Mpmaster - Horizontal B output
Brian Pallas
The force_wcs is set to "yes$".  I looked in the ptlchg_com block.  I put the pfcout in a few places and never got any B output still with the one plane.
The post version is V16.00 P0 E1 W16.00 T1369940991 M16.00 I0 O1, and I am using MCAM X7.
Here is the ptlchg_com postblock:
I was wondering if the line that is "if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0" has something to do with it, but don't undertand what that line is doing yet.
ptlchg_com      #Tool change common blocks
       pbld, " ", e$
       pbld, " ", e$
       pbld, " ", e$
      if force_output | sof,
        result = force(ipr_type,ipr_type)
        result = force(absinc$,absinc$)
        result = force(plane$,plane$)
      pcom_moveb
      pcheckaxis      #Check for valid rotary axis
      if sof, uninhibit_probe$
      #ptoolcomment
      if sof & scomm_sav <> snull,
        spaces$ = 0
        n$, pspc, scomm_str, *scomm_sav, scomm_end, e$
        spaces$ = sav_spc
      if sof = 0, scomm_sav = snull
      comment$
      pcomment3
      pmisccheck
      pcan
      if stagetool >= zero,
        if omitseq$ = 1 & tseqno > 0,
          if tseqno = 2, n$ = t$
          pbld, *n$, *t$, ptoolcomm, e$
        else, pbld, n$, *t$, ptoolcomm, e$
      spaces$=0
      pbld, "M01", e$
      pbld, "M98 P8000", e$
      pbld, "M06", e$
      if output_z = yes$,
        preadbuf5
        if (opcode$ > 0 & opcode$ < 16) | opcode$ = 19,
          n$, pspc, scomm_str, "MAX - ", *max_depth, scomm_end, e$
          n$, pspc, scomm_str, "MIN - ", *min_depth, scomm_end, e$
      spaces$=sav_spc
      pstock
      sav_absinc = absinc$
      if wcstype > one, absinc$ = zero
      pindex
      if safe_index,
        if lock_codes = one & not(index) & rot_on_x, pbld, n$, *sunlock, sunlockcomm, e$
        pbld, n$, pgear, e$
        pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], pfcout, strcantext, e$
        if lock_codes = one & not(index) & rot_on_x & cuttype = 0, pbld, n$, *slock, slockcomm, e$
        if convert_rpd$ = one,
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
        pbld, n$, sgcode, [if gcode$ = 1, sgfeed], pfxout, pfyout, pfcout, pfspindleout, [if gcode$ = 1, *feed], e$
      else,
        pbld, n$, pgear, e$
          gcode$ = one
          feed = maxfeedpm
          ipr_type = zero
        pcan1, pbld, n$, *sgcode, sgplane, [if not(index), sgabsinc, pwcs], [if gcode$ = 1, sgfeed], pfcout, pfxout, pfyout,
          pfspindleout, [if gcode$ = 1, *feed], strcantext, e$
      phsm1_on        #must remain before G43
      pbld, n$, "G43", *tlngno$, pfzout, scoolant, next_tool$, e$
      pcan2           #Added so M and G codes in canned text will output before phsm2_on
      phsm2_on        #must remain after G43
      sav_coolant = coolant$
      if coolant$ = 1, sm09 = sm09_0
      if coolant$ = 2, sm09 = sm09_1
      if coolant$ = 3, sm09 = sm09_2
      absinc$ = sav_absinc
      pcom_movea
      toolchng = zero
      c_msng$ #Single tool subprogram call
      plast
