Drilling with a right angle head on Okuma horizontal with 5th axis table
We have 2 Makino horizontals with 5th axis rotary tables. My post for these works perfectly for drilling and milling with a right angle head. We just purchased a new Okuma MA600 horizontal with the same 5 axis tables. We need to be able to drill with a right angle head the same way as we do on our Makinos. Okuma does not use G98, G99 in their canned drill cycles. They use G53 and G54 on the line before the line with a canned cycle to control the retract hieght. It seems that no matter what I try, I get alarms when trying to change planes and dill holes in X axis. Does anyone have an idea on what the code should look like to accomplish this. No problem on our Fanuc control machines. We do aerospace structural components and drill tons of pilot holes at lots of varying angles and in tight quarters.
You can put the M53/M54 in the line with the cycle call and on any point position line there after. M54 works like a G99 in a Fanuc. The M53 retracts to a specified point called like so
G71 Z0.5 ( USED FOR RETRACT PLANE - USED WITH M53/M54 )
G81 Z-0.15 R0.05 P0.237 F0.0056 M53
Look in the special functions manual at the section called; Axis Name Designation. This function allows you to call a temporary rotation of the axis label. Example
G14 X3 Y2 Z1 ( the XYZ are the desired program code for drill cycle plane,IE XY drill points with Z drilling, The 321 are the corresponding machine axis with 1 meaning X, 2 Meaning Y, 3 Meaning Z. For reversal use a negative, example; X-3 Y2 Z1
You need to use UVW for the plane and check the below parameter. See below from the programming manual, Section 7 - Fixed cycles
2-1. Determining the Positioning Plane and the Cycle Axis
(1) Determining the positioning plane and the cycle axis by commands
The positioning plane may be determined by selecting a plane using G17, G18, and G19. The
cycle axis is then chosen as the axis which is vertical to the selected positioning plane or the
axis parallel to it.
Xp = X- or U-axis
Yp = Y- or V-axis
Zp = Z- or W-axis
Due to the nature of the cycle axis as described above, once the positioning plane is
determined, only two axes can be selected as the cycle axis. To determine the cycle axis to be
used, specify the address of the desired axis in the block that contains a fixed cycle G code
(G73 - G89).
(2) Determining the positioning plane and the cycle axis by parameter
It is possible to fix the cycle axis as the Z-axis by the setting for NC optional parameter (bit) No.
17, bit 0. Accordingly the positioning plane can only be selected by designating G17 (X-Y
plane).
G Code Positioning Plane Cycle Axis
G17 Xp-Yp plane Zp
G18 Zp-Xp plane Yp
G19 Yp-Zp plane Xp
W-axis is selected as the cycle axis.
Movements in the positioning plane
(Wrong) G17 X__Y__
G18 X__Y__Z__W__R__F__
An alarm occurs since the cycle axis cannot be determined
(two possible axes, Z and W, are specified).
(Correct) G17 X__Y__
G18 X__Y__U__V__W__R_
Okuma apps guys finally got back with me. Ran this on machine and works good. Prety close to the Fanuc code on our Makino's. Changing the G71 line to an X dimension is what solved my problem.
N80
(.098 DRILL IN RIGHT ANGLE HEAD )
(DRILL PILOT HOLES LEG 1)
M21 (UNLOCK B)
M27 (UNLOCK C)
T80 M6
M51
G0 G15 H2 G90 X-12.525 Y0 C0. B0. S4000 M3
M20 (LOCK B)
M26 (LOCK C)
G56 H80 Z10.
G19
G71 X-12.525
G81 X-11.4 R-11.675 F5. M54
Y-1.
Z11.
Y0
G0
G130
M9
M5
G30 P1
/M60
