Lathe Chuck Parameters
This parameter is from the machine definition, and needs to be accessed in a different way than NCI parameters.
In the pmachineinfo$ postblock, make sure this line is not commented out:
      if prmcode$ >= 17000 & prmcode$ < 18000, result = fprm(17000) #Run the parameter table for Machine Definition Parameters
then, in fprmtbl 17000 table, type something like this:
         17435   chuck_loc     #Chuck Location
That should get what you want.  (After you define the variable you want to use, of course.)
HTH :cheers:
That line is not in my post, nor is the table. It's a post by Postability so it's possible that it's binned.
I managed to make a work around; the only reason I needed it is for pick-off operations on our sub-spindled Okumas. Since I used a modified Misc-Ops > stock transfer operation, I just pulled the parameter from there. It's not an ideal solution but it got the job done.
