cutting with dovetail
duckdogers
When trying to get surface toolpaths to work I always advise users to start with a big step over. This will reduce the amount of time Mastercam requires to generate toolpaths while you are tyring to get the parameters worked in. Once you have the parameters setup correctly refine your finish step down.
I selected just the surfaces I wanted to machine as drive surfaces and the surrounding as check surfaces instead of using containment boundaries. This also helps in toolpath generation time, few surfaces to machine one means less time generating. See the attached program.
INSERT.JOHN.MCX-7
Here is johns with my take on keeping the tool in the cut.
john is using the check surfaces instead of boundrys to keep the tool from going around the surfaces like you were trying with the boundry.
Also using the Direction option to give the tool a lead in and out at start and end. One this one did not build a new surface just using the ones you supplied.
Hope you find this helpful.
