Formatting date and time in Post
Bocho
I hate to ask a Dreaded Post question with so few postings on the forum, but I'll risk the "Gauntlet" anyway. My Fanuc 6-M doesn't like colons,ie,:, and therefore replaces them with a letter O. As you might imagine, this makes a nasty looking time output on the Fanuc's screen. Is there a way to format the date output from the post or is this hard-coded output from the C languge? Thanks in advance, Tim
No I think that is more of a windows thing than anything even if you go to military time it still uses the : I have program set up like this.
 O9999 (03HOLE2)
(MC9 FILE - C:2003_MC92905_MC903FLIPPED.MC9)
(PROGRAM LOCATION - CNC_DELTANC_PROGRAMS2905_NC03HOLE2.NC)
(DATE - OCT-10-03)
(TIME - 16:31)
(T8 | 1/8 FLAT ENDMILL | H8 | D8 | D0.1250" | | CONTOUR....)
G0G17G40G80G90
T8M6( 1/8 FLAT ENDMILL)
(MAX | Z.25)
(MIN | Z-.1083)
I use the colon at the C: and really like thisa layout and again that is a wondows thing I beleive. I hoping if I am brave enough to start toehrs will follow. Good question.
Crazy Millman
We dont mind helping you fix your post just dont ask us to give you our posts. wink.gifwink.gif
I replaced mine with "*". You've asked a good post question. "How do I do this?", not Does anyone have a post for this..." Big difference.
How's this?
# Select month
smon00 ""
smon01 "JAN"
smon02 "FEB"
smon03 "MAR"
smon04 "APR"
smon05 "MAY"
smon06 "JUN"
smon07 "JUL"
smon08 "AUG"
smon09 "SEP"
smon10 "OCT"
smon11 "NOV"
smon12 "DEC"
smonth
fstrsel smon00 month smonth
      "(DATE      - ", *smonth, "-", *day, "-", *year, ")", e
[ 11-05-2003, 12:27 PM: Message edited by: James Meyette ]
James,
What part of the post does this go into?
#Select month
smon00 ""
smon01 "JAN"
smon02 "FEB"
smon03 "MAR"
smon04 "APR"
smon05 "MAY"
smon06 "JUN"
smon07 "JUL"
smon08 "AUG"
smon09 "SEP"
smon10 "OCT"
smon11 "NOV"
smon12 "DEC"
smonth
Before the
# General G and M Code String select tables
Usually the time is expressed in 24 hour format.
I don't know how to change the time format from ":" to anything else.
Dave??? You out there?
[ 11-05-2003, 01:11 PM: Message edited by: James Meyette ]
Thnaks James for Teaching me soemthing on this one. That book keeps on a Growing I tell you.
Crazy Millman
If you both Download the Mpmaster post you can see where this in use the copy and paste this into your existing post. I as alway recommned backing up before doing any post mod so if you mess up to bad just start over, Been there done that so just try it and do a little at a time so you can see how things work.
[ 11-05-2003, 01:10 PM: Message edited by: Millman^Crazy ]
The following are segments from the MPFADAL2.PST ->
# These formats used only for 'Date' & 'Time'
fs2 25 2.2 2.2lt #Decimal, force two leading & two trailing (time2)
fs2 26 2 0 2 0t #Integer, force trailing (hour)
fs2 27 0 2 0 2lt #Integer, force leading & trailing (min)
# -------------------- Date & Time Formatting ------------------------------
fmt 25 time2 # Capture 24-hour time value into 'time2' variable
fmt 26 hour # Hour
fmt 27 min # Minutes
# Uncomment the 'fmt' for 'day' and/or 'month' if you only want 1-digit format
#fmt 26 day # Day (2 digit format)
#fmt 26 month # Month (2 digit format)
ptime           #Turn 24-hour time format into AM/PM format
!spaces
spaces = zero
if time >= 13, time2 = (time - 12)
else, time2 = time
hour = int(time2)
min = frac(time2)
*hour, ":", *min,
if time > 12, " PM"
else, " AM"
spaces = prv_spaces
James,
Can you not using the string functions change the nth character in the string into something else an then put the string back together. I used to do this in BASIC, but ... You don't use it you loss it. It's been too long. I think according to the post manual something like this can be done. A bit of newtime$=oldtime$ manipulated kind of thing?
TIM
How do I get rid of teh extra spaces between month, day and year?
Uhhh,
spaces      : 0     #Number of spaces to add between fields
Try that one first. If not, change this;
*progno, "(EMCO", " ", progname," ",*smonth,"-",*day,"-",*year,")", e
to this;
*progno, "(EMCO", progname, *smonth, *day, *year,")", e
James,
Changing spaces to 0 removed spaces everywhere. I ended up removing the "-" between each word.
Now it post month day year (no spaces though). Thats better than day month year. Never could get used to that.
Thank you all for your efforts.
I learn a little more every day.
well i had the error on line 350 , now is
Variable not defined: smon00
Post line number 348
i have this
#Select month smon00 ""
smon01 "JAN"
smon02 "FEB"
smon03 "MAR"
smon04 "APR"
smon05 "MAY"
smon06 "JUN"
smon07 "JUL"
smon08 "AUG"
smon09 "SEP"
smon10 "OCT"
smon11 "NOV"
smon12 "DEC"
smonth
[ 11-05-2003, 04:02 PM: Message edited by: T@T@LO ]
