mpmaster post change x/z retract,same line?
Brendan P
Hi guys,I am using a modified mpmaster post thatI have just started to use for my rotab programs.
Everything works great but I dont like a move that I'm seeing in my code:
(MILL 2 X FIRE HOLES)
A98.979
X-6.219Z-2.
Z-2.2
G1Z-3.F30.
G41D50X-8.0065F10.
G3X-4.4315R1.7875
X-8.0065R1.7875
G1X-8.0265
G3X-4.4115R1.8075
X-8.0265R1.8075
G1G40X-7.7265
G0Z-2.
See the 2nd line?
I want to split up the X/Y moves so that the Z moves by itself.
The Z clearance plane is posting on the X line.
I don't like this.
Can someone please tell me what line in my post I can correct this on?
Thank you
Open your post..
# Debugging and Factory Set Program Switches
fastmode : no #Posting speed optimizition
bug1 : 2 #0=No display, 1=Generic list box, 2=Editor
bug2 : 0 #Append postline labels, non-zero is column position?
bug3 : 0 #Append whatline no. to each NC line? 0
bug4 : 0 #Append NCI line no. to each NC line? 0
whatno : yes #Do not perform whatline branches? (leave as yes)
change bug2 to 30 or 40, save, repost...
You'll get something like this;
% pheader
O0001 pheader
(202475-021 REV 13.NCF) pheader
(OCT 17, 2003 07:51) pheader
(MC9 FILE: 202475-021 REV 13) pheader
(MACHINE: PRESTAGE 4 AXIS) pheader
(MATERIAL: BRASS) pheader
(STOCK SIZE: X 2. Y .75 Z .5) pheader
(TOOL 1: DIA 0.5000 .500 CB EM 2FL SE) pwrtt
(TOOL 2: DIA 0.1250 1/8 CB EM 4FL TIALIN) pwrtt
(TOOL 3: DIA 0.2500 1/4 CHAMFER MILL) pwrtt
(OVERALL MAX Z1.) psof
(OVERALL MIN Z-.305) psof
N1 G00 G17 G40 G49 G80 G90 G20 psof
N2 T1 psof
N3 M01 psof ptlchg_com
( OPERATION: 1 FACING ) psof popnumber
N4 ( OP 1 G54 ) psof pcomment
N5 ( FACE ) psof pcomment
N6 M06(T1: .500 CB EM 2FL SE) psof ptoolcomm
N7 M03 S7000 psof ptlchg_com
N8 G00 G90 G54 X-2.3 Y-.694 A0. psof ptlchg_com
N9 G43 H1 Z1. M08 T2 psof ptlchg_com
N10 Z.11 pzrapid prapidout
N11 G01 Z0. F50. plin plinout
N12 X.15 F70. plin plinout
N13 G03 Y-.32 I0. J.187 pcir pcirout1
N14 G01 X-2. plin plinout
N15 G02 Y.054 I0. J.187 pcir pcirout1
N16 G01 X.45 plin plinout
N17 G00 Z1. pzrapid prapidout
(OPERATION: 2 CONTOUR) ptlchg0 popnumber
N18(OP 1 G54) ptlchg0 pcomment
N19(CONTOUR) ptlchg0 pcomment
(T1: .500 CB EM 2FL SE) ptlchg0 ptoolcomm
( TOOLPATH - CONTOUR) ptlchg0 p__1:908
( STOCK LEFT ON X & Y = 0.) ptlchg0 p__1:908
( STOCK LEFT ON Z = 0.) ptlchg0 p__1:908
N20 X-.975 Y.355 ptlchg0 prapidout
N21 Z.1 pzrapid prapidout
'Rekd
BUCKETHEAD,
I'm not sitting in front of Mcam right now but my best guess is that the source of this line is from the postblock prapid (prapidout?) and might acctually originate in the .nci file. Your post might need some customizing to force x,y before z after a rotary indexing move.
HTH,
steve
Here's a copy from my master.pst for you to compare Bucket
prapidout #Output to NC of linear movement - rapid
pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, strcantext, scoolant, e
plinout #Output to NC of linear movement - feed
pcan1, pbld, n, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e
Bucket this is Mpmaster thing it involves going into the Retract part of the post as well as the lock and unlock code part of the post. It will require some playing but when doing rotation of axis mpmaster I have seen it add soe mthing I didnt like so I modified the psot to take them out antoher thing you might find is it will throw in some extra M9 here and there is you have a mist, or through the spindle code in the post. I would make a back up and then look for places in the post where you the the retract called and the other things that relate to the Z plane working at the end and the begining of the paths when doing clearance.
Crazy Millman
