Need help with a part
MSL
Thanks guys for looking.
This is going to be done on a mill. I can not finish it on a lathe because the groove and C-Bore are not parallel to face. I tried different surface machining but couldn't come up with a good result.
Thanks.
depending on your tolerances I'd go for a 2d pocket & contour projected to a suface using a bullnose endmill. If you need to be technical the undercuting of the geometry to a normal Z direction in the file shows the groove walls with a .0006" undercut which again if it's tight tolerance stuff you'd need a 5axis machine or secondary setup and fixturing.
doing the above you'll get close and closer if you go with smaller tooling for a finish cut around the outside of the pocketing. you could even add in a ball endmill with just enough fine stepovers contouring out to the od withing the 1st cutter diameter to take it to the limit.
I'll give it a try.
Thanks.
