+ axis rotation and a M16 before a B- rotation.. I working with a MPmaster post.. Is this something I can change in the machine or control file or is it a post add on? It is for a Okuma horizontal MC-50H with X6...
I need it to post like this
N150 G00 G17 G20 G40 G80 G90
N160 G91
N170 (MILLS THE RIGHT SIDE 35 DEG WELD PREP WITH 4.0" FACEMILL)
N180 (COMPENSATION TYPE - WEAR COMP)
N190 IF [VATOL EQ 19] N210 (SPINDLE TOOL CHECK)
N200 T19 M6
N210 S500 M03 (SPINDLE TOOL JUMP)
N220 M08
N230 (MAX - Z6.6924)
N240 (MIN - Z6.4874)
N245 M15 <-------------------------------------------------------------------------------- Need M15 for positive B rotation here --------------------------------------------------------->
N250 G00 G17 G90 G15 H1 B55. X-2.0614 Y7.375 S500 M03
N260 G56 H19 Z6.6924
N270 G94 G01 G41 D19 Y9.5 F10.
N280 Y17.533
N290 G40 Y19.658
N300 G00 X-2.198 Y7.375
N310 Z6.4974
N320 G01 G41 D19 Y9.5
N330 Y17.533
N340 G40 Y19.658
N350 G00 X-2.205 Y7.375
N360 Z6.4874
N370 G01 G41 D19 Y9.5
N380 Y17.533
N390 G40 Y19.658
N400 G91 G00 G30 P2.0
N410 (MILLS THE LEFT SIDE 35 DEG WELD PREP WITH 4.0" FACEMILL)
N415 M16 <------------------------------------------------------------------------------------------------------------Need M16 for negative B rotation here ------------------------------------------------------>
N420 G00 G90 B-55. X2.0614 Y19.658
N430 G56 H19 Z6.6924
First sace a copy of your post, then try Inserting the following on a line before the B move in the post at (ptlchg_com) section and (ptlchg0$) section.
(Example) Note:The B move is pfcout
if cabs < 0, "M16 (B CCW)", e$,
if cabs > 0, "M17 (B CW)", e$
pcan1, pbld, n$, *sgcode, *sgabsinc, pwcs, pfcout, scoolant, e$
Great thanks I will try that tomorrow...
Talk to Inhouse (or I guess more importantly, your reseller) about their MPMaster Okuma post. That has all the M15/M16 logic built in to it.
Thanks... I tried to convice these guys to buy a post for it but they refuse to pay so I am stuck trying to make my own post or use Espirt which has a post already for there old Okuma machine. And I don't really want to use Esprit.. Also this forum is great for learning about post processors it has been a great help...
I tried it but it doesn't seam to change anything.. I don't see any M16 or M17 on the code.. I started with aMPmaster post with X6
Here is where I changed the post at
ptlchg_com #Tool change common blocks
if force_output | sof,
result = force(ipr_type,ipr_type)
result = force(absinc$,absinc$)
result = force(plane$,plane$)
pcom_moveb
pcheckaxis #Check for valid rotary axis
#ptoolcomment
if sof & scomm_sav <> snull,
spaces$ = 0
n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
spaces$ = sav_spc
if sof = 0, scomm_sav = snull
comment$
pcomment3
pmisccheck
pcan
if stagetool >= zero,
spaces$=0
okuma_skip_toolnumber = t$
pbld, n$, " IF [VATOL EQ ", *okuma_skip_toolnumber,"] ",
n$ = n$ + seqinc$,
n$ = n$ + seqinc$,
*n$, " (SPINDLE TOOL CHECK)", e$
spaces$=sav_spc
n$ = n$ - seqinc$
n$ = n$ - seqinc$
pbld, n$, *t$, "M6", e$
pbld, *n$,[if nextdc$ <> 7, *speed, *spindle], pgear, strcantext, "(SPINDLE TOOL JUMP)", e$
n$, *scoolantx, e$
spaces$=0
if output_z = yes$,
preadbuf5
if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
n$, pspc, scomm_str, "MAX - ", *max_depth, scomm_end, e$
n$, pspc, scomm_str, "MIN - ", *min_depth, scomm_end, e$
spaces$=sav_spc
pstock
if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0
sav_absinc = absinc$
if wcstype > one, absinc$ = zero
pindex
if safe_index,
if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
pbld, n$, pgear, e$
if cabs < 0, "M16 (B CCW)", e$, <--------------------------------------------------------------------------------------------- Added these two lines here ----------------------------->
pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], pfcout, strcantext, e$
if lock_codes = one & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
if convert_rpd$ = one,
gcode$ = one
feed = maxfeedpm
ipr_type = zero
pbld, n$, sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, pfspindleout, [if gcode$ = 1, *feed], e$
else,
Also added it here
ptlchg0$ #Call from NCI null tool change (tool number repeats)
toolchng0 = one
if op_id$ <> last_op_id,
rd_params$ # Read parameters - pparameter
pmisccheck
pcuttype
toolcount = toolcount + 1
if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)
else, nexttool = first_tool$
retractflg = 0
if (mi10$ & (op_id$ <> last_op_id | (op_id$ = last_op_id & xform_op_id$ <> op_id$)))
| ((tlplnno$ <> last_tlplnno | rotary_type$ <> last_rotary_type) & ret_on_indx),
phsm_off
if mi10$,
pretract
n$, *sm00, e$
result = force(spdir2,spdir2) #Force spindle output after M00
result = force(speed,speed) #Force speed output after M00
else, pretract0
retractflg = 1
else,
if mr1$ <> last_mr1 | mr2$ <> last_mr2, phsm_off
pcom_moveb
comment$
pcomment3
pcan
if op_id$ <> last_op_id, pbld, n$, sgplane, e$
pspindchng
if coolant$ <> 0 & coolant$ <> sav_coolant & sav_coolant, pbld, n$, sm09, e$
pbld, n$, scoolant, e$
sav_coolant = coolant$
if coolant$ = 1, sm09 = sm09_0
if coolant$ = 2, sm09 = sm09_1
if coolant$ = 3, sm09 = sm09_2
if op_id$ <> last_op_id, pstock
if sav_mi9 = 1, workofs$ = sav_workofs
if (wcstype > one & workofs$ <> prv_workofs$) | (tlplnno$ <> last_tlplnno) | retractflg,
gcode$ = one
feed = maxfeedpm
ipr_type = zero
absinc$ = zero
pindex
if retractflg,
if safe_index,
pbld, n$, pgear, e$
if cabs < 0, "M16 (B CCW)", e$, <----------------------------------------------------------------------------------------- Added these two lines here --------------------------------------->
pbld, n$, *sgcode, [if not(index), sgabsinc, pwcs], pfcout, pspindleout, e$
pbld, n$, pfxout, pfyout, e$
else,
pbld, n$, pgear, e$
Ok I was looking at a old post. Remove the if cabs < 0, "M16 (B CCW)", e$ and if cabs > 0, "M17 (B CW)", e$ stuff from the post. Then change the use_rotmcode : 0 to a 1 and search for (sindx_cw) and change M22 and M21 to M17 and M16 this should work.
use_rotmcode : 0 #Output M-Code for Axis direction (sindx_mc)
#0 = Signed direction (only valid when rot_type = 1)
#1 = M-Code for direction
sindx_cw : "M22" #Rotate CW code -----------------------Change to "M17"
sindx_ccw : "M21" #Rotate CCW code --------------------Change to "M16"
I tried this and it still doesn't post any M code any where. I even tried it on a un-edited Mpmaster post and it doesn't post either.. It is controlled in the machine def or control somewhere?
The only thing I see is to change this in your post to a 1 because it says the M16 and M17 is (only valid when rot_type = 1)
rot_type : 0 #Rotary type - 0=signed continuous, 1=signed absolute, 2=shortest direction
Thanks... That worked but only if I have signed direction absolute checked in the machine definition manager...
